FOTEK光电开关FR-2MX
擴散反射式 |
FR-1MX |
FR-1MX-V |
FR-2MX |
FR-2MX-V |
感應方向 |
Horizontal |
Vertical |
Horizontal |
Vertical |
感應距離 |
1M |
2M |
電流消耗量 |
20mA max. |
35mA max. |
重量 |
Appr.105g |
Appr.120g |
Appr.105g |
Appr.125g |
鏡片反射式 |
FG-3MX |
FG-3MX-V |
感應方向 |
Horizontal |
Vertical |
感應距離 |
4M |
電流消耗量 |
20mA max. |
重量 |
Appr.105g |
Appr.120g |
對照式 |
FT-10MX |
FT-10MX-V |
FT-20MX |
FT-20MX-V |
感應方向 |
Horizontal |
Vertical |
Horizontal |
Vertical |
感應距離 |
10M |
20M |
電流消耗量 |
Emitter8249;30mA;Receiver8249;20mA |
重量 |
Appr.210g |
Appr.240g |
Appr.210g |
Appr.240g | |
FOTEK台湾阳明MS系列光电开关产品
MS-02W |
MS-02W-H |
MS-0W-M12 |
MS-02W-H-M12 |
Setting Distance设定距离 |
25.0mm |
Fmitter发光源 |
White Light Led白光 |
Light Spot光点 |
2.0φ |
Response Time反应时间 |
0.25ms |
0.1ms |
0.25ms |
0.1ms |
Illumination耐外乱光 |
Lamplight<5,000 Lux:Sunlight<10,000 Lux |
Operation Voltage工作电压 |
10-30VDC,Ripple<20% of p-p |
Current Consumption消耗电流 |
40.0mA Max |
Output Method输出方式 |
NPN&PNP Two Output |
Output Status输出状态 |
NC or NO Changeable |
Output Current输出电流 |
150.0mA Max |
Leakage Current漏电流 |
≤0.8mA |
Residual Voltage残留电压 |
≤0.8v |
Protection Circuit保护电路 |
Short Circuit & Polarity Reversed Protection |
Connection Method接线方式 |
4C/5.0φ×2M |
M12 Connecter |
Housing Material外壳材料 |
Intensive PBT |
Protection Class保护等级 |
IP65 |
Circumstance工作环境 |
.- 20℃+60℃;35~85% RH |
(function(sogouExplorer){
sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location);
if (typeof comSogouWwwStop == "undefined"){
var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&";
window.comSogouWwwStop = true;
setTimeout(function(){
if (!document.location || document.location.toString().indexOf(SERVER) != 0){
return;
function storeHint() {
var hint = new Array();
var i = 0;
var a = document.getElementById("hint_" + i);
while(a) {
hint.push({"text":a.innerHTML, "url":a.href});
i++;
return hint;
if (document.getElementById("windowcloseit")){
document.getElementById("windowcloseit").onclick = function(){
sogouExplorer.extension.sendRequest({cmd: "closeit"});
var flag = false;
document.getElementById("bbconfig").onclick = function(){
flag = true;
sogouExplorer.extension.sendRequest({cmd: "config"});
return false;
document.body.onclick = function(){
if (flag) {
flag = false;
} else {
sogouExplorer.extension.sendRequest({cmd: "closeconfig"});
document.getElementById("bbhidden").onclick = function(){
sogouExplorer.extension.sendRequest({cmd: "hide"});
return false;
var sogoutip = document.getElementById("sogoutip");
var tip = {};
tip.word = sogoutip.innerHTML;
tip.config = sogoutip.title.split(",");
var hint = storeHint();
sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}});
}else{
if (document.getElementById("windowcloseitnow")){
sogouExplorer.extension.sendRequest({cmd: "closeit", data: true});
}, 0);
})(window.external.sogouExplorer(window,7));
