桌面式RMI XLS 108/208 CPU,带WAN x 1, Switch LAN x 5
产品亮点
机箱:BOX-105B
主板:DNB-1500/DNB-1501
CPU: RMI XLS 108 750MHz
内存:1G DDRII
硬盘:320G SATA
电源:200W
6个千兆网口,1个VGA口,1个CONSOLE口,2个USB口,1个板载CF卡卡槽,1个MINI-PCI插槽。
特点详情
桌面式网络安全平台,整机尺寸272mmx 195mm x 44mm,CPU采用RMI XLS 108 750MHz结构,整机提供1个PCI扩展插槽,1个MINPCI槽。机器支持网络BYPASS功能,网络唤醒功能。
Specifications |
主板 |
- DNB 1500/DNB 1501
- On Board RMI XLS 108 750MHz/On Board RMI XLS 208 Dual Core 600 MHz Processors
内存 |
- 1 x 200-pin DDR2 SO-DIMM Socket, up to 1GB DDR2 SO-DIMM
网络特点 |
- LAN Chip: 1 x Marrell 88E11111 x Marrell 7395
- Support 10/100/1000 link speed
- LAN BYPASS: 1 pair
扩展 |
- Support 2 x Mini-PCIe Slot
I/O接口-前面板 |
- Power status/HDD status/LAN status LEDs
I/O接口-后面板 |
- 1 x Power button
- 1 x RJ45 type for Console port
- 2 x USB 2.0 ports
- 6 x Copper LAN ports
设置 |
- 1 x on-board CompactFlash socket
- 1 x On-board 128MB fl ash memory
电源输入 |
- Support 60W ATX Power Supply
认证 |
- CE approval
- FCC Class B
- UL
尺寸规格 |
- Chassis Dimension: 330mm x 220mm x 44mm
- Carton Dimension: 430mm x 300mm x 170mm
重量 |
- Without packing : 2 kg
- With packing : 4 kg
订购信息
· DNA 1500 (P/N: 10L00150000X0)Desktop RMI XLS 108 750MHz, GbE WAN x 1, GbE Switch LANs x 5
· DNA 1501 (P/N: 10L00150100X0)Desktop RMI XLS 208 Dual Core 600 MHz, GbE WAN x 1, GbE Switch LANs x 5
