| Output mothod 輸出模式 |
NPN N.O. |
PSC1203-N |
PSC1203-ND |
PSC1206-N |
PSC1206-ND |
| NPN N.C. |
PSC1203-N2 |
PSC1203-N2D |
PSC1206-N2 |
PSC1206-N2D |
| PNP N.O. |
PSC1203-P |
PSC1203-PD |
PSC1206-P |
PSC1206-PD |
| PNP N.C. |
PSC1203-P2 |
PSC1203-P2D |
PSC1206-P2 |
PSC1206-P2D |
NPN N.O./N.C. PNP N.O./N.C. |
| SCR N.O. |
| SCR N.C. |
| Sensing surface / 檢測方向 |
Shielded / 隔離型 |
Unshielded / 非隔離型 |
| Description / 外型 |
Standard / 標準M12 |
| Standard sensing object / 標準檢測物 |
Iron 12 × 12 × 1 mm |
| Sensing distance / 檢出距離 |
3 mm |
6 mm |
| Secure sensing distance / 建議距離 |
0 to 2.4 mm |
0 to 4.8 mm |
| Hysteresis / 遲滯 |
≦ 10 % of sensing distance |
| Response time / 反應時間 |
DC Type 1 ms Max. |
| Operating voltage / 工作電壓 |
DC12 ~ 24 V |
| Current consumption / 消耗電流 |
DC: ≦ 8 mA no-load |
| Load current / 負載電流 |
DC: 100 mA Max |
| Leakage current / 漏電流 |
≦ 1.1 mA no-load |
| Residual voltage / 殘餘電壓 |
≦ DC 2V |
| Insulation resistance / 隔離阻抗 |
20MΩ min. (DC500V) |
| Voltage withstandability / 絕緣耐壓 |
AC1000V 60Hz for 60 Sec. |
| Operating temperature / 工作溫度範圍 |
-20℃ ~ + 60℃ |
| Protection degree / 防水等級 |
IP 67 |
| Wiring method / 出線方式 |
Ø4.2 x 2M / 3-wires |
M8 pigtailed type / M8接頭15cm電線式 |
| Weight / 重量 |
Approx. 64g |
Approx. 48g |
Approx. 65g |
Approx. 49g |
