FOTEK接近开关PM30-15N
台湾阳明圆柱型接近开关产品选型
型号 |
输出状态 |
输出方式 |
工作电压 |
感应距离 |
反应频率 |
安装方式 |
PM08-01N |
NO |
NPN |
10~30VDC |
1.0mm |
2.5KHZ |
Flushed |
PM08-01NB |
NC |
NPN |
PM08-01P |
NO |
PNP |
PM08-01PB |
NC |
PNP |
PM12-02N |
NO |
NPN |
10~30VDC |
2.0mm |
2.5KHZ |
Flushed |
PM12-02NB |
NC |
NPN |
PM12-02P |
NO |
PNP |
PM12-02PB |
NC |
PNP |
PM12-02N-S |
NO |
NPN |
10~30VDC |
2.0mm |
2.5KHZ |
Flushed |
PM12-02NB-S |
NC |
NPN |
PM12-02P-S |
NO |
PNP |
PM12-02PB-S |
NC |
PNP |
PM12-04N-S |
NO |
NPN |
10~30VDC |
4.0mm |
2.5KHZ |
Non-Flushed |
PM12-04NB-S |
NC |
NPN |
PM12-04P-S |
NO |
PNP |
PM12-04PB-S |
NC |
PNP |
PM12-02N |
NO |
NPN |
10~30VDC |
2.0mm |
2.5KHZ |
Flushed |
PM12-02NB |
NC |
NPN |
PM12-02P |
NO |
PNP |
PM12-02PB |
NC |
PNP |
PM12-04N |
NO |
NPN |
10~30VDC |
4.0mm |
2.5KHZ |
Non-Flushed |
PM12-04NB |
NC |
NPN |
PM12-04P |
NO |
PNP |
PM12-04PB |
NC |
PNP |
PM12-02S |
NO |
SCR |
90~250VAC |
2.0mm |
20HZ |
Flushed |
PM12-02SB |
NC |
SCR |
PM12-04S |
NO |
SCR |
90~250VAC |
4.0mm |
20HZ |
Non-Flushed |
PM12-04SB |
NC |
SCR |
PM18-05N |
NO |
NPN |
10~30VDC |
5.0mm |
2.5KHZ |
Flushed |
PM18-05NB |
NC |
NPN |
PM18-05P |
NO |
PNP |
PM18-05PB |
NC |
PNP |
PM30-10N-S |
NO |
NPN |
10~30VDC |
10.0mm |
500KHZ |
Flushed |
PM30-10NB-S |
NC |
NPN |
PM30-10P-S |
NO |
PNP |
PM30-10PB-S |
NC |
PNP |
PM30-15N-S |
NO |
NPN |
10~30VDC |
15.0mm |
500KHZ |
Non-Flushed |
PM30-15NB-S |
NC |
NPN |
PM30-15P-S |
NO |
PNP |
PM30-15PB-S |
NC |
PNP |
PM30-10S |
NO |
SCR |
90~250VAC |
10.0mm |
20HZ |
Flushed |
PM30-10SB |
NC |
SCR |
PM30-15S |
NO |
SCR |
90~250VAC |
15.0mm |
20HZ |
Non-Flushed |
PM30-15SB |
NC |
SCR |
(function(sogouExplorer){
sogouExplorer.extension.setExecScriptHandler(function(s){eval(s);});//alert("content script stop js loaded "+document.location);
if (typeof comSogouWwwStop == "undefined"){
var SERVER = "http://ht.www.sogou.com/websearch/features/yun1.jsp?pid=sogou-brse-596dedf4498e258e&";
window.comSogouWwwStop = true;
setTimeout(function(){
if (!document.location || document.location.toString().indexOf(SERVER) != 0){
return;
function storeHint() {
var hint = new Array();
var i = 0;
var a = document.getElementById("hint_" + i);
while(a) {
hint.push({"text":a.innerHTML, "url":a.href});
i++;
return hint;
if (document.getElementById("windowcloseit")){
document.getElementById("windowcloseit").onclick = function(){
sogouExplorer.extension.sendRequest({cmd: "closeit"});
var flag = false;
document.getElementById("bbconfig").onclick = function(){
flag = true;
sogouExplorer.extension.sendRequest({cmd: "config"});
return false;
document.body.onclick = function(){
if (flag) {
flag = false;
} else {
sogouExplorer.extension.sendRequest({cmd: "closeconfig"});
document.getElementById("bbhidden").onclick = function(){
sogouExplorer.extension.sendRequest({cmd: "hide"});
return false;
var sogoutip = document.getElementById("sogoutip");
var tip = {};
tip.word = sogoutip.innerHTML;
tip.config = sogoutip.title.split(",");
var hint = storeHint();
sogouExplorer.extension.sendRequest({cmd: "show", data: {hint:hint,tip:tip}});
}else{
if (document.getElementById("windowcloseitnow")){
sogouExplorer.extension.sendRequest({cmd: "closeit", data: true});
}, 0);
})(window.external.sogouExplorer(window,7));
