ÐͺţºIGYX 30P17B3/L
¿ÉÌæ»»Å·Ä·Áú¡¢Í¼¶û¿Ë¡¢P+FµÈ²úÆ·
general data
mounting type shielded
nominal sensing distance Sn 15 mm
assured sensing distance Sa 12 mm
temperature drift ¡À 10 % of Sr (0 ... +60 ¡ãC)
hysteresis 3 ... 20 % of Sr
output indicator LED red
electrical data
switching frequency < 400 Hz
voltage supply range +Vs 10 ... 30 VDC
current consumption max. 15 mA
output circuit PNP make function (NO)
voltage drop Vd < 2,5 VDC
output current < 200 mA
short circuit protection yes
reverse polarity protection yes
ÈçÄúÐèÒª¶©¹º¼°×Éѯ±¤Ã˵IJúÆ·£¬Ç뽫ѯ¼Ûµ¥·¢ÖÁÓÊÏä»ò´«ÕæÖÁÎÒ˾£¬Ñ¯¼Ûµ¥Ó¦°üº¬¹«Ë¾Ãû³Æ(È«³Æ)¡¢ÁªÏµµç»°¡¢ÁªÏµÈË¡¢²úÆ·Ãû³Æ¡¢ÐèÒªµÄÊýÁ¿£¬Ð»Ð»ÄúµÄÅäºÏ£¡
