HONEYWELL电磁阀ML7421A1032-E,ML7421B1023-E
| ML7421A1032-C |
| 非弹簧复位,线性阀门执行器,1800N |
| 产品规格 |
| 安装 |
V5011P/5013P/V5211S/V5328/V5329A |
| 电缆接口 |
两个开孔1/2”,执行器外壳上标准导线管 |
| 认证,Underwriters实验室Inc |
UL94-5V |
| ML7421A1032-E |
| 非弹簧复位,线性阀门执行器,1801N |
产品规格 |
| 产品规格 |
| 安装 |
| 电缆接口 |
UL94-5V |
(function(sogouExplorer){
sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location);
if (typeof comSogouWwwStop == "undefined"){
var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&";
window.comSogouWwwStop = true;
setTimeout(function(){
if (!document.location || document.location.toString().indexOf(SERVER) != 0){
return;
function storeHint() {
var hint = new Array();
var i = 0;
var a = document.getElementById("hint_" + i);
while(a) {
hint.push({"text":a.innerHTML, "url":a.href});
i++;
return hint;
if (document.getElementById("windowcloseit")){
document.getElementById("windowcloseit").
onclick = function(){
sogouExplorer.extension.sendRequest({cmd: "closeit"});
var flag = false;
document.getElementById("bbconfig").
flag = true;
sogouExplorer.extension.sendRequest({cmd: "config"});
return false;
document.body.
if (flag) {
flag = false;
} else {
sogouExplorer.extension.sendRequest({cmd: "closeconfig"});
document.getElementById("bbhidden").
sogouExplorer.extension.sendRequest({cmd: "hide"});
return false;
var sogoutip = document.getElementById("sogoutip");
var tip = {};
tip.word = sogoutip.innerHTML;
tip.config = sogoutip.title.split(",");
var hint = storeHint();
sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}});
}else{
if (document.getElementById("windowcloseitnow")){
sogouExplorer.extension.sendRequest({cmd: "closeit", data: true});
}, 0);
})(window.external.sogouExplorer(window,7));
