PCL-818HD/HG 100 kHz µÍ³É±¾¶à¹¦ÄÜ ISA ¿¨
PCL-818L 40 kHz µÍ³É±¾¶à¹¦ÄÜ ISA ¿¨
ÌØµã
16 ·µ¥¶Ë»ò 8 ·²î·ÖÄ£ÄâÁ¿ÊäÈë
12 λ A/D ת»»Æ÷
ÿ¸öÊäÈëͨµÀµÄÔöÒæ¿É±à³Ì
´ø DMA µÄ×Ô¶¯Í¨µÀ/Ôö񾃬Ãè
16 ·Êý×ÖÁ¿ÊäÈë¼° 16 ·Êý×ÖÁ¿Êä³ö
Onboard FIFO memory (1024 samples, PCL-818HD/HG only)
1 · 12 λģÄâÁ¿Êä³ö
¿É±à³Ì´¥·¢Æ÷/¶¨Ê±Æ÷
¸ÅÊö
CL-818L ϵÁÐÊÇ PCL-818 ϵÁÐÖеÄÈëÃż¶°å¿¨¡£ PCL-818L ÊÇΪ¶Ô¼Û¸ñ½ÏΪÃô¸ÐµÄ¿Í»§¶ø×¨ÃÅÉè¼ÆµÄ£¬µ«³ýÁËËüµÄ²ÉÑùËÙÂÊΪ 40 kHz ºÍÖ»Ö§³Öµ¥¼«ÐÔÊäÈëÖ®Í⣬ËüÒÀÈ»Óë´ËϵÁÐÖÐÆäËü²úÆ·¾ßÓÐͬÑùµÄ¹¦ÄÜ¡£ PCL-818L Óë PCL-818HD ºÍ PCL-818HG ÔÚÈí¼þºÍ½Ó¿ÚÉÏÍêÈ«¼æÈÝ¡£ ÕâÑùÄú¾ÍÎÞÐë¸ü¸ÄÓ²¼þ»òÈí¼þ£¬¾Í¿ÉÒÔ½«Ó¦ÓÃÉý¼¶µ½¸ßÐÔÄܵÄÊý¾Ý²É¼¯¿¨ÉÏ¡£PCL-818LS °üº¬ PCL-818L °å¿¨¡¢PCLD-8115 ½ÓÏß¶Ë×Ó°åºÍ 1 ¸ù DB37 ±âƽµçÀ¡£ PCLD-8115 ´øÓÐÎÞÔ´Ðźŵ÷ÀíÔª¼þ£¨µçÈݼ°µç×裩£¬Äú¿ÉÒÔ·½±ãµÄʵÏÖµÍͨÂ˲¨¡¢µçѹ˥¼õ»ò 4 ~ 20 mA µçÁ÷µÄµçѹת»»¡£
¹æ¸ñ
Ä£ÄâÁ¿ÊäÈë
ͨµÀ 16 ·µ¥¶Ë»ò 8 ·²î·ÖÄ£ÄâÁ¿ÊäÈë
·Ö±æÂÊ 12 λ
×î¸ß²ÉÑùËÙÂÊ 40 KHz£¨ËùÓÐÊäÈ뷶Χ£©
¹ýѹ±£»¤ ¡À30 VDC£¨×î´ó£©
ÊäÈë×迹 10 M¦¸
²ÉÑùģʽ Èí¼þ´¥·¢¡¢¶¨Ê±Æ÷´¥·¢»òÍⲿ´¥·¢Æ÷´¥·¢
ÊäÈ뷶Χ (V,µçѹ£¬Èí¼þ¿É±à³Ì£©
Ë«¼«ÐÔ¡À10 ¡À5 ¡À2.5 ¡À1.25 ¡À0.625
¾«¶È (FSR µÄ % ¡À1LSB) 0.01 0.01 0.02 0.02 0.04
Ä£ÄâÁ¿Êä³ö
ͨµÀ 1
·Ö±æÂÊ 12 λ
Êä³öËÙÂÊ ¾²Ì¬¸üÐÂ
Êä³ö·¶Î§ (µçѹ£¬Èí¼þ¿É±à³Ì£©
ÄÚ²¿²Î¿¼µçѹµ¥¼«ÐÔ0 ~ 5, 0 ~ 10
Íⲿ²Î¿¼µçѹ0~10, 0~ -10
Êý×ÖÁ¿ÊäÈë
ͨµÀ 16
¼æÈÝÐÔ 5 V/TTL
ÊäÈëµçѹ Âß¼µçƽ 0£º0.8 V£¨×î´ó£©
Âß¼µçƽ 1£º2.0 V£¨×îС£©
Êý×ÖÁ¿Êä³ö
ͨµÀ 16
¼æÈÝÐÔ 5 V/TTL
Êä³öµçѹ Âß¼µçƽ 0£º0.4 V£¨×î´ó£©
Âß¼µçƽ 1£º2.4 V£¨×îС£©
Êä³öÄÜÁ¦ »ã£º8 mA
Ô´£º-0.4 mA
¶¨Ê±Æ÷/¼ÆÊýÆ÷
ͨµÀ 1
A/D ¶¨Ê±´¥·¢Æ÷ 32 λ, 10 MHz »ò 1 MHz ʱ»ù
×î¸ßºÍ×îµÍËÙÂÊ 2.5 MHz µ½ 0.00023 Hz
¼ÆÊýÆ÷ 1 ¸ö 16 λ¼ÆÊýÆ÷£¬Ê±»ù 100 KHz
Ò»°ã¹æ¸ñ
¹¦ºÄ +5 V @ 210 mA (µäÐÍ) ,500 mA£¨×î´ó£©
+12 V @ 210 mA (µäÐÍ) ,100 mA£¨×î´ó£©
-12 V @ 20 mA (µäÐÍ) ,40 mA£¨×î´ó£©
I/O ½Ó¿Ú DB37-F
³ß´ç (L x H) 155 x 100 mm (6.1¡± x 3.9¡±)
¹¤×÷ÎÂ¶È 0 ~ 50¡ã C (32 ~ 122¡ã F)
´¢´æÎÂ¶È -20 ~ 65¡ã C (-4 ~ 149¡ã F)
¹¤×÷ʪ¶È 5% ~ 95% RH£¬ÎÞÄý½á£¨²Î¼û IEC 68-2-3£©
¶©»õÐÅÏ¢
PCL-818L µÍ³É±¾£¬¸ßÐÔÄܰ볤¶à¹¦ÄÜÊý¾Ý²É¼¯¿¨£¬ÓÃ
»§ÊÖ²áºÍÇý¶¯³ÌÐò CD-ROM£¨²»º¬µçÀ£©
PCL-818LS PCL-818L ´ø PCLD-8115 ºÍ DB-37
µçÀ (PCL-10137)
PCL-10137-1 37 о D Ð͵çÀ£¬1 Ã×
PCL-10137-2 37 о D Ð͵çÀ£¬2 Ã×
PCL-10137-3 37 о D Ð͵çÀ£¬3 Ã×
PCLD-8115 ´ø CJC µç·ºÍ DB37 ½Ó¿ÚµÄ¹¤Òµ½ÓÏß¶Ë×Ó
PCLD-880 ´ø DB37 ½Ó¿ÚµÄ¹¤Òµ½ÓÏß¶Ë×Ó
