Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú MOXA NPort 5650 »ú¼Üʽ´®¿Ú·þÎñÆ÷
²úÆ·Ãû³Æ£º MOXA NPort 5650 »ú¼Üʽ´®¿Ú·þÎñÆ÷
ÐÍ ºÅ£º MOXA NPort 5650 »ú¼Üʽ´®¿Ú·þÎñÆ÷
Æ· ÅÆ£º 78
16¿Ú»ú¼ÜʽRS-232/422/485´®¿Ú·þÎñÆ÷
¼ò½é
NPort® 5600ϵÁÐΪ´®¿ÚÉ豸Á¬½Óµ½ÒÔÌ«ÍøÌṩÁ˱ã½ÝµÄ´« Ê䷽ʽ£¬²»½ö±£»¤ÄúµÄÏÖÓÐÓ²¼þͶ×Ê£¬¶øÇÒÈ·±£½«À´ÍøÂçµÄ À©Õ¹ÐÔÄÜ¡£ÄúÖ»ÐèÒª×öһЩ¼òµ¥µÄÅäÖÃÈÎÎñ£¬¾Í¿ÉÒÔʹÏÖÓÐµÄ ´®¿ÚÉ豸×öºÃÁËÁªÍøµÄ×¼±¸¡£´ËÍ⣬NPort® 5600ϵÁпÉÒÔÖ± ½Ó½øÐд®¿ÚºÍÒÔÌ«Íø½Ó¿ÚµÄË«Ïò´«ÊäÊý¾Ý¡£Í¨¹ýʹÓÃNPort® 5600ϵÁУ¬Äú¿ÉÒÔͬʱ¼¯ÖйÜÀíÄúµÄ´®¿ÚÉ豸ºÍÖ÷»úϵͳ¡£
×î¶à¿ÉÈÃ16¸öRS232´®¿ÚÉ豸ÁªÍø
Ö»Ðè¼òµ¥µÄÅäÖã¬NPort® 5600¾Í¿ÉÒÔ½«16¸ö´®¿ÚÉ豸Á¬½Ó ÖÁÒÔÌ«Íø¡£
19´ç»ú¼ÜʽÉ豸ÁªÍø·þÎñÆ÷
NPort 5610¾ßÓÐרҵµÄÍâ¿ÇÉè¼Æ£¬³ýÁËÇ°Ãæ°åÉÏÓÐËùÓеĴ®¿ÚµÄTx/Rx ״̬LEDÏÔʾ£¬ºóÃæ°åÉÏÔòÓÐ8/16¿ÚRS-232 RJ45½ÓÏ߿ڡ£ÕâÏîÌØµãÈÃNPort 5610ÊÊÓÃÓÚ±ê×¼19´ç»ú¼Ü°²×°£¬¼ò»¯Á˲Ù×÷£¬Î¬»¤£¬ºÍ¹ÜÀíµÄ¹¤×÷¡£
¼ò½é
Real COM/TTY¶Ë¿Ú
ÔÚ°²×°ÍêËæ»úËù´øµÄNPort 5610µÄreal COM/ttyÇý¶¯³ÌÐòºó£¬NPort 5610ÉϵĴ®¿Ú»á±»Windows²Ù×÷ϵͳÊÓΪReal COM¶Ë¿Ú£¬»ò±»Linux²Ù×÷ϵͳÊÓΪtty¶Ë¿Ú¡£NPortϵÁÐÌṩ»ù±¾µÄ´«Êä/½ÓÊÕÊý¾Ý¹¦ÄÜ£¬ÒÔ¼°RTS£¬CTS£¬DTR£¬DSR£¬ºÍ DSDµÈ¿ØÖÆÐźŹ¦ÄÜ¡£
LED ÏÔʾÆ÷
Á¬½ÓÍ·ÉϵÄϵͳLED¡¢´®¿ÚTx/Rx LED¡¢ÒÔ¼°ÒÔÌ«ÍøÂçLEDÏÔʾÆ÷ÈÃÏÖ³¡¹¤³ÌʦÄܹ»¿ìËٵķÖÎöÎÊÌâËùÔÚ£¬²¢ÇÒÈÃ¼à¿ØµÄ¶¯×÷±äµÄ¼òµ¥¡¢ÇáËÉ¡£NPort 5610µÄLEDÏÔʾÆ÷²»½öÄܹ»ÏÔʾĿǰϵͳºÍÍøÂçµÄ״̬£¬Ò²ÄÜЭÖúÏÖ³¡¹¤³Ìʦ¼à¿ØËùÁ¬½Ó´®¿ÚÉ豸µÄ״̬¡£
ÌØµã
- ¼òµ¥Ò×ÓõÄLCM£¨Liquid Crystal Module£©ÏÔʾ²Ù×÷½çÃæ£¬¿ÉÓÃÓÚÉèÖÃIPµØÖ·
- ±ê×¼19´ç»ú¼Üʽ°²×°
- ×Ô¶¯¼ì²â10/100Mbps Ethernet½çÃæ
- 16/8¸öRS-232´®¿Ú
- ËùÓж˿ڽÔÓÐÍ»²¨±£»¤¹¦ÄÜ£¨15KV ESD£©
- Ö§³ÖTCP Server£¬TCP Client£¬UDP£¬ºÍReal COMģģʽ
- Ö§³ÖwebÓëtelnet console
- Ö§³ÖSNMP MIB-IIÍø¹Ü¹¦ÄÜ
ÒÔÌ«Íø ¿ÚÊýÁ¿£º1
ËÙÂÊ£º10/100 M×ÔÊÊÓ¦ MDI/MDIX
½ÓÍ·£º8-pin RJ45
µç´Å¸ôÀë±£»¤£ºÄÚ½¨1.5 KV
¹âÏË ¾àÀ룺
¶àÄ££º0 ~ 2 km£¬1310 nm (62.5/125 ¦Ìm£¬500 MHz*km)
µ¥Ä££º0 ~ 40 km£¬1310 nm (9/125 ¦Ìm£¬3.5 PS/(nm*km))
×îСTXÊä³ö£º-20 dBm (¶àÄ£)£¬-5dBm (µ¥Ä£)
×î´óTXÊä³ö£º-14 dBm (¶àÄ£)£¬0 dBm (µ¥Ä£)
ÁéÃô¶È£º-34 ~ -30 dBm (¶àÄ£)£¬-36 ~ -32 dBm (µ¥Ä£)
´®¿Ú ÊýÁ¿£º8»ò16¸ö
´®¿Ú±ê×¼£º
NPort® 5610£ºRS-232
NPort® 5630£ºRS-422/485
NPort® 5650£ºRS-232/422/485
¶Ë¿ÚÀàÐÍ£ºRJ45 (8-pin)
´®¿ÚÏßÐÔ±£»¤£ºÈ«ÐźÅ15 KV ESD
RS-485Êý¾ÝÁ÷Ïò£ºADDC® (רÀû±£»¤µÄÊý¾ÝÁ÷Ïò×Ô¶¯¿ØÖƹ¦ÄÜ)
RS-485ÉÏÀ­/ÏÂÀ­µç×裺1 K¦¸£¬150 K¦¸
´®ÐÐͨѶ²ÎÊý Êý¾Ýλ£º5£¬6£¬7£¬8
ֹͣλ£º1£¬1.5£¬2
УÑéλ£ºNone£¬Even£¬Odd£¬Space£¬Mark
Á÷¿Ø£ºRTS/CTS£¬DTR/DSR (½öRS-232)£¬XON/XOFF
²¨ÌØÂÊ£º50 ~ 921.6 Kbps
´®ÐÐÐźŠRS-232£ºTxD£¬RxD£¬RTS£¬CTS£¬DTR£¬DSR£¬DCD£¬GND
RS-422£ºTx+£¬Tx-£¬Rx+£¬Rx-£¬GND
RS-485 (2Ïß)£ºData+£¬Data-£¬GND
RS-485 (4Ïß)£ºTx+£¬Tx-£¬Rx+£¬Rx-£¬GND
Èí¼þÌØµã ÍøÂçЭÒ飺ICMP£¬IP£¬TCP£¬UDP£¬DHCP£¬BOOTP£¬Telnet£¬
DNS£¬SNMP V1/V2c£¬HTTP£¬SMTP£¬SNTP£¬ARP£¬PPP£¬
SLIP£¬RTelnet£¬RFC2217
ÅäÖãºWeb Console£¬Telnet Console£¬Windows Utility
WindowsʵʱCOMÇý¶¯£ºWindows 95£¬98£¬ME£¬NT£¬
2000£¬XP x86/x64£¬2003 x86/x64£¬Vista x86/x64£¬2008
x86/x64£¬Embedded CE 5.0/6.0£¬XP Embedded
¹Ì¶¨TTYÇý¶¯£º£ºSCO Unix£¬SCO OpenServer£¬UnixWare
7£¬UnixWare 2.1£¬SVR 4.2£¬QNX 4.25£¬QNX 6£¬Solaris 10£¬
FreeBSD£¬AIX 5.x£¬HP-UX 11i
LinuxʵʱTTYÇý¶¯£ºLinux kernel 2.4.x£¬2.6.x
ÃÔÄãÆÁÄ»ºÍ°´Å¥ LCDÃæ°å£ºÌṩҺ¾§ÏÔʾÆÁ
°´¼ü£º4¸ö°´¼ü£¬·½±ã¶ÔÏÖ³¡ÅäÖÃ
»úÐµÌØÐÔ Íâ¿Ç£º½ðÊô£¬IP30·À»¤µÈ¼¶
ÖØÁ¿£º
NPort® 5650-16£º3460 g
NPort® 5650-16-S-SC£¬5650-16-M-SC£º3440 g
³ß´ç:
ÎÞ¹Ò¶ú£º440 x 45 x 198 mm (17.32 x 1.77 x 7.80 in)
ÓйҶú£º480 x 45 x 198 mm (18.90 x 1.77 x 7.80 in)
¹¤×÷»·¾³ ¹¤×÷ζȣº0 ~ 55 ¡ãC (32 ~ 131 ¡ãF)
¹¤×÷ʪ¶È£º5 ~ 95% RH
´æ´¢Î¶ȣº-20 ~ 75 ¡ãC (-4 ~ 167 ¡ãF)
µçÔ´ÐèÇó ÊäÈëµçѹ£º
NPort® 5610/5630/5650£º100 ~ 240 VAC£¬47 ~ 63 hz
µçÔ´¹¦ºÄ£º
NPort® 5650-8/16£º158 mA @ 100 VAC£¬102 mA @ 240
VAC
NPort® 5650-8/16-S-SC£º164 mA @ 100 VAC£¬110 mA @
240 VAC
NPort® 5650-8/16-M-SC£º174 mA @ 100 VAC£¬113 mA @
240 VAC
°²¹æÈÏÖ¤ EMC£ºCE (EN55022 Class A£¬EN55024)£¬FCC Part 15
Subpart B Class A
NPort® 5610 only£ºIEC61000-4-12
°²È«£ºUL (UL60950-1)£¬TÜV (EN60950-1)
Ò½ÁÆ£ºEN60601-1-2 Class B£¬EN55011
¿É¿¿ÐÔ
×Ô¶¯ÖØÆô´¥·¢»úÖÆ£ºÄÚ½¨WDT£¨¿´ÃŹ·Ê±ÖÓ£©
¿ÉÑ¡ÐͺÅ
²úÆ·±àºÅ ÃèÊö
NPort 5650-16 16¿ÚRS-232/422/485µ½ÒÔÌ«Íø´®¿ÚÉ豸ÁªÍø·þÎñÆ÷£¬100-240 VACµçÔ´ÊäÈ룬»ú¼ÜÐÍ
NPort 5650-16-M-SC£º 16¿ÚRS-232/422/485´®¿ÚÉ豸ÁªÍø·þÎñÆ÷£¬10/100BaseF(X)£¬¶àÄ£¹âÏË (SCÁ¬½ÓÍ·)£¬»ú¼ÜÐÍ
NPort 5650-16-S-SC 16¿ÚRS-232/422/485´®¿ÚÉ豸ÁªÍø·þÎñÆ÷£¬10/100BaseF(X)£¬µ¥Ä£¹âÏË (SCÁ¬½ÓÍ·)£¬»ú¼ÜÐÍ
´®¿ÚµçÀÂÏß
²úÆ·±àºÅ ÃèÊö
CBL-RJ45M9-150 150 cm 8-pin RJ45תDB9ÕëʽµçÏß
CBL-RJ45F9-150 150 cm 8-pin RJ45תDB9¿×ʽµçÏß
CBL-RJ45M25-150 150 cm 8-pin RJ45תDB25ÕëʽµçÏß
CBL-RJ45F25-150 150 cm 8-pin RJ45תDB25¿×ʽµçÏß
MTBF (meantime between failures):
NPort® 5650-8£º117584Сʱ
NPort® 5650-16£º104767Сʱ
NPort® 5650-S-SC-8£º116914Сʱ
NPort® 5650-S-SC-16£º87528Сʱ
NPort® 5650-M-SC-8£º116914Сʱ
NPort® 5650-M-SC-16£º87528Сʱ
±£ÐÞ ±£ÐÞÆÚ£º5 Äê
¹«Ë¾Ãû³Æ£º ±±¾©À¶²©Ô¶Ñï¿Æ¼¼·¢Õ¹ÓÐÏÞ¹«Ë¾
µç »°£º 010 62632232 82483045 / Ñî֥Ȩ
ÊÖ»ú£º 13911904509
µØ Ö·£º ±±¾©Êк£µíÇøÖйشå´ó½ÖEÊÀ½ç²Æ¸»ÖÐÐÄA×ùA631
ÓÊ ±à£º 100086
Ö÷ Ò³£º http://www.lbyy2008.com
  • MOXA UPort 1450ϵÁÐ
  • MOXA UPort 1250/1250I
  • MOXA UPort™ 1150/1150I
  • MOXA UPort 1130
  • MOXA UPort 1610-16
  • MOXA UPort 1610-8/1650-8
  • MOXA UPort 1400ϵÁÐ
  • MOXA UPort 1110 (ÐÂÆ·£¡)
  • MOXA UPort™ 2410
  • moxa UPort™ 2210
