honeywell GLAB01A2B,GLAA20A2B,GLAB01C限位开关
Product Features:
- Operating Force (O.F.): 0,330 N m [2.90 in lb]
- Pretravel (P.T.): 26°
- Overtravel (O.T.): 59°
- Differential Travel (D.T.): 12°
- Actuator: Side Rotary
- Lever Style: Roller - Adjustable
- Circuitry: 1NC 1NO SPDT Snap Action
- Ampere Rating: 10 A (Thermal)
- Supply Voltage: 600 Vac and 250 Vdc max.
- Housing Material: Zinc Die-Cast
- Termination Type: PG13.5
- Housing Type: EN 50041
- Series Name: GLS DIN
- Shock: 50 g per IEC 68-2-27c (w/o Actuator)
- Vibration: 10 g per IEC 68-2-6 (w/o Actuator)
- Sealing: NEMA 1, 4, 12, 13 IP67
- Approvals: UL, CSA, CE
- CSA File #: LR94369-3
- UL File #: E37138 & E157416
- Mechanical Life: 15 million
- Operating Temperature Range: -25 °C to 85 °C [-13 °F to 185 °F]
- Agency Approvals and Standards: IEC 947-5-1, EN60947-5-1, UL508
- UNSPSC Code: 302119
- UNSPSC Commodity: 302119 Switches and controls and relays
- Sealed: Industrial
- Operating Position (O.P.): 26°
Documentation and Links: |
Actual product appearance may vary. |
