Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú ´«¸ÐÆ÷
²úÆ·Ãû³Æ£º ´«¸ÐÆ÷
ÐÍ ºÅ£º ·ÆÄá¿Ë˹SAC-4P-10,0-PUR/M12FR´«¸ÐÆ÷Ö´ÐÐÆ÷µçÀÂ
Æ· ÅÆ£º 340
´«¸ÐÆ÷/Ö´ÐÐÆ÷µçÀÂ, 4¡ª¡ªÎ»Êý, PUR ÎÞÂ±ËØ, ºÚ-»ÒÉ« RAL 7021, ×ÔÓɳöÏß, on ¿×ʽ£¬ÍäÍ· M12, A±àÂë, µçÀ³¤¶È: 10 m
²úƷͼƬ¡¢¼Û¸ñ¡¢²úÆ·ÊôÐÔµÈ×ÊÁÏ£¬½ö¹©²Î¿¼£¬¾ßÌåÒÔѯ¼ÛʱΪ׼£¬ÈçÐèÏêϸ¼¼Êõ×ÊÁÏÇëÁªÂ磬»¶Ó­ÔÚÏß»òÀ´µç×Éѯ¡­¡­
ÏÃÃŷƹÌ×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾>
Phoenix·ÆÄá¿Ë˹ȫϵÁвúÆ·>
KAKU ¿¨¹Ì·ç»úͨ·ç¹ýÂËÍø×é>
ÏúÊÛ·ÆÄá¿Ë˹µçÔ´¡¢ILBÎÞÏßÄ£¿é¡¢ÊäÈëÊä³öÄ£¿éϵÁС¢´«¸ÐÆ÷¡¢¶Ë×Ó¡¢¼ÌµçÆ÷¡¢ÐźŸôÀë±¶Ôö·Å´óÆ÷¡¢ÒÔÌ«Íø½»»»»ú¡¢Ñ¹½ÓÇаþÏßǯCRIMPFOXϵÁС¢ÂÝË¿µ¶¹¤¾ß¡¢ÀËÓ¿±£»¤·ÀÀׯ÷¡¢×Ô¶¯»¯²úÆ·£»KAKU¿¨¹Ì·ç»úͨ·ç¹ýÂËÍø×飻ʩÄ͵Â140PLC£»ÃÀ¹úAB PLC²úÆ·£»ABB¶Ë×ÓM4/6¡¢M6/8¼°Öն˹̶¨Æ÷BAM2¡¢¶Ë°åFEM6£¬ÎºµÂÃ×ÀÕ¶Ë×ÓSAKϵÁУ¬µ¼¹ì¡£
            ÐÍ    ºÅ             ÐͺÅ˵Ã÷
QUINT-PS-100-240AC/24DC/2.5 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-100-240AC/24DC/5 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-100-240AC/24DC/10 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-100-240AC/24DC/20 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-100-240AC/24DC/40 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-100-240AC/12DC/10 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-100-240AC/48DC/5 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-100-240AC/48DC/10 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-100-240AC/48DC/20 ·ÆÄá¿Ë˹µçÔ´
QUINT-DIODE/40 µçÔ´ÈßÓàÄ£¿é
QUINT-PS-3X400-500AC/48DC/10 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-3X400-500AC/24DC/5 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-3X400-500AC/24DC/10 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-3X400-500AC/24DC/20 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-3X400-500AC/24DC/30 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS-3X400-500AC/24DC/40 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/12DC/15 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/12DC/20 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/24DC/3.5 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/24DC/5 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/24DC/10   ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/24DC/20 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/24DC/40 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/48DC/5 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/1AC/48DC/10 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/3AC/24DC/5 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/3AC/24DC/10 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/3AC/24DC/20 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/3AC/24DC/40 ·ÆÄá¿Ë˹µçÔ´
QUINT-PS/3AC/48DC/20 ·ÆÄá¿Ë˹µçÔ´
QUINT-DC-UPS/24DC/10 ·ÆÄá¿Ë˹µçÔ´
QUINT-DC-UPS/24DC/20 ·ÆÄá¿Ë˹µçÔ´
QUINT-DC-UPS/24DC/40 ·ÆÄá¿Ë˹µçÔ´
QUINT-BAT/24DC/12AH     ·ÆÄá¿Ë˹µçÔ´
QUINT-BUFFER/24DC/20 ·ÆÄá¿Ë˹µçÔ´Ä£¿é
TRIO-PS/1AC/24DC/2.5    ·ÆÄá¿Ë˹µçÔ´
TRIO-PS/1AC/24DC/5 ·ÆÄá¿Ë˹µçÔ´
TRIO-PS/1AC/24DC/10 ·ÆÄá¿Ë˹µçÔ´
TRIO-PS/1AC/24DC/20 ·ÆÄá¿Ë˹µçÔ´
TRIO-PS/3AC/24DC/10 ·ÆÄá¿Ë˹µçÔ´
TRIO-PS/3AC/24DC/20 ·ÆÄá¿Ë˹µçÔ´
TRIO-PS/3AC/24DC/40  ·ÆÄá¿Ë˹µçÔ´
MINI-PS-100-240AC/5DC/3 ·ÆÄá¿Ë˹µçÔ´
MINI-PS-100-240AC/2X15DC/1·ÆÄá¿Ë˹µçÔ´
MINI-PS-100-240AC/24DC/2  ·ÆÄá¿Ë˹µçÔ´
STEP-PS/1AC/24DC/1.75 ½ô´ÕÐ͵çÔ´
STEP-PS/1AC/24DC/4.2   ½ô´ÕÐ͵çÔ´
STEP-PS/1AC/12DC/3   ½ô´ÕÐ͵çÔ´
VAL-MS 320/3+1 ·ÆÄá¿Ë˹·ÀÀׯ÷
VAL-MS 320/1+1 ·ÆÄá¿Ë˹·ÀÀׯ÷
VAL-MS 230/3+1 ·ÆÄá¿Ë˹·ÀÀׯ÷
VAL-MS 500 ST ·ÆÄá¿Ë˹·ÀÀׯ÷
VAL-MS 400 ST ·ÆÄá¿Ë˹·ÀÀׯ÷
VAL-MS 320 ST ·ÆÄá¿Ë˹·ÀÀׯ÷
VAL-MS 230 ST ·ÆÄá¿Ë˹·ÀÀׯ÷
VAL-MS 120 ST ·ÆÄá¿Ë˹·ÀÀׯ÷
VAL-MS BE ·ÀÀׯ÷µ××ù
PT 1X2+F-BE ·ÆÄá¿Ë˹·ÀÀׯ÷
FLT 35-260   ·ÆÄá¿Ë˹·ÀÀׯ÷
FLT-PLUSCTRL-2.5/I  ·ÆÄá¿Ë˹·ÀÀׯ÷
FLT-CP-3S-350 ·ÆÄá¿Ë˹µçÓ¿±£»¤
PLC-RSC-24DC/21 ·ÆÄá¿Ë˹¼ÌµçÆ÷
PLC-RSP-24DC/21 ·ÆÄá¿Ë˹¼ÌµçÆ÷
PLC-RSC-24UC/21 ·ÆÄá¿Ë˹¼ÌµçÆ÷
PLC-RSC-24DC/21-21 ·ÆÄá¿Ë˹¼ÌµçÆ÷
PLC-RSC-24DC/1/ACT ·ÆÄá¿Ë˹¼ÌµçÆ÷
PLC-OSC-24DC/48DC/100 ·ÆÄá¿Ë˹¼ÌµçÆ÷
REL-MR-24DC/21   ¿É²å°Îµ¥¸ö¼ÌµçÆ÷
REL-MR-24DC/21AU ¿É²å°Îµ¥¸ö¼ÌµçÆ÷
REL-MR-24DC/21-21 ¿É²å°Îµ¥¸ö¼ÌµçÆ÷
REL-MR-60DC/21 ¿É²å°Îµ¥¸ö¼ÌµçÆ÷
PLC-BSC-24DC/21 ¼ÌµçÆ÷µ××ù
PLC-BSC-230UC/21 ¼ÌµçÆ÷µ××ù
PLC-BSC-24DC/21-21 ¼ÌµçÆ÷µ××ù
OPT-24DC/24DC/2 ¿É²å°Îµ¥¸ö¼ÌµçÆ÷
OV-24DC/480AC/5 ·ÆÄá¿Ë˹¹Ì̬¼ÌµçÆ÷
PLC-RSC-230UC/21 ·ÆÄá¿Ë˹¼ÌµçÆ÷
PLC-ESK GY ·ÆÄá¿Ë˹µçÔ´¶Ë×Ó
EMD-FL-V-300 ¼àÊӼ̵çÆ÷
DEK-REL-G24/21 ¼ÌµçÆ÷Ä£¿é
ETD-SL-1T-DTF ¿Éµ÷¶¨Ê±¼ÌµçÆ÷
EMG 17-OV-24DC/60DC/3 ·ÆÄá¿Ë˹¼ÌµçÆ÷¹âñî
PSR-SPP-24UC/URM4/5X1/2X2/B ¼±Í£¼ÌµçÆ÷-Ä£¿é
PSR-SCP-24UC/ESAM4/8X1/1X2 Í¨µÀ¼±Í£¼ÌµçÆ÷
PSR-SCP-24UC/ESM4/2X1/1X2 °²È«¼ÌµçÆ÷
PSR-SCP-24UC/ESA4/2X1/1X2 °²È«¼ÌµçÆ÷
PSR-SCP-24-230UC/ESAM4/3X1/1X2 °²È«¼ÌµçÆ÷
PSI-REP-PROFIBUS/12MB ·ÆÄá¿Ë˹ÖÐ¼ÌÆ÷
PSI-MOS-PROFIB/FO 850 T ·ÆÄá¿Ë˹ת»»Æ÷
MCR-CPS-I-I-44-E ·ÆÄá¿Ë˹¸ôÀëÆ÷
MCR-C-UI-UI-DCI ·ÆÄá¿Ë˹¸ôÀëÆ÷
MCR-C-UI-UI-DCI-NC ·ÆÄá¿Ë˹¸ôÀëÆ÷
MCR-2CLP-I-I-00 ·ÆÄá¿Ë˹¸ôÀëÆ÷
MCR-SL-S-16-SP-24 ·ÆÄá¿Ë˹½Ó´¥Æ÷
MINI MCR-SL-PTB ·ÆÄá¿Ë˹µçÔ´Ä£¿é
MINI MCR-SL-I-I ·ÆÄá¿Ë˹·Å´óÆ÷
MINI MCR-BL-I-I ·ÆÄá¿Ë˹·Å´óÆ÷
MINI MCR-SL-RPS-I-I ·ÆÄá¿Ë˹¸ôÀëÆ÷
MINI MCR-BL-RPS-I-I ·ÆÄá¿Ë˹¸ôÀëÆ÷
MINI MCR-SL-UI-2I-NC ·ÆÄá¿Ë˹±¶ÔöÆ÷
MINI MCR-SL-PT100-UI ·ÆÄá¿Ë˹αäÆ÷
MINI MCR-SL-PT100-UI-NC ·ÆÄá¿Ë˹αäÆ÷
MINI MCR-SL-1CP-I-I ·ÆÄá¿Ë˹¸ôÀëÆ÷
MACX MCR-SL-CAC-5-I ·ÆÄá¿Ë˹±äËÍÆ÷
MACX MCR-SL-CAC-5-I-UP ·ÆÄá¿Ë˹±äËÍÆ÷
UM 45-FLKS50 ·ÆÄá¿Ë˹ģ¿é
UMK-32 RM/MR-G24/1/PLC VARIOFACEÊä³öÄ£¿é
ILB BT ADIO MUX-OMNI ·ÆÄá¿Ë˹ÎÞÏßÄ£¿é
ILB S3 AI4 AO2-2TX ·ÆÄá¿Ë˹IOÄ£¿é
ILB BT ADIO MUX-OMNI 4 ÎÞÏßÊäÈëÊä³öÄ£¿é
ILB IB 24 DI16 DO16 ÎÞÏßÊäÈëÊä³öÄ£¿é
ILB IB 24 DI32 ·ÆÄá¿Ë˹ÊäÈëÄ£¿é
ILB IB 24 DO16-DSUB IOÊý×ÖÊä³öÄ£¿é
IB IL TEMP 2 RTD-PAC ·ÆÄá¿Ë˹ģ¿é
IL DN BK3-PAC ·ÆÄá¿Ë˹×ÜÏßñîÈ«Æ÷
IB IL 24 TC-PAC ·ÆÄá¿Ë˹ģ¿é
IB IL AO 2/SF-PAC ·ÆÄá¿Ë˹ģ¿é
IB IL 24 SEG/F-D-PAC    ·ÆÄá¿Ë˹ģ¿é
IB IL 24 DI 32/HD-2MBD-PAC   ·ÆÄá¿Ë˹ģ¿é
FLS PB M12 DI 8 M12   ·ÆÄá¿Ë˹ģ¿é
FLS PB M12 DIO 8/8 M12 ·ÆÄá¿Ë˹ģ¿é
IBS STME 24 BK RB-T ·ÆÄá¿Ë˹ģ¿é
RAD-ISM-2400-ANT-VAN- 3-1-MCX ·ÆÄá¿Ë˹ÌìÏß
FL SWITCH MM HS ·ÆÄá¿Ë˹½»»»»ú
FL SWITCH SF 8TX ·ÆÄá¿Ë˹½»»»»ú
FL SWITCH SFNB 8TX ·ÆÄá¿Ë˹½»»»»ú
FL SWITCH SF 6TX/2FX ·ÆÄá¿Ë˹½»»»»ú
FL SWITCH SFN 6TX/2FX ·ÆÄá¿Ë˹½»»»»ú
FL SWITCH MCS 14TX/2FX ·ÆÄá¿Ë˹½»»»»ú
FL SWITCH SF 16TX ·ÆÄá¿Ë˹½»»»»ú
FL SWITCH SF 15TX/FX ·ÆÄá¿Ë˹½»»»»ú
FL SWITCH LM 4TX/2FX ·ÆÄá¿Ë˹½»»»»ú
ELR W3-24DC/500AC- 2I   ·ÆÄá¿Ë˹½Ó´¥Æ÷
SACB-8/16-10,0HPUR SCO ·ÆÄá¿Ë˹´«¸ÐÆ÷
SACB-8/ 8-L-SC NPN ·ÆÄá¿Ë˹´«¸ÐÆ÷
SAC-4P-10,0-PUR/M12FR ´«¸ÐÆ÷Ö´ÐÐÆ÷µçÀÂ
SZF 1-0,6X3,5 ·ÆÄá¿Ë˹һ×ÖÂÝË¿µ¶
SZF 2-0.8*4.0 ·ÆÄá¿Ë˹һ×ÖÂÝË¿µ¶
SZF 3-1,0X5,5 ·ÆÄá¿Ë˹һ×ÖÂÝË¿µ¶
SZS 1.0*4.0 VDE Ò»×ÖÂÝË¿µ¶-¾øÔµ
SZS 0,6X2,5 VDE   Ò»×ÖÂÝË¿µ¶-¾øÔµ
SZK PH0 VDE Ê®×ÖÂÝË¿µ¶ÏµÁÐ
SZK PH1 VDE Ê®×ÖÂÝË¿µ¶ÏµÁÐ
SZK PH2 VDE Ê®×ÖÂÝË¿µ¶ÏµÁÐ
SHN 5.5 ·ÆÄá¿Ë˹Ì×Ͳ°âÊÖ
UNIFOX-C VDE (¸ÖË¿)×éºÏǯ
CUTFOX-S VDE ·ÆÄá¿Ë˹¼â×ìǯ
CUTFOX FB ·ÆÄá¿Ë˹ÇÐÏßǯ
CUTFOX 35 ·ÆÄá¿Ë˹ÇÐÏßǯ
WIREFOX 2,5   ·ÆÄá¿Ë˹°þÏßǯ
CRIMPFOX 10S  ·ÆÄá¿Ë˹ѹ½Óǯ
CRIMPFOX 6H ·ÆÄá¿Ë˹ѹ½Óǯ
UK5N ·ÆÄá¿Ë˹¶Ë×Ó
UK6N ·ÆÄá¿Ë˹¶Ë×Ó
UK2.5B ·ÆÄá¿Ë˹¶Ë×Ó
URTK/S ·ÆÄá¿Ë˹¶Ë×Ó
SB 2-RTK/S ¿ª¹ØÇŽӼþ
MBKKB 2.5 ·ÆÄá¿Ë˹¶Ë×Ó
E/UK Öն˽ô¹Ì¼þ
D-UK 4/10 ·ÆÄá¿Ë˹¶Ë°å
ATP-UK ·ÆÄá¿Ë˹¸ô°å
FBI 10-6 ·ÆÄá¿Ë˹ÇŽӼþ
FBI 10-8 ·ÆÄá¿Ë˹ÇŽӼþ
ZB±êʶÌõ(¿É¸ù¾Ý¿Í»§ÒªÇó´òÓ¡) ·ÆÄá¿Ë˹¶Ë×Ó±ê¼ÇÌõ
ABB¶Ë×ÓM4/6 ABB½ÓÏß¶Ë×Ó
ABB¶Ë×ÓM6/8 ABB½ÓÏß¶Ë×Ó
M4/6¡¢M6/8Öն˹̶¨Æ÷BAM2 Öն˹̶¨Æ÷
M4/6¡¢M6/8¶Ë×Ӷ˰åFEM6   ABB¶Ë°å
κµÂÃ×ÀÕ¶Ë×ÓSAKϵÁРȫϵÁÐÌØ¼Û
ͨ·ç¹ýÂËÍø£¨×飩 FU-9803A£¨C£©
ͨ·ç¹ýÂËÍø£¨×飩 FU-9804A£¨C£©
ͨ·ç¹ýÂËÍø£¨×飩 FU-9805A£¨C£©
ͨ·ç¹ýÂËÍø£¨×飩 FU-9806A£¨C£©
¿¨¹Ì·ç»ú(º¬ÓÍÖá³Ð´ø¶ËÍ·²åƬ) KA1238HA2S
¿¨¹Ì·ç»ú(¹öÖéÖá³Ð´ø¶ËÍ·²åƬ) KA1238HA2B
¿¨¹Ì·ç»ú¹öÖéÖá³Ð180*180*65MM KA1806HA2B
¿¨¹Ì·ç»ú(º¬ÓÍÖá³Ð´ø¶ËÍ·²åƬ) KA1725HA2S
¿¨¹Ì·ç»ú(¹öÖéÖá³Ð´ø¶ËÍ·²åƬ) KA2206HA2-2
¿¨¹Ì·ç»ú220V/222mm*222mm*80mm KA2208HA2-2
¿¨¹Ì·ç»ú220V/222mm*222mm*80mm KA2208HA2-4
¿¨¹Ì·ç»ú(º¬ÓÍÖá³Ð´ø¶ËÍ·²åƬ) KA2509HA2-4
ÆäËüÐͺÅÌØ¼ÛÇë×Éѯ
¹«Ë¾Ãû³Æ£º ÏÃÃŷƹÌ×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾
µç »°£º 0592 8225651 / °¬ÌìÃ÷
ÊÖ»ú£º 13459211367
µØ Ö·£º ¸£½¨Ê¡ÏÃÃÅÊкþÀïÇø³¤°¶Â·92ºÅ1004ÊÒ
ÓÊ ±à£º 361000
Ö÷ Ò³£º http://www.xmfeigu.cn
  • PHOENIX·ÆÄá¿Ë˹¹¤¾ßCRIMPFOX UD 6-6
  • ·ÆÄá¿Ë˹µçÔ´TRIO-PS/1AC/24DC/10
  • ·ÆÄá¿Ë˹ÒÔÌ«Íø½»»»»úFL SWITCH SFNB 8TX
  • ÏÖ»õÌØ¼Û·ÆÄá¿Ë˹µçÔ´QUINT-PS-3X400-500AC/24DC/40
  • ·ÆÄá¿Ë˹ӡˢµç·Á¬½ÓÆ÷
  • ·ÆÄá¿Ë˹ӡˢÏß·°åÁ¬½ÓÆ÷
  • ·ÆÄá¿Ë˹COMBICONÓ¡Ë¢Ïß·°åÁ¬½Ó¶Ë×Ó
  • ·ÆÄá¿Ë˹һÌ廯ģ¿é
  • ·ÆÄá¿Ë˹ģ¿éFLS
  • ·ÆÄá¿Ë˹Phoenix½»»»»úFL
