ÐͺÅ˵Ã÷£º
ÐͺŠ|
ÊäÈë |
¹©µçµçÔ´ |
Êä³ö |
·â×° |
IAPM V3-P1-V1 |
0-75mV |
24VDC |
0-5V |
SIP12 |
ÌØµã£º
>>СÌå»ý¡¢±ê×¼SIP12×èȼ·â×°
>>ÐźÅÊäÈë/Êä³ö/µçÔ´:3000VDC¸ôÀë
>>¹¤Òµ¼¶¿íζȣ¨-45¡ª+85¡æ£©
>>ÎÞÐèÍâ½ÓµçλÆ÷µÈÆäËüÔª¼þ£¬ÃâÁãµãºÍÔöÒæµ÷½Ú
>>µ¥µçÔ´¹©µç
>>·ûºÏUL94V-0±ê×¼×èȼ·â×°
>>³ß´ç£º32x14.2x8.9mm
>>ÔÚEMC£¨µç´Å¸ÉÈÅ£©±È½ÏÌØÊâµÄʹÓó¡ºÏӦעÒâÔö¼Óµç´Å¸ÉÈÅÒÖÖÆµç·»ò²ÉÈ¡ÆÁ±Î´ëÊ©
²úÆ·×î´ó¾ø¶Ô¶î¶¨Öµ£º
Continuous Isolation Voltage£¨³ÖÐø¸ôÀëµçѹ£©:3000VDC
Junction Temperature£¨¹¤×÷ζȣ©:+85¡æ
Storage Temperature £¨´æÖüζȣ©:+150¡æ
Lead Temperature £¨º¸½Óζȣ©:+300¡æ£¨10Ã룩
µçѹÐźÅÊä³öʱ×îС¸ºÔØÎª2K¦¸
µçÔ´µçѹ·¶Î§£º¡À10%Vin
×¢Ò⣺Èç¹û³¬³öÉÏÊö·¶Î§£¬²úÆ·¿ÉÄÜ»áÒýÆðÓÀ¾ÃÐÔË𻵡£
²úƷͨÓòÎÊý£º
Parameter |
Test Condition |
Mix |
Type |
Max |
Unit |
Isolated voltage ¸ôÀëµçѹ |
AC,50Hz,1min |
3000 |
V(rms) |
G.Adj ÔöÒæ |
1 |
V/V |
G.Adj temperature drift ÔöÒæÎÂÆ¯ |
25 |
ppm/¡æ |
Non-linearity ·ÇÏßÐÔ¶È |
0.1 |
0.2 |
%FSR |
Input signal
ÊäÈëÐźŠ|
Voltage µçѹ |
0 |
15 |
V |
Current µçÁ÷ |
0 |
30 |
mA |
Input maladjusted voltage ÊäÈëʧµ÷µçѹ |
2 |
5 |
mV |
Input impedance
ÊäÈë×迹 |
Voltage µçѹ |
1 |
M |
Current µçÁ÷ |
50 |
Output signal
Êä³öÐźŠ|
Voltage µçѹ |
-10 |
10 |
V |
Current µçÁ÷ |
-20 |
20 |
mA |
Load capability
¸ºÔØÄÜÁ¦ |
Voltage µçѹ |
Vout=10V |
2 |
k¦¸ |
Current µçÁ÷ |
0 |
350 |
650 |
Frequency response ƵÏì |
-3DB
10 |
KHz |
Signal output ripple Êä³öÎÆ²¨ |
No-filter²»Â˲¨ |
10 |
20 |
mVRMS |
Signal voltage temperature drift
ÐźŵçѹÎÂÆ¯ |
1 |
mV/¡æ |
Assistant power
¸¨ÖúµçÔ´ |
Voltage µçѹ |
Óû§×Ô¶¨Òå |
3.3 |
12 |
24 |
VDC |
Power loss
¹¦ºÄ |
0.5 |
1 |
W |
Operating temperature ¹¤×÷ÎÂ¶È |
-45 |
85 |
¡æ |
Storage temperature ´¢´æÎÂ¶È |
-55 |
105 |
¡æ |
ÍâÐγߴçºÍÒý½ÅÃèÊö£º
¸ü¶à×ÊÁÏ£º
http://www.wayjun.cn/ProductShow.asp?ID=271
