²úÆ·Ãû³Æ£º
ÍþÂÚ´¥ÃþÆÁ 10´ç ¾¼ÃÐÍ TK6102i
ÐÍ ºÅ£º
TK6102i
²úÆ·ÃèÊö£ºÍþÂÚTK6102i´¥ÃþÆÁ£¨ÈË»ú½çÃæ£©£¬ÓµÓÐ128MBÄڴ棬²ÉÓÃ400MHZ CPU£¬16£º9µÄ10´ç¿íÆÁ£¬·Ö±æÂʸߴï800*480;³ÊÏÖ¾«×¼»Ã棬ÏíÊÜÁ¼ºÃµÄÊÓ¾õЧ¹û¡£
²úÆ·ÌØµã£º
10¡±800*480 TFTLCD£¬2¸öCOM¶Ë¿Ú£¬1¸öUSB2.0½Ó¿Ú£»
ÄÚ½¨´¢´æÄÚ´æ¼°ÍòÄêÀú
LED±³¹â
USB ClientÏÂÔØ
ÄÚ½¨µçÔ´¸ôÀë·À»¤Æ÷
Com1¼°Com3µÄ¡¾RS485¡¿2WÖ§³Ö MPI 187.5K,µ«Í¬Ê±¼äÖ»ÄÜÑ¡ÔñÒ»¸öʹÓÃ
TK6102i´¥ÃþÆÁÏêϸ²ÎÊýÈçÏÂ±í£º
ÏÔʾ |
ÏÔʾÀàÐÍ |
10¡±TFT |
·Ö±æÂÊ (WxH dots) |
800 x 480 |
ÏÔʾÁÁ¶È (cd/m2) |
300 |
¶Ô±È¶È |
500:1 |
±³¹âÀàÐÍ |
LED |
±³¹âÊÙÃü |
30,000Сʱ |
ÏÔʾɫ²Ê |
65536 |
´¥¿ØÃæ°å |
ÀàÐÍ |
4ÏßÄ£Äâµç×èʽ |
´¥¿Ø¾«¶È |
Active Area Length(X)¡À2%, Width(Y)¡À2% |
ÄÚ´æ |
Flash´¢´æÆ÷ (MB) |
128 |
DRAM (MB) |
64 |
´¦ÀíÆ÷ |
32Bit RISC 400MHz |
ͨѶ²º |
SD ¿¨²å²Û |
ÎÞ |
USB Ö÷É豸 |
ÎÞ |
Mini USB ÏÂÔØ¿Ú |
USB 2.0 x 1 |
ÒÔÌ«ÍøÂç |
ÎÞ |
COMÁ¬½Ó²º |
Com1: RS-232/RS-485 2w/4w, Com3: RS-485 2w |
ÉùÒôÊä³ö |
ÎÞ |
Video Input Port |
ÎÞ |
ÍòÄêÀú |
ÄÚ½¨ |
µçÔ´ |
ÊäÈëµçÔ´ |
24¡À20%VDC |
µçÔ´¹¦ºÄ |
300mA@24VDC |
¸ôÀëµçÔ´Æ÷ |
ÄÚ½¨ |
ÄÍѹ |
500VAC (1·ÖÖÓ) |
¾øÔµµç×è |
³¬¹ý50MW at 500VDC |
¿¹Õð |
10 to 25Hz(X,Y,Z ·½Ïò 2G 30·ÖÖÓ) |
¹æ¸ñ |
Íâ¿Ç²ÄÖÊ |
¹¤ÒµËÜÁÏ |
ÍâÐγߴç WxHxD |
271 x 212 x 50mm |
¿ª¿×³ß´ç (mm) |
260 x 202 |
ÖØÁ¿ (kg) |
Ô¼1.4 kg |
²Ù×÷»·¾³ |
·À»¤µÈ¼¶ |
NEMA4 / IP65 |
´¢´æ»·¾³ÎÂ¶È |
-20¡ã~60¡ãC (-4¡ã ~ 140¡ãF) |
ʹÓû·¾³ÎÂ¶È |
0¡ã ~ 50¡ãC (32¡ã ~ 122¡ãF) |
ʹÓû·¾³Êª¶È |
10% ~ 90% @ 40¡ãC, ÎÞÀäÄý |
Å·ÃËCEÈÏÖ¤ |
EN 55022:2006,Class A, EN 61000-3-2:2006,
EN 61000-3-3:1995+A1:2001+A2:2005
EN 55024:1998+A1:2001+A2:2003 |
ʹÓÃÈí¼þ |
½öÊÊÓÃÓÚ¼òÌåÖÐÎİæEB8000 V4.42»ò¸üаæ | , ctly; mso-element-anchor-h: column"> 10 to 25Hz(X,Y,Z ·½Ïò 2G 30·ÖÖÓ)
¹æ¸ñ |
Íâ¿Ç²ÄÖÊ |
¹¤ÒµËÜÁÏ | |
ÍâÐγߴç WxHxD |
271 x 212 x 50mm | |
¿ª¿×³ß´ç (mm) |
260 x 202 | |
ÖØÁ¿ (kg) |
Ô¼1.4 kg | |
²Ù×÷»·¾³ |
·À»¤µÈ¼¶ |
NEMA4 / IP65 | |
´¢´æ»·¾³ÎÂ¶È |
-20¡ã~60¡ãC (-4¡ã ~ 140¡ãF) | |
ʹÓû·¾³ÎÂ¶È |
0¡ã ~ 50¡ãC (32¡ã ~ 122¡ãF) | |
ʹÓû·¾³Êª¶È |
10% ~ 90% @ 40¡ãC, ÎÞÀäÄý | |
Å·ÃËCEÈÏÖ¤ |
EN 55024:1998+A1:2001+A2:2003 | |
ʹÓÃÈí¼þ |
½öÊÊÓÃÓÚ¼òÌåÖÐÎİæEB8000 V4.42»ò¸üаæ | , TH: 257.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: 1pt inset; mso-border-alt: inset windowtext .75pt" width=343>
Å·ÃËCEÈÏÖ¤ |
