2736013 FLS IB M12 DI 8 M12
ÓÃÓÚINTERBUSµÄÒ»Ì廯ģ¿é´øÓÐ8¸öÊý×Ö»¯ÊäÈë¡£ M12µÄÁ¬½ÓʹÓÃÁË¿ìËÙÁ¬½Ó¼¼Êõ¡£ 24 V DCµÄµçÔ´ÓÃÓÚ·ÀÖ¹¶Ì·ºÍ¹ýÔØ¡£ É豸µÄ¶î¶¨µçÁ÷Ϊ600 mA¡£
2736026 FLS IB M12 DIO 4/4 M12-2A
ÓÃÓÚINTERBUSµÄÒ»Ì廯ģ¿é´øÓÐ4¸öÊý×Ö»¯ÊäÈëºÍ4¸öÊý×Ö»¯Êä³ö£¬Ã¿¸öµÄ¸ºÔØÄÜÁ¦Îª2 A¡£M12µÄÁ¬½ÓʹÓÃÁË¿ìËÙÁ¬½Ó¼¼Êõ¡£ 24 V DCµÄµçÔ´ÓÃÓÚ·ÀÖ¹¶Ì·ºÍ¹ýÔØ¡£
2736039 FLS IB M12 DO 8 M12-2A
ÓÃÓÚINTERBUSµÄÒ»Ì廯ģ¿é´øÓÐ8¸öÊý×Ö»¯ÊäÈ룬ÿ¸öµÄ¸ºÔØÄÜÁ¦Îª2 A¡£M12µÄÁ¬½ÓʹÓÃÁË¿ìËÙÁ¬½Ó¼¼Êõ¡£ 24 V DCµÄµçÔ´ÓÃÓÚ·ÀÖ¹¶Ì·ºÍ¹ýÔØ¡£
2736204 FLS IB M12 DIO-SAMPLE
·ÆÄá¿Ë˹Phoenix½»»»»úFL SWITCH SF ²úÆ·
ÒÔÌ«Íø½»»»»ú£¬14¸öTP RJ45¶Ë¿Ú£¬2¸öFO¶Ë¿Ú£¬100 Mbit/sȫ˫¹¤£¬SC-D¸ñʽ£¬10»ò100 Mbit/s£¨RJ45£©Êý¾Ý´«ÊäËÙÂÊ×Ô¶¯¼ì²â£¬×Ô¶¯½»²æ¡£
½Ó¿Ú1 ÒÔÌ«Íø£¨RJ45£©
¶Ë¿ÚÊý 14 (RJ45¶Ë¿Ú)
Á¬½ÓÀàÐÍ RJ45
Á¬½Ó·½·¨·½ÃæµÄ×¢ÒâÊÂÏî ×ÔÊÊÓ¦ºÍ×Ô½»²æ
´«ÊäÔÀí ÒÔÌ«ÍøRJ45Ë«½ÊÏß
´«ÊäËÙ¶È 10/100 MBit/s
´«Ê䳤¶È 100 m (ÿ¸ö·Ö¶Î)
ÐźÅLED Êý¾Ý½ÓÊÕ£¬Á´½Ó״̬
½Ó¿Ú2 ¹âÏ˽ӿÚ
¶Ë¿ÚÊý 2 (FO¶Ë¿Ú)
Á¬½ÓÀàÐÍ SC
ÏÃÃŷƹÌ×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾Î»ÓÚ¾¼ÃÌØÇø¸£½¨Ê¡ÏÃÃÅÊУ¬ÊÇÒ»¼Ò¼¯Éú²ú¼Ó¹¤¡¢¾ÏúÅú·¢ÎªÒ»Ìå¡¢¾¹ú¼ÒÏà¹Ø²¿ÃÅÅú×¼×¢²áµÄÆóÒµ¡£ÒÔ³ÏОӪºÍ±¡Àû¶àÏúµÄÔÔò£¬Ó®µÃÁ˹ã´ó¿Í»§µÄÐÅÈΣ¬Èȳϻ¶Ó¸÷½çÅóÓÑǰÀ´²Î¹Û¡¢¿¼²ì¡¢Ç¢Ì¸ÒµÎñ¡£
²úƷͼƬ¡¢¼Û¸ñ¡¢²úÆ·ÊôÐÔµÈ×ÊÁÏ£¬½ö¹©²Î¿¼£¬¾ßÌåÒÔѯ¼ÛʱΪ׼£¬ÈçÐèÏêϸ¼¼Êõ×ÊÁÏÇëÁªÂ磬»¶ÓÔÚÏß»òÀ´µç×Éѯ¡¡
ÏÃÃŷƹÌ×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾>
Phoenix·ÆÄá¿Ë˹ȫϵÁвúÆ·>
KAKU ¿¨¹Ì·ç»úͨ·ç¹ýÂËÍø×é>
ÏúÊÛ·ÆÄá¿Ë˹µçԴȫϵÁС¢ILB I/OÎÞÏßÄ£¿é¡¢ÊäÈëÊä³öÄ£¿éϵÁС¢´«¸ÐÆ÷¡¢¼ÌµçÆ÷¡¢MINI MCRÐźŸôÀëÆ÷¡¢MACX±¶Ôö·Å´óÆ÷¡¢½Ó´¥Æ÷¡¢×ª»»Æ÷¡¢ÒÔÌ«Íø½»»»»ú¡¢¶Ë×Ó¡¢Ñ¹½ÓÇÐÏßǯCRIMPFOXϵÁС¢°þÏßǯWIREFOXϵÁС¢ÂÝË¿µ¶¹¤¾ß¡¢ÀËÓ¿±£»¤·ÀÀׯ÷¡¢COMBICONÓ¡Ë¢Ïß·°åÁ¬½Ó¶Ë×Ó¡¢×Ô¶¯»¯²úÆ·£»KAKU¿¨¹Ì·ç»úͨ·ç¹ýÂËÍø×飻ʩÄ͵Â140ϵÁÐPLC¡¢ÃÀ¹úA-B PLCϵÁУ¬ABB¶Ë×ÓM4/6¡¢M6/8¼°Öն˹̶¨Æ÷BAM2¡¢¶Ë°åFEM6£¬ÎºµÂÃ×ÀÕ¶Ë×ÓSAKϵÁУ¬¹«Ë¾×Ô²úµ¼¹ì(NSϵÁУ¬Ö´ÐÐÅ·ÖÞÉú²ú¹¤ÒÕˮƽ£©¡£
PHONEIX CONTACT·ÆÄá¿Ë˹QUINTµçԴȫϵÁÐÌØ¼Û
COMBICONÓ¡Ë¢Ïß·°åÁ¬½Ó¶Ë×ÓȫϵÁÐÌØ¼Û
·ÆÄá¿Ë˹Phoenix½»»»»úFL SWITCH 4TX/FX
·ÆÄá¿Ë˹Phoenix½»»»»úFL SWITCH 8TX
·ÆÄá¿Ë˹Phoenix½»»»»úFL SWITCH MM HS
·ÆÄá¿Ë˹Phoenix½»»»»úFL SWITCH SF 14TX/2FX
·ÆÄá¿Ë˹Phoenix½»»»»úFL SWITCH MCS 16TX
FL SWITCH MCS 14TX/2FX
FL SWITCH SF 8TX
FL SWITCH SF 6TX/2FX
FL SWITCH SFN 5TX
FL SWITCH SFN 4TX/FX
FL SWITCH SFN 6TX/2FX
2832551 FL HUB 8TX-ZF
2832564 FL HUB 16TX-ZF
2832810 FL SWITCH 4TX/FX
2832085 FL SWITCH 5TX
2832218 FL SWITCH 8TX
2832593 FL SWITCH SF 14TX/2FX
2832661 FL SWITCH SF 15TX/FX
2832726 FL SWITCH SF 7TX/FX
2832771 FL SWITCH SF 8TX
2832849 FL SWITCH SF 16TX
2832933 FL SWITCH SF 6TX/2FX
2832577 FL SWITCH SF 7TX/FX ST
2832603 FL SWITCH SF 4TX/3FX ST
2832674 FL SWITCH SF 6TX/2FX ST
2832328 FL SWITCH MM HS
2832331 FL MXT
2832522 FL SWITCH MM HS/M
2832535 FL MXT/M
2832344 FL IF 2TX VS-RJ-F
2832357 FL IF 2TX VS-RJ-D
2832742 FL IF 2HCS 100-D
2832852 FL IF 2POF 10/100-D
2832412 FL IF 2FX SC-F
2832425 FL IF 2FX SC-D
2832205 FL IF 2FX SM SC-D
2884033 FL IF 2FX ST-D
2832739 FL IF TX/HCS 100-D
2832807 FL IF TX/POF 10/100-D
2832470 FL CB IF
2832483 FL IF MEM 2TX-D
2832904 FL IF 2PSE-F
2832700 FL SWITCH MCS 16TX
2832713 FL SWITCH MCS 14TX/2FX
2832111 FL PN/IBS
2744490 FL COM SERVER RS232
2708740 FL COM SERVER RS485
2313041 FL COM SERVER RS232 PRO
2313054 FL COM SERVER RS485 PRO
2831060 FL IBS SC/I-T
2862327 FL IL 24 BK-B-PAC
2862314 FL IL 24 BK-PAC
2878816 FL IL 24 BK-PN-PAC
2863986 FL IL 24 BK ETH/IP-PAC
2831044 FL SWT
2832166 FL SNMP OPC SERVER
2832179 FL OPC SNMP AGENT
2708193 FL MC 10/100BASE-T/FO-660
2744513 FL MC 10BASE-T/FO POF
2744788 FL MC 10BASE-T/FO G850
2708164 FL MC 10/100BASE-T/FO G1300
2708986 FL MC 10/100 BASE-T/FO G1300ST
2708177 FL MC 10/100BASE-T/FO G1300 SM
2891851 FL SWITCH SFN 4TX/FX
2891453 FL SWITCH SFN 4TX/FX ST
2891152 FL SWITCH SFN 5TX
2891929 FL SWITCH SFN 8TX
2832250 FL CAT5 PATCH 0,3
2832263 FL CAT5 PATCH 0,5
2832276 FL CAT5 PATCH 1,0
2832221 FL CAT5 PATCH 1,5
2832289 FL CAT5 PATCH 2,0
2832292 FL CAT5 PATCH 3,0
2832580 FL CAT5 PATCH 5,0
2832616 FL CAT5 PATCH 7,5
2832629 FL CAT5 PATCH 10,0
2744814 FL CAT5 HEAVY
2744827 FL CAT5 HEAVY CONF/
2744830 FL CAT5 FLEX
2744843 FL CAT5 FLEX CONF/
2744856 FL PLUG RJ45 GR/2
2744571 FL PLUG RJ45 GN/2
2744869 FL CRIMPTOOL
2744610 FL CAT5 TERMINAL BOX
2832991 FL RJ45 PROTECT CAP
2832496 FL PBX 8TX
2832506 FL PBX 6TX/4FX
2832865 FL SEC PAC 4TX
2832687 FL PF SEC 2TX
2832690 FL PF SEC 8TX
2891165 FL PF 2TX CAT5E
2891068 FL PF 2TX CAT 6
2891071 FL PF 8TX CAT 6
2891178 FL PF 8TX CAT5E
·ÆÄá¿Ë˹·Ö²¼Ê½I/OÄ£¿é
2736042 FLS DN M12 DIO 4/4 M12-2A
2736055 FLS DN M12 DO 8 M12-2A
2736068 FLS DN M12 DI 8 M12
2736071 FLS CO M12 DIO 4/4 M12-2A
2736084 FLS CO M12 DO 8 M12-2A
2736097 FLS CO M12 DI 8 M12
2736107 FLS PB M12 DIO 4/4 M12-2A
2736110 FLS PB M12 DO 8 M12-2A
2736123 FLS PB M12 DI 8 M12
2736220 FLS PB M12 DI 16 M12
2736314 FLS IB M12 DI 16 M12
2736327 FLS DN M12 DI 16 M12
2736372 FLS PB M12 DIO 8/8 M12
2736385 FLS IB M12 DIO 8/8 M12
2736398 FLS DN M12 DIO 8/8 M12
2736479 FLS CO M12 DI 16 M12
2736482 FLS CO M12 DIO 8/8 M12
·ÆÄá¿Ë˹Phoenix¹âµçת»»Æ÷PSI-MOS-PROFIB/FO 850 E
·ÆÄá¿Ë˹Phoenix½Ó¿Úת»»Æ÷PSM-ME-RS232/RS485-P
·ÆÄá¿Ë˹PhoenixÖÐ¼ÌÆ÷PSM-ME-RS485/RS485-P
·ÆÄá¿Ë˹Phoenix´®ÐÐÉ豸·þÎñÆ÷FL COM SERVEN RS232
·ÆÄá¿Ë˹Phoenix¹¤ÒµÄ£ÄâMODEM£ºPSI-DATA/FAX-MODEM/RS232
·ÆÄá¿Ë˹PhoenixÀ¶ÑÀת»»Æ÷£ºPSI-WL-RS232-RS485/BT
·ÆÄá¿Ë˹PhoenixÀ¶ÑÀÊÊÅäÆ÷PSI-WL-PLUG-RS232/BT
·ÆÄá¿Ë˹RS-232µçÀ£ºPSM-KA-9SUB25/BB/2 METER
·ÆÄá¿Ë˹ÖÕ¶ËÄ£¿é£ºPSI-MOS-RS232/FO 660 E
·ÆÄá¿Ë˹TÐÍÄ£¿é:PSI-MOS-RS232/FO 660 T
·ÆÄá¿Ë˹ϵͳµçÔ´£ºMINI-SYS-PS-100-240AC/24DC/1.5
·ÆÄá¿Ë˹PhoenixÈ«ÏòÌìÏߣºRAD-ISM-2400-ANT-OMNI-2-1
RAD-ISM-2400-ANT-OMNI-9-0
·ÆÄá¿Ë˹Phoenix¶¨ÏòÌìÏߣºRAD-ISM-2400-ANT-PAN-8-0
·ÆÄá¿Ë˹PhoenixË«ÏòÎÞÏß´«Êäϵͳ£ºRAD-ISM-2400-SET-BD-BUS-ANT
·ÆÄá¿Ë˹Phoenixµ¥ÏòÎÞÏß´«Êäϵͳ£ºRAD-ISM-2400-SET-UD-ANT
·ÆÄá¿Ë˹PhoenixñîºÏI/OÄ£¿éIB IL BK-PLSET/CP
IBS STME 24 BK DIO 8/8/3-LK
IBS STME 24 BK DIO 8/8/3-T
IBS STME 24 BK RB-LKDIO8/8/3LK
IBS STME 24 BK RB-T DIO8/8/3LK
IBS STME 24 BK RB-T
IB IL 24 PWR IN/2-F-D-PAC
IBS CT 24 IO GT-LK-OPC
IBS IL 24 BK RB-LK-PAC
IBS OPTOSUB-MA/M/L-LK-OPC
IBS RL 24 DI 16/8-LK
IBS RL 24 DIO 8/8/8-LK
IBS RL 24 DO 16/8-R-LK
IBS RL PLUG-LK/POF
PSM-LWL-KDHEAVY-980/1000
PSI-MOS-PROFIB/FO 850 T
PSI-MOS-RS485W2/FO 850 T
IB IL MUX-CAB PSI
IB IL SCN-12-OCP
IB IL SCN-6 SHIELD
IB IL SCN-8-CP
IB IL TEMP 2 RTD
IB IL 400 ELR R-3A
IB IL 24 PWR IN/2-F
IB IL 230 PWR IN
IB STME 24 AO 4/SF4
IB STME 24 DO 8/3-2A
IB STME 24 DIO 8/8R/3
IBS STME 24 BK-LK
IBS ST 24 BKM-T
ILB BT ADIO MUX-OMNI
IL PB BK DP/V1-PAC
IL PB BK DP/V1
IB IL 24 DI 8
IB IL 24 DI 4-PAC
IB IL TEMP 2 RTD-PAC
IB IL 24 SEG/F-PAC
IB IL AI 2/SF-PAC
IB IL AO 1/SF-PAC
IB IL 24 PWR IN/F-PAC
FLKMS-D50 SUB/B
FLKM 50/32M/PLC
FLKM 50/32M/SI/PLC
FLKM 50-PA-AB/1756 IN
FLK-D37 SUB/B
IB IL AI 2/SF
IB ST 24 AI 4/SF
IB ST ZF 24 AO 4/BP
IB ST 24 AO 4/BP
IBS ST 24 BK-T
IBS MC FLASH 4MB
IBS MC FLASH 2MB
IB ST 24 AO 4/SF
IB ST 230 DI 16/3
IBS OPTOSUB-MA/M/R-LK-OPC-2MBD
IB IL 24 SEG/F-D
IB STME 24 AI 4/SF
IB STME 24 AO 4/SF
IBS STME 24 BK-T
IBS S7 300 DSC-T
IBS RBC METER-T
FLM BK PB M12 DI 8 M12
FLM AO 4 SF M12
FLM DI 8 M12
IB IL 400 ELR R-3A
IB IL AI 8/SF
IB IL 24 DI 2-PAC
IB IL AO 2/U/BP
IB IL AO 4/8/U/BP
IBS IL 24 BK-T/U
FLS IB M12 DI 8 M12
ILB IB 24 DI16
IBS PC ISA SC/I-T
IB ST 24 DI32/2
IB ST 24 DO32/2
IB ST 24 DI 16/4
IB ST 24 DO16/3
ILB IB 24 DI16 DO16
RAD-IN+OUT-2D-1A-1
PLC-RSC-230UC/21-21/SO46
IB IL SCN-12-ICP
IB IL SCN-12-OCP
IB IL SCN-6 SHIELD
IL PB BK DP/V1-PAC
IB IL 24 DI 4-PAC
IB IL 24 SEG/F-PAC
IB IL AI 2/SF-PAC
IB IL AO 1/SF-PAC
IB IL AI 2/SF
FL COM SERVER RS232
SAC-2P-M12MSB/ 2,0-910/M12FSB
IB IL TEMP 2 RTD
IBS ST 24 BK-T
IF 2FX SM SC-DJ
FL IF 2TXVS-RI-D
FLM DI 8 M12
IB IL AO 2/U/BP
IBS IL 24 BK-T/U
IBS S5 DSC/I-T
FLS IB M12 DI 8 M12
ILB IB 24 DI16
IBS PC ISA SC/I-T
IB ST 24 DI 16/4
IB ST 24 DO16/3
ILB IB 24 DI16 DO16
SUBCON-PLUS-PROFIB/SC2
SAC-4P-M12Y/2X0,3-PUR/M12FS VP
IBS RT PLSET SMSTB
VC-M3/4M
FLKM 50/PLC ÖÕ¶ËÄ£¿é2285690 IBS ISA STAND Á¬½ÓÆ÷
FLKM 40-PA-MA12/S100
FLKMS-D25 ½Ó¿ÚÁ¬½ÓÆ÷
FLKM4X14PAMA12S100 FLKM4X14-PA-MA12/S100 Á¬½ÓÆ÷
S135
FLKM 50 Á¬½ÓÆ÷ for S5-115
Á¬½ÓÆ÷2294500 FLKM-50-PA-S400 FLKM 50-PA-S400 Á¬½ÓÆ÷
FLKPVB224 FLK-PVB 2/24 ½ÓÏߺÐ
IB IL 24 PWR IN/R/L-0.8A-PAC ¼ÌµçÆ÷ÊäÈëÄ£¿é
IB IL 24 PSDOR 4-F-PAC Êý×ÖϽµÊä³öÄ£¿é
PSI-DATA/FAX-MODEM/RS232 Êý¾Ýµ÷ÖÆ½âµ÷Æ÷Ä£¿é
IB IL 24 MUX MA
IBS PLC5 DSC/I-T ½Ó¿ÚÄ£¿é
IBS PC ISA SC/I-T ½Ó¿ÚÄ£¿é
IBS CT 24 IO GT-T ñîºÏÄ£¿é
IBS CT 24 IO GT-LK ñîºÏÄ£¿é
IB STME 24 AI4/1 Ä£ÄâÁ¿ÊäÈëÄ£¿é
IBS S5 100 SL-T 24VDC Öն˰å
IBS S7 300 DSC-T
IBS SAB 24 DIO 8/4/4 Êý×ÖÀïÊäÈëÊä³öÄ£¿é
IB STME 24 BAI 8/U; 9283129, 2721219Ä£ÄâÁ¿ÊäÈëÄ£¿é
IB ST 24 DO16R/S
IB STME 24 DO16R/S ¼ÌµçÆ÷Êä³öÄ£¿é
IB STME 24 BAI 8/U, 9283129 Ä£ÄâÁ¿ÊäÈëÄ£¿é
IBS S7 300 BC-T Öն˰å
IBS ISA FC/I-T ¿ØÖÆÆ÷Ä£¿é
IES ISA FC/486DX/I-T ¿ØÖÆÆ÷Ä£¿é
IBS VME3H SC/I-T
IBS 24 ETH DSC/I-T
IBS 24 RFC/486 DX/ETH-T Ô¶³¡¿ØÖÆÆ÷
IBS IP 24 V-24 ´®ÐÐͨÐÅÄ£¿é
IBS RT 24 DIO 16/ 8-2A-T Êý×ÖÁ¿I/OÄ£¿é
IB ST ZF 24 BDO 8/3-V3
IB STME 24BDI 16/4-V3 Êý×ÖÁ¿ÊäÈëÄ£¿é
IB STME 24 AO4/SF4-V3; 2750581; 9356137 Ä£ÄâÁ¿Êä³öÄ£¿é
IBS RL DIO 8/8/8-LK Êý×ÖÁ¿I/OÄ£¿é
IBS RL 24 DI 16/8 LK Êý×ÖÊäÈëÉ豸
IB STME 24 UTH 8; 2724902; 9392214
IB ST 24 UTH 8 tÈȵçżģ¿é
IBS PC AT/SL/I-T
IBS STME 24BK RB-T DIO 8/8/3-LK
IBS IL 24 BK-LK ×ÜÏßñîºÏÆ÷
IB IL 24 DI 2 ǶÈëʽÊý×ÖÁ¿ÊäÈëÄ£¿é
IB IL 24 DI 8 Êý×ÖÁ¿ÊäÈëÄ£¿é
IB IL 24 DI 16
IB IL 24 DO 8 ǶÈëʽÊý×ÖÁ¿Êä³öÄ£¿é
IB IL 24 DO 16
IB IL AI 2/SF ǶÈëʽģÄâÁ¿Êä³öÄ£¿é
IB IL AO1/SF ǶÈëʽģÄâÁ¿Êä³öÄ£¿é
IB IL 24 PWR IN
IB IL 24 L2
IBS ST 24 BKM
IBS MC FLASH 2 MB
ILC 200 IB ǶÈë¿ØÖÆÆ÷Ä£¿é
IBS PCI SC/RI/I-T
IBS RL PLUG-LK/POF ¹âÏË×ÜÏß½ÓÍ·
IBS S7 400 ETH DSC/I-T
IBS RL AP °²×°Ö§¼Ü
IB ST 24 DI32/2-MB Êý×ÖÁ¿ÊäÈëÄ£¿é
IB STME 24 DI 32/2-MB Êý×ÖÁ¿ÊäÈëÄ£¿é
IBSLBOC24DIO224M122AD2 Êý×ÖÁ¿I/O Ä£¿é
IBS RL 24 DIO Êý×ÖÁ¿I/O Ä£¿é
IB L2 BOX 24 DI 8/4 M12 Êý×ÖÁ¿ÊäÈëÄ£¿é
IB L2 IP 500MLR 4-6A µç»úÆô¶¯Æ÷
IB L2 BOX 24 DI Êý×ÖÁ¿ÊäÈëÄ£¿é
IB L2 BOX 24 DIO2/2/4 ÊäÈë/Êä³öÄ£¿é
IBS RL 24 DIO 8/8/8-R-LK Êý×ÖÁ¿I/O Ä£¿é
ASI IO SV DIO 4/3 AB ASI I / OÄ£¿é
IB IL 24 DO 2 ǶÈëʽÊý×ÖÁ¿Êä³öÄ£¿é
IBS RBC-T µçÀÂ
ASI IO PL DI 4/4 Êý×ÖÁ¿I/O Ä£¿é
IBS IL 24 BK-T/U ×Üվģ¿é
IBS CT 24 IO GT-LK-OPC ñîºÏI/O Ä£¿é
IB IL 24 PWR IN/P ǶÈëʽµçÔ´¶Ë×Ó
IB ST 24 AO 4/SF4, 2750578; 2750581 Ä£ÄâÁ¿Êä³öÄ£¿é
IB STME 24 AI 4/SF4; 2750565; 9283129 Ä£ÄâÁ¿ÊäÈëÄ£¿é
IBS OPTOSUB-MA/M/R-LK ÊÊÅäÆ÷
IB STME 24 PT 100 4/4; 2752767; 9283187 RTDÊäÈëÄ£¿é
IBS ST24 BKM-T 24VDC
IB STME 24 BDI 16/4, 9281956; 2751687
IB STME 24 AO4/BP +/-10V
IBS RC 4M µçÀÂ
IBS RT 24 BK RB-T ×Üվģ¿é
IB STME 24 AI 4/SF4;9283129, 2750060
IB ST 24 AO 4/SF4; 2750057; 9243826 Ä£ÄâÁ¿Êä³öÄ£¿é
IB ST ZF 24 AO. 2750057; 2724630; 9356137 Ä£ÄâÁ¿Êä³öÄ£¿é
IB ST ZF 24 DO32/2
IB ST ZF 24 DI32/2, 2754985,9282777 IBSTZF24DI32/2
IB ST ZF 24 BDO 32/2; 9282748; 2751713 Êý×ÖÁ¿Êä³öÄ£¿é
IBS ST ZF 24 BK-T; 9243949; 2754367 ×Üվģ¿é
IBS ST ZF 24 BK; 9282780; 2751221 Êý×ÖÁ¿I/OÄ£¿é
IB STME 24 BDO 32/2, 2751713, 9243868 Êý×ÖÁ¿Êä³öÄ£¿é
IBS CT PLSET FRONT-M Á¬½ÓÆ÷
IBS SAB 24 DIO 4/4/2 IBS SAB 24 DIO 4/4/2 Êý×ÖÁ¿I/OÄ£¿é
IBS SAB 24 DO Êý×ÖÁ¿Êä³öÄ£¿é
IBS ST 24 BKM-LK ×Üվģ¿é
IBS ST 24 BK DIO 8/8/3-LK, 2751221, 9282557Êý×ÖÁ¿I/OÄ£¿é
IBS STME 24 BK DIO 8/8/3-LK Êý×ÖÁ¿I/OÄ£¿é
IB STME 24 CNT ¼ÆÊýÆ÷Ä£¿é
IB STME 24 BDI 8/4 24VDC Êý×ÖÁ¿ÊäÈëÄ£¿é
IB STME 24 BDI 16/4 24VDC. 9281956, 2750170 Êý×ÖÁ¿ÊäÈëÄ£¿é
IB STME 24 BDO 8/3 24VDC Êý×ÖÁ¿Êä³öÄ£¿é
IB STME 24 BDO 16/3-250 24VDC Êý×ÖÁ¿Êä³öÄ£¿é
IB STME 24 BDO 32/2, 2750691,2750824 Êý×ÖÁ¿Êä³öÄ£¿é
IB STME 24 INC/2 µç×ÓÄ£¿é
IB ST 24 INC; 2751962, 928255 ¶¨Î»Ä£¿é
IBS ST 24 BK DIO 8/8/3-T: 2752961; 9282557 ×ÜÕ¾I/OÄ£¿é
IB ST 24 16/4-WT; 2755007 Êý×ÖÁ¿ÊäÈëÄ£¿é
IBS 24 BK I/O-FLK-T Êý×ÖÁ¿I / OÃæ°å
IBS RT 24 DI 32-T Êý×ÖÁ¿ÊäÈëÄ£¿é
IBS RT 24DO 32-T
IB STME 24 PT 100 4/4; 2750138; 9283187 RTD ÊäÈëÄ£¿é
IBS STME 24 BK RB-T; 2753504; 9282735×Üվģ¿é
IS STME 24 DIO 8/8/3-2A; 2753708 8/8 Êý×ÖÁ¿I/OÄ£¿é
IBS STME 24 BK DIO 8/8/3-T; 2752411; 9282557 Êý×ÖÁ¿I/OÄ£¿é
IBS RT 24 AIO 4/2-T Ä£ÄâÁ¿I/OÄ£¿é
IBS ST 24 BK LB-T; 9282735 ½ÓÏߺÐ
IBS ST 24 BK RB-T; 2752932; 9282735 ×Üվģ¿é
IBS SAB 24 DI Êý×ÖÁ¿ÊäÈëÄ£¿é
IBS RT 24DI /16-T
IBS RT 24 DIO 16/16-T Êý×ÖÁ¿I/OÄ£¿é
IBS RT 24 DIO 8/8R-T Êý×ÖÁ¿I/OÄ£¿é
IBS RBC RT-KONFEK-T µçÀÂ
IBS RT 24 DO 16-T Êý×ÖÁ¿Êä³öÄ£¿é
IB ST ASI DIO Êý×ÖÁ¿I/OÄ£¿é
IBS S5 100-CB-T ÖÕֹģ¿é
IB ST 24 DIO 8/8/3-2A Êý×ÖI / Oµ¥Î»
IB ST 24 AI 4/SF Ä£ÄâÁ¿ÊäÈëÄ£¿é
IB ST 24 AO 4/SF Ä£ÄâÁ¿Êä³öÄ£¿é
IB STME 24 DO 32/2 Êý×ÖÁ¿Êä³öÄ£¿é
IB ST 24 DI 16/4, 2754396, 9282382 Êý×ÖÁ¿ÊäÈëÄ£¿é
IBS ST 24 BK-T; 2754367; 9282803 ×Üվģ¿é
IB STME 24 AO 4/SF Ä£ÄâÁ¿Êä³öÄ£¿é
IB STME 24 BK-T; 2754341; 9282803 ×ÜÕ¾µç×ÓÄ£¿é
IB STME 24 DO 32/2
IBS STME 24 AI4/SF Ä£ÄâÁ¿ÊäÈëÄ£¿é
IB STME 24 DI 16/4 Êý×ÖÁ¿ÊäÈëÄ£¿é
IBSST24BK-LK IBS ST 24 BK-LK
IBSSTME24BK-LK IBS STME 24 BK-LK
IBS VME3H CB/I-T ¿ØÖÆÆ÷Ä£¿é
IB STME 24 DO 8/3-2A,, 2754972, 9289068 Êý×ÖÁ¿Êä³öÄ£¿é
IB ST 24 DO16/3; 2754943; 9243884 Êý×ÖÁ¿Êä³öÄ£¿é
IBST24DI32; 2754985; 9283103 IB ST 24 DI32/2
IB STME 24 DO 16/3; 2754914; 9243884 Êý×ÖÁ¿Êä³öÄ£¿é
IB ST 24 DO 8/3-2A, 2754891 Êý×ÖÁ¿Êä³öÄ£¿é
IB STME 24 DI 32/2; 2754927, 2750675 Êý×ÖÁ¿ÊäÈëÄ£¿é
IB STTB 24 DI16/4; 2752563 Êý×ÖÁ¿ÊäÈëÄ£¿é
IBS PC AT-T °å¿¨
IBS PC AT/I-T
IBS24BKLWLK IBS 24 BK-LWL-K
IBS24BK/LC2 ×Üվģ¿é
IBS AI 3/16 Ä£ÄâÁ¿Êä³öÄ£¿é
IBS PBC 50 IBS PBC 50 I/OµçÀÂ
IBS IP CDO 1/24-F Êý×ÖÁ¿Êä³öÄ£¿é
IBS 24 BK-I/O-T
PSM-EG-RS232/TTY-P/2K ½Ó¿Úת»»Æ÷
PSM-EG-RS232/RS422-P/4K ½Ó¿Úת»»Æ÷
PSM-EG-RS422/LWL-K ½ÓÏß¶Ë×Ó
PSM-EG-RS485/LWL-K ת»»Æ÷
PSM-EG-RS232/RS485-P/2D ´®ÐнӿÚÄ£¿é
PSM-EG-RS485-W2/FO-E/K ¹âÏËת»»Æ÷
SUBCON9/FSH Á¬½ÓÆ÷
SUBCON 15/M-SH Á¬½ÓÆ÷
SUBCON 25/M-SH Á¬½ÓÆ÷
PSM-EG-RS485W2/FO-E/G
MT-IBS-MUX
IBS AI 3 Ä£ÄâÁ¿ÊäÈëÄ£¿é
IBS 24 DO/R ¼ÌµçÆ÷Êä³öÄ£¿é
IBS S5 DAB
IBS S5 DAB/I
IBS 24 BK/LC
IBS 24 DO I Êý×ÖÁ¿Êä³öÄ£¿é
IBS AI/I Ä£ÄâÁ¿ÊäÈëÄ£¿é
IBS 24 BK-T
IBS 24 DO/32-B Êý×ÖÁ¿Êä³öÄ£¿é
IBS PC CB/I-T
IBS 24 DI Êý×ÖÁ¿ÊäÈëÄ£¿é
IBS 24 DO Êý×ÖÁ¿Êä³öÄ£¿é
IBS 24 DO/32 Êý×ÖÁ¿Êä³öÄ£¿é
IBSAI Ä£ÄâÁ¿ÊäÈëÄ£¿é
IBSAO1 IBS AO 1Ä£ÄâÁ¿ÊäÈëÄ£¿é
IBS 220 BK ×Üվģ¿é
IBS 24 BK
IBSPBC10 µçÀÂ
IBSPBC100 IBS PBC 100 C µçÀÂ
IBS PBC 150 µçÀÂ
IBS 24 DI/32 Êý×ÖÁ¿ÊäÈëÄ£¿é
IBS 24 DO/LC Êý×ÖÁ¿Êä³öÄ£¿é
IBS 24 RELS ¼ÌµçÆ÷Êä³öÄ£¿é
IBS S5/SL
IBC V. 24 RS 232C ÐÐͨÐÅÄ£¿é
IBC 24 ADIO 3 Êý×ÖÁ¿I/OÄ£¿é
IBC AI 3 Ä£ÄâÁ¿ÊäÈëÄ£¿é
IBC A0I Ä£ÄâÁ¿Êä³öÄ£¿é
PSM-V24/TTY-P/HA/SB ½Ó¿Úת»»Æ÷
PSM-V24/V24-P/SB PSM-V24/V24-P/SB ½Ó¿Úת»»Æ÷
PSM-SET-FSMA/4
PSM-LWL/KPFLEX µçÀÂ
OPTOSUB-PLUS-K/IN
OPTOSUB-PLUS-K/OUT
PSM-SET-FSMA/4-KT
IBS S5/SL-LB-B
IBS 24 DO/32/F2 Êý×ÖÁ¿Êä³öÄ£¿é
IBS 24 DI/32/F2 Êý×ÖÁ¿ÊäÈëÄ£¿é
IBS PRG CAB
MCR-C-U-I-10B-0B-DCI
FLT-Plus CTRL-0.9
IBS RL 24 OC-LK
IBS RL 24 DIO 4/2/4-LK Êý×ÖÁ¿I/OÄ£¿é
ST-REL3-HG 24/21 ¼ÌµçÆ÷Á¬½ÓÆ÷
FLHUB10BASE-T FL HUB 10BASE-T
IBS S5 DAB
IBS IL 24 BK-LK-2MBD Ô¶³ÌÊäÈë/Êä³öÄ£¿é
IB IL 24 PWR IN
IBS IL 24BK T/U-PAC
TRIO-PS/ 1AC/24DC/ 5 µçÔ´
MINI-PS-100-240AC/24DC/C2LPS µçÔ´
PHOENIX QUINT-PS-100-240AC/24DC/5
PS-100-240AC/10-15DC µçÔ´
MINI-PS 24DC 4A µçÔ´
PS-120 AC/24DC/5 µçÔ´
QUINT20 µçÔ´
QUINT20 µçÔ´
CM125-PS-120-230AC/24DC/S/F µçÔ´Ä£¿é
CM 90-PS-220AC/24DC/1,5 µçÔ´
CM 90-ELR-W3/5
EMG 22 DIO 7P ¶þ¼«¹ÜÄ£¿é
UM 45-FLK50 Á¬½ÓÆ÷
PLC-BSC-24DC/21 ¶Ë×Ó
PLC-RSP-230UC/21
PLC-BSC-24DC/21-21 ¶Ë×Ó
UMKS-F48M-VR
UMK 8 RM24DC/MK
KSR-G24/21/PLC
PSR-SPP-24DC/TS/S Êý×Ö¿ØÖÆÄ£¿é
RV-8 PV-TP
IB STTB 24 AO 4/SF; 2750578, 2750057
IB STME 24 DO 32; 2750824
IB STTB 24 DO 16/3, 2754914; 2754943
IBS STTB ZF 24 BK LB-T ÖÕ¶ËÄ£¿é
IB STTB ZF 24 BK-T
IB STTB 24 BDO 8/3 ÖÕ¶ËÄ£¿é
IB STTB 24 BDO 16/3 ÖÕ¶ËÄ£¿é
IB STTB 24 BDI 16/4; 2750170, 2751687 ÖÕ¶ËÄ£¿é
IB STTB 24 DI16/4
IB STTB 24 DIO 8/8/3-2A ½ÓÏߺÐ
IBS STTB 24 BK DIO 8/8/3-T
IBS STTB 24 BK LB-T; 2753504; 2752932
IB STTB ZF 24; 2750691
IB STTB ZF 24 DO 16/3 ÖÕ¶ËÄ£¿é
IB STTB ZF 24 DI 32/2, 2750675
IBS STTB ZF 24
IB STTB ZF 24 DI 16/4 ÖÕ¶ËÄ£¿é
IBS STTB 24 BK-T; 2754341; 2754367
IBSTTB24DI32/2; 2754927 ½ÓÏߺÐ
IB STME 24 BAI 8/U; 2750060; 2750565
IB STTB 24 PT100 4/4; 2752767; 2750138
IB STTB24 BDI 8/4 ÖÕ¶ËÄ£¿é
IB STTB 24 INC/2
IB STTB ZF 24 AI 4/SF »ù´¡Ä£¿é
IB STTB 24 DO 8/3-2A, 2754891
IS STTB 24 AI 4/1
IB STTB 24 DO 16 R/S ½ÓÏߺÐ
IB STME 24 AO4/SF4-V3; 2750581, 2724630, 2750057
IB STTB ZF 24 DO 16 R/S ÖÕ¶ËÄ£¿é
IB STTB 24 UTH 8; 2724902; 2724889
IB ST 24 DI32/2-MB Base Module
IBC S5/SL
IBS CO AT ½Ó¿ÚÄ£¿é
IBS S5 DCB-T
IBS S5 DCB/I-T
IBS S5/SL ½Ó¿ÚÄ£¿é
IBS S5/SL-LB ½Ó¿ÚÄ£¿é
IBS S5/SL-LB-B
IBS S7 400DSC/I-T Öն˰å
IBSS5DSC/I-T
¸ß¶ÈÄ£¿é»¯µÄInline I/Oϵͳ¿É³öÉ«µÄÊÊÓ¦ËùÓÐ×Ô¶¯»¯ÈÎÎñ£¬Ìṩ×î´óÏ޶ȵÄÓÅÊÆ£º
¸ß¶ÈÑ¡ÔñÐÔ
Êý×ÖÁ¿ÊäÈë»òÊä³ö
Ä£ÄâÁ¿´«¸ÐÆ÷ºÍÖ´ÐÐÆ÷µÄÈ«Ãæ¿É¿¿ÐÔ
¹¦ÄÜÄ£¿é¡¢µç»ú¿ª¹ØºÍ°²È«²úÆ·
ÊʺÏËùÓпØÖÆÆ÷
½ÚÊ¡¿ØÖƹñ¿Õ¼ä
¡°²å°ÎÌæ´ú½ÓÏß¡±ÔÔòËõ¶ÌÁ˰²×°Ê±¼ä£¨½Úʡʱ¼ä×î¶à´ï80%£©
IB IL 24 DO 16-ME
·ÆÄá¿Ë˹ģ¿éIB IL 24 DI 16-ME
·ÆÄá¿Ë˹ģ¿éIB IL 24 PWR IN/R-PAC
·ÆÄá¿Ë˹ģ¿éIB IL MUX-CAB PSI
·ÆÄá¿Ë˹ģ¿éIB IL 24 DI 32/HD
·ÆÄá¿Ë˹ģ¿éIB IL 24 DO 2-2A
·ÆÄá¿Ë˹ģ¿éIB IL 24 BR/DC
PHOENIXÄ£¿éIB IL AO 1/SF
PHOENIXÄ£¿éIB IL BK-PLSET/CP
PHOENIXÄ£¿éIB IL SCN-12-ICP
PHOENIXÄ£¿éIB IL SCN-12-OCP
PHOENIXÄ£¿éIB IL SCN-6 SHIELD
PHOENIXÄ£¿éIB IL SCN-8-CP
ÐͺŴýÐø£¬ÆäËüÌØ¼ÛÐͺÅÇë×Éѯ¡£
