免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → 高温光纤GXH510
产品名称: 高温光纤GXH510
型 号: GXH510
价 格:
品 牌: 189
TAKEX高温光纤GXH510
takex GXH520,GXH510,GXH505,GXSH505,GXSH510,GXSH520高温光纤有小量现货,现改用新款GXH520j,GXH510j,GXH505j高温光纤
FUH612BC U Sharpe,
Heat resistance 130°C
12 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''unit%2FFUH612BC_e.htm''%2C''''%2C''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'')%22">Dimensions -
FTH7BC Low cost,
Heat resistance 105°C
830 460 270 230 80 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''unit%2FFTH7BC_e.htm''%2C''''%2C''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'')%22">Dimensions
GLT500J series M4 screw,
Heat resistance 230°C
610 340 195 180 65 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''unit%2FGLT500J_e.htm''%2C''''%2C''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'')%22">Dimensions
GT500J series M4 screw,
610 340 195 180 65 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''unit%2FGT500J_e.htm''%2C''''%2C''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'')%22">Dimensions
GTH500J series M4 screw,
Heat resistance 350°C
610 340 195 180 65 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''unit%2FGTH500J_e.htm''%2C''''%2C''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'')%22">Dimensions
Side view FTHV74BC Low cost,
830 460 270 230 60 onclick_fckprotectedatt="%20onclick%3D%22MM_openBrWindow(''unit%2FFTHV74BC_e.htm''%2C''''%2C''menubar%3Dyes%2Cscrollbars%3Dyes%2Cresizable%3Dyes%2Cwidth%3D630%2Cheight%3D540'')%22">Dimensions
(function(sogouExplorer){ sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location); if (typeof comSogouWwwStop == "undefined"){ var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&"; window.comSogouWwwStop = true; setTimeout(function(){ if (!document.location || document.location.toString().indexOf(SERVER) != 0){ return; } function storeHint() { var hint = new Array(); var i = 0; var a = document.getElementById("hint_" + i); while(a) { hint.push({"text":a.innerHTML, "url":a.href}); i++; a = document.getElementById("hint_" + i); } return hint; } if (document.getElementById("windowcloseit")){ document.getElementById("windowcloseit").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "closeit"}); } var flag = false; document.getElementById("bbconfig").onclick = function(){ flag = true; sogouExplorer.extension.sendRequest({cmd: "config"}); return false; } document.body.onclick = function(){ if (flag) { flag = false; } else { sogouExplorer.extension.sendRequest({cmd: "closeconfig"}); } };/* document.getElementById("bbhidden").onclick = function(){ sogouExplorer.extension.sendRequest({cmd: "hide"}); return false; } */ var sogoutip = document.getElementById("sogoutip"); var tip = {}; tip.word = sogoutip.innerHTML; tip.config = sogoutip.title.split(","); var hint = storeHint(); sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}}); }else{ if (document.getElementById("windowcloseitnow")){ sogouExplorer.extension.sendRequest({cmd: "closeit", data: true}); } } }, 0); } })(window.external.sogouExplorer(window,7));
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
