CPU
Intel® Core i7/i5, rPGA988´¦ÀíÆ÷
оƬ×é
Intel® QM57
ϵͳÄÚ´æ
204-pin DDR3 SODIMM x 2, ×î´óÖ§³Ö8GB
ÏÔʾ½Ó¿Ú
VGA
DB-15 x 1, ¹²ÏíϵͳÄÚ´æ×î¸ß¿É´ï512MB
DVI
DVI-I x1 (DVI - DÊý×ÖÐźÅ)
´æ´¢É豸
½Ó¿Ú
SATA x 3
HDD
2.5" SATA¿¹ÕðÓ²Å̼Üx 1
ÍøÂç
ÍøÂçоƬ
ǧÕ×ÒÔÌ«Íøx 3, Intel® 82577LM/82574L
Íø¿Ú
RJ-45 x 3
ǰÖÃI/O
USB½Ó¿Ú
2
MIC, Line-out
¼üÅÌ/Êó±ê
1
ÆäËû
µçÔ´°´Å¥¡¢µçÔ´ÊäÈë(Terminal block connector, 3-pin£©
ºóÖÃI/O
USB½Ó¿Ú
4
Íø¿Ú
RJ-45 x 3
´®¿Ú
RS-232 x 3, RS-232/422/485 x 1
DIO
8, 4-in/4-out
À©Õ¹
À©Õ¹²Û
2, PCIe[x1] x2 »ò PCI x1+ PCIe[x1] x1(572AÖ§³Ö)
MiniCard
1, Ö§³Ö°ë³¤/È«³ß´ç, Ö§³ÖmSATA(¿ÉÑ¡Å䣩
USB
4( w/ pin-header)
ָʾµÆ
ǰÖÃ
LAN LED (active, ÂÌÉ«) x3,ϵͳLED (ÂÌÉ«)x1, HDD LED (active, »ÆÉ«)x1
ºóÖÃ
¹©µç·½Ê½
DC 12V»ò9~30V(Ñ¡Åä)
µçԴģʽ
ATX
°²×°·½Ê½
±Ú¹Òʽ
¹¤×÷ζÈ
ÎÞ¿ÕÆø¶ÔÁ÷»·¾³Ï£º
-15°C ~ 50°C (w/ i7/620M, HDD)
-20°C ~ 55°C (w/ i7/620M, MiniPCIeDOM)
´æ´¢Î¶È
-40°C ~ 70°C (-4°F ~ 140°F)
´æ´¢Êª¶È
10%~95% @40°C; ÎÞÀäÄý
¿¹Õñ¶¯
5g rms/5~500Hz/ÔËÐÐ״̬ÏÂ-MiniPCIeDOM
1g rms/5~500Hz/ÔËÐÐ״̬ÏÂ-HDD
¿¹³å»÷
50 G·åÖµ¼ÓËÙ¶È(³ÖÐøÊ±¼ä11 msec.) - MiniPCIeDOM
Íâ¹Û³ß´ç
µ¥»ú 214mm(W) x 207.5mm (D) x 93mm (H)
º¬¹Ì¶¨¼Ü 247mm (W) x 208.5mm (D) x 101.8mm (H)
×ÜÖØ
4.8 Kg
¾»ÖØ
3.3 Kg
²Ù×÷ϵͳ
Ö§³ÖWindow® XP Embedded, Window® XP (32-bit), Window®
7(32/64-bit), Linux Fedora Core 10 (kernel 2.6.27)
