²úÆ·Ãû³Æ£º SLO-SYN
ÐÍ ºÅ£º SS2000I,440EPI/440PTO ,430PT,3180EPI,SS2000D6,6180PT,M092-FD-8109
Æ· ÅÆ£º 10190
Environmental Specifications
Mechanical
SS2000D6i Size:
3.67W x 10.93H x 5.98D
SS2000D3i Size:
2.33W x 10.78H x 5.96D
Operating Temperature:
+32°F to +122°F(0°C to +50°C)
Storage Temperature:
-40°F to +167°F(-40°C to +75°C)
Humidity:
95% maximum, non-condensing
Altitude
10,000 feet (3,048 meters) max.
Weight:
7.75 lbs. (3.52 kg)
Electrical Specifications, Drive Section
SS2000D6i
AC Input Range:
90 to 132 VAC, 50/60 Hz
AC Current:
7 amperes
Drive Power Dissipation (Worst Case):
50 watts
SS2000D3i
AC Input Range:
AC Current:
5 amperes
35 watts
SS2000D3i-240
AC Input Range:
190 to 260 VAC, 50/60 Hz
AC Current:
5 amperes
35 watts
Fuse Rating, All Models
250 Volts, 8 Amps.
Isolated Digital I/O
12V DC Internal I/O Power:
11.5 to 14V DC @ 100mA
or
User Supplied I/O Power: 5-24V DC
Inputs (IN1 - IN8):
Sink Mode:
(+Vopto = 12V DC)
On State Voltage Range (Vin):
0V to +6V DC
Input Current (Vin = 0V):
-6mA
Source mode:
4.5V to 24V
Input Current (Vin = 12V DC):
6mA
Response Time (sink or source):
Opto Turn On Delay:
10uS typical
Opto Turn Off Delay:
75uS typical
Programmable Outputs (OUT1-OUT4):
Sink Mode:
Continuous Current Rating per Output:
250mA max.
Maximum Collector Voltage:
25V max.
On State Voltage @ 250mA:
1.5V max.
Non-Isolated I/O (or BCD Interface):
IN9 - IN 16: These inputs may be used with open collector outputs without an external supply by connecting the output device common (ground) to signal ground on the unit, and the open collector to the input pin. An internal pullup resistor to +5V DC is provided.
Logic High Input Level:
25V > Vsource > 4.5V, or open circuit
Logic Low Input Level:
1.2V max.
Logic Low Current with Input @ GND:
-1mA max.
OUT5 - OUT8: These are open-collector, sink only TTL outputs, and are NOT isolated from the unit''s +5V logic supply. Proper care must be taken to ensure noise is not injected onto these signals. The user''s I/O supply must be referenced to GND on the controller.:
Active Output Voltage:
0.6V max. @ 20mA
Permissible Output Current:
20mA
Permissible Output Voltage:
24V DC
Serial Communications:
Port 1: Configurable for RS-232C or RS-485 four wire communications via a switch. Port 1 is designated as the HOST communications port and can be used to daisy chain up to 32 units in RS485 mode.
Port 2: Serial port 2 is used for differential RS485 four wire USER communications.
Encoder Connections:
Encoder connections provide power and inputs for a digital encoder interface to indicate motor position to the controller.
Encoder +5V DC
Power Supply Output:
+5V DC (�5%) @ 100mA current.
Encoder Signal Inputs: TTL level Single-ended or differential; channels A and B in phase quadrature.
Input Current A+, A-, B+, B-, Z+, Z-:
�5mA min.
Analog Input:
Voltage Range:
0-10V referenced to GND
Resolution:
10 bits or 9.77mV
Absolute Accuracy:
�0.3V worst case
Sample Rate:
500 Hz min.
Bandwidth:
100 Hz max.
¹«Ë¾Ãû³Æ£º À¥Ã÷ÇåÕý¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0871 8324348 / ÎâÃÉ
ÊÖ»ú£º 13888603562
µØ Ö·£º À¥Ã÷Êжþ»·Î÷·625ºÅÔÆÍ­¿Æ¼¼´óÂ¥401ÊÒ
ÓÊ ±à£º 650000
Ö÷ Ò³£º http://www.qz-st.com
  • 2000/N-P
  • SLO-SYN
  • 2000/N-P
  • MONARCH
