System |
Network compatible Control System |
Task Processing |
Multi-Task Real time Processing System |
CPU & DSP |
68301(12MHz)for CPU,uPD77240(9MHz) for DSP |
RAM |
SRAM(Battery Back-up) 、 IC Memory Card |
Control Laguage |
Real time BASIC 、 Control Block 、 Ladder |
Scan Time |
5ms or times of 5ms ( Configurable) for Basic Task, Ladder Task
0.5ms or times of 0.5ms (Configurable) for Control Block Task |
Processing Spd. |
BASIC : 16bits Add : 136μs Control Block : Floating (32bits) Add : 3μs Ladder : Input 1.6μs 、 Output : 26μs |
User
Memory |
Cap |
CPU : 250KB(SRAM) DSP : 5kW(High Speed SRAM) |
Backup |
Lithium Battery 、 IC Memory Card (Flash 256kB) |
Network |
Max 56Drop/Network, 64×16Bit/Drop, Baud rate 875kbps 、 Distance 900m |
Communication Ports |
RS-232C(2CH) 、 RS-485(1CH) All Isolated |
Other I/F |
MODBUS Module
MELSEC-A Link Module Omron SYSMAC Series Link Module (All product compatible) |
Diagnostic |
Hardware Error
Software Error (300 Types) |
I/OType |
Controller Card Pulse input 3CH : External 300KHZ(MAX) : Internal 4 times 1.2MHZ Analog output 3CH : ±13bits Counter Latch Input: 9 points (12 ~ 24VDC)
DIO Card Discrete Input : 32 points (12 ~ 24VDC) Discrete Output : 32 点 (12 ~ 24VDC)
Absolute Encoder Input 3CH
AIO Card Analog Input 4CH : ±13bits Analog Output 4CH : ±13bits
Base Unit |
Extend slot : 2 |
Programming Terminal |
AX PC (MAXYNOTE386<Mitsubishi>Standard Type) |
Applications |
Servo Controll |
