Desktop Intel® Atom8482; D510 Dual Core/D410 Single Core 1.66GHz 处理器,1U上架式整机,带6PCIe千兆网络接口
产品亮点
机箱:DTX-105A
主板:NSB1110
CPU: INTEL ATOM D510
内存:1G DDR2
硬盘:320G SATA
电源:200W电源(可选配4个千兆网口)
6个intel 82583千兆网口(支持BY PASS功能),1个VGA口,1个CONSOLE口,2个USB口,1个板载CF卡卡槽,1个PCI插槽,1个MINI-PCI插槽。
特点详情
1U机架式网络安全平台,整机尺寸426mmx 238mm x 44mm,CPU采用凌动D510 1.66G,整机提供1个PCI扩展插槽。机器支持网络BYPASS功能,网络唤醒功能。
Specifications |
主板 |
- NSB 1110
- Support Intel® Atom8482; D510 Dual Core/D410 Single Core 1.66GHz Processors
- Intel® ICH8M Chipset
内存 |
- 1 x 240-pin DDR2 667/800 DIMM Socket, up to 2GB Non-ECC DDR2 SDRAM
网络特点 |
- LAN Chip: Intel® 82583V
- Support 10/100/1000 link speed
- LAN Bypass: 2 pairs
扩展 |
I/O接口-前面板 |
- Support 2 x 16 Characters LCD Module, PIO interface (Optional)
- Power status/HDD status/LAN status/Bypass status LED
- 2 x USB 2.0 Ports
- 1 x RJ45 type Console Port
- 1 x software button
- 6 x Copper LAN Ports
- PCI Expansion (Optional)
I/O接口-后面板 |
- I/O Interface-Rear
- 2 x USB 2.0 Ports
- 1 x VGA Port
设置 |
- 1 x CompactFlash Socket (Optional)
- 1 x Intelnal 3.5" HDD bay
- 1 x SATA-DOM device space
电源输入 |
尺寸规格 |
- Chassis Dimension: 426mm x 238mm x 44mm
- Carton Dimension: 556mm x 384mm x 185 mm
重量 |
- Without Packing: 5.6kg
- With Packing: 8kg
认证 |
- CE approval
- FCC Class A
- UL
订购信息
· NSA 1110 (P/N: 10S00111000X0)Intel® Atom8482; D410 Single Core 1.66GHz Processors, 1 DDR2 memory slot,6 Gigabit LAN ports with two pairs bypass, CompactFlash Socket, VGA, USB port, One Mini-PCI Slot, Two PCI expansion slot
· NSA 1110A (P/N: 10S00111001X0)Intel® Atom8482; D510 Dual Core 1.66GHz Processors, 1 DDR2 memory slot,6 Gigabit LAN ports with two pairs bypass, CompactFlash Socket, VGA, USB port, One Mini-PCI Slot, Two PCI expansion slot
· NSA 1110-C4 (P/N: 10S00111002X0)Intel® Atom8482; D410 Single Core 1.66GHz Processors, 1 DDR2 memory slot,4 Gigabit LAN ports with two pairs bypass, CompactFlash Socket, VGA, USB port, One Mini-PCI Slot, Two PCI expansion slot
· NSA 1110A-C4 (P/N: 10S00111003X0)Intel® Atom8482; D510 Dual Core 1.66GHz Processors, 1 DDR2 memory slot,4 Gigabit LAN ports with two pairs bypass, CompactFlash Socket, VGA, USB port, One Mini-PCI Slot, Two PCI expansion slot
