Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Î÷ÃÅ×ÓS7-400 CPU
²úÆ·Ãû³Æ£º Î÷ÃÅ×ÓS7-400 CPU
ÐÍ ºÅ£º 6ES7 417-4XT05-0AB0
Æ· ÅÆ£º 1
ÁªÏµÈË:³ÂºÆ µç»°£º021-60346029  ÊÖ»ú-13482833481
QQ:1024779677 ´«Õæ:021-33737848
The CPU 417-4 has:
  • Powerful processor:
    The CPU achieves instruction execution times as low as 0.018 µs per binary instruction.
  • 30 MB RAM (of which 15 MB each for program and data);
    fast RAM for parts of the user program relevant to execution.
  • Flexible expansion:
    Up to 262144 digital and 16384 analog inputs/outputs.
  • Multi-point interface MPI:
    With the MPI it is possible to establish simple networking of max. 32 stations at a data transmission rate of up to 12 Mbit/s. The CPU can establish up to 44 connections to stations of the communications bus (C bus) and the MPI.
    Note:
    If the PROFIBUS DP interface and MPI interface are operated simultaneously, it is only possible to connect the following bus connector to the MPI interface:
    • With socket: 6ES7 972-0BB41-0XA0
    • Without socket: 6ES7 972-0BA41-0XA0
  • Mode selector switch:
    Designed as toggle switch.
  • Diagnostics buffer:
    The last 120 fault and interrupt events are retained in a ring buffer for diagnostic purposes (extendable).
  • Real-time clock:
    The date and time are appended to diagnostic messages of the CPU.
  • Memory card:
    For expansion of the integrated load memory. The information in the load memory comprises S7-400 parameterization data in addition to the program and therefore requires twice as much memory space. The result is:
    • The integral load memory is not sufficient for large programs, therefore a memory card is frequently required.
      RAM and FEPROM cards (FEPROM for retentive storage) are available
  • PROFIBUS DP interface:
    The PROFIBUS DP master interface allows a distributed automation configuration offering high speed and ease of use. From the user''''s point of view, the distributed I/O is treated as central I/O (same configuring, addressing, and programming).
    Mixed configuration: SIMATIC S5 with SIMATIC S7 as PROFIBUS master to EN 50170.
    Note:
    If the PROFIBUS DP and MPI interface are operated simultaneously, it is only possible to connect the following bus connectors to the MPI interface:
  • Two additional slots:
    Two additional PROFIBUS DP master systems can be connected via IF 964-DP interface modules.
µçÔ´Ä£¿é
6ES7 407-0DA02-0AA0 µçÔ´Ä£¿é(4A)
6ES7 407-0KA02-0AA0 µçÔ´Ä£¿é(10A)
6ES7 407-0KR02-0AA0 µçÔ´Ä£¿é(10A)ÈßÓà
6ES7 407-0RA02-0AA0 µçÔ´Ä£¿é(20A)
6ES7 405-0DA02-0AA0 µçÔ´Ä£¿é(4A)
6ES7 405-0KA02-0AA0 µçÔ´Ä£¿é(10A)
6ES7 405-0RA01-0AA0 µçÔ´Ä£¿é(20A)
6ES7 971-0BA00 ±¸ÓÃµç³Ø
CPU
6ES7 412-3HJ14-0AB0 CPU 412-3H; 512KB³ÌÐòÄÚ´æ/256KBÊý¾ÝÄÚ´æ
6ES7 414-4HM14-0AB0 CPU 414-4H; ÈßÓàÈȱ¸CPU 2.8 MB RAM
6ES7 417-4HT14-0AB0 CPU 417-4H; ÈßÓàÈȱ¸CPU 30 MB RAM
6ES7 400-0HR00-4AB0 412H ϵͳÌ×¼þ°üÀ¨ 2 ¸öCPU¡¢1¸öHÐÍÖÐÑë»ú¼Ü¡¢2¸öµçÔ´¡¢2¸ö1M ´æ´¢¿¨¡¢4¸öͬ²½Ä£¿é¡¢2¸ùͬ²½µçÀ£¬ÒÔ¼°4¸ö±¸ÓÃµç³Ø(PS407 10A)
6ES7 400-0HR50-4AB0 412H ϵͳÌ×¼þ°üÀ¨ 2 ¸öCPU¡¢1¸öHÐÍÖÐÑë»ú¼Ü¡¢2¸öµçÔ´¡¢2¸ö1M ´æ´¢¿¨¡¢4¸öͬ²½Ä£¿é¡¢2¸ùͬ²½µçÀ£¬ÒÔ¼°4¸ö±¸ÓÃµç³Ø(PS405 10A)
6ES7 412-1XJ05-0AB0 CPU412-1,144KB³ÌÐòÄÚ´æ/144KBÊý¾ÝÄÚ´æ
6ES7 412-2XJ05-0AB0 CPU412-2,256KB³ÌÐòÄÚ´æ/256KBÊý¾ÝÄÚ´æ
6ES7 414-2XK05-0AB0 CPU414-2,512KB³ÌÐòÄÚ´æ/512KBÊý¾ÝÄÚ´æ
6ES7 414-3XM05-0AB0 CPU414-3,1.4M³ÌÐòÄÚ´æ/1.4MÊý¾ÝÄÚ´æ 1¸öIFÄ£°å²å²Û
6ES7 414-3EM05-0AB0 CPU414-3PN/DP 1.4M³ÌÐòÄÚ´æ/1.4MÊý¾ÝÄÚ´æ 1¸öIFÄ£°å²å²Û
6ES7 416-2XN05-0AB0 CPU416-2,2.8M³ÌÐòÄÚ´æ/2.8MÊý¾ÝÄÚ´æ
6ES7 416-3XR05-0AB0 CPU416-3,5.6M³ÌÐòÄÚ´æ/5.6MÊý¾ÝÄÚ´æ 1¸öIFÄ£°å²å²Û
6ES7 416-3ER05-0AB0 CPU416-3PN/DP 5.6M³ÌÐòÄÚ´æ/5.6MÊý¾ÝÄÚ´æ 1¸öIFÄ£°å²å²Û
6ES7 416-2FN05-0AB0 CPU416F-2,2.8M³ÌÐòÄÚ´æ/2.8MÊý¾ÝÄÚ´æ
6ES7 416-3FR05-0AB0 CPU416F-3PN/DP,5.6M³ÌÐòÄÚ´æ/5.6MÊý¾ÝÄÚ´æ
6ES7 417-4XT05-0AB0 CPU417-4,15M³ÌÐòÄÚ´æ/15MÊý¾ÝÄÚ´æ
Äڴ濨
6ES7 955-2AL00-0AA0 2 X 2M×Ö½Ú RAM
6ES7 955-2AM00-0AA0 2 X 4M×Ö½Ú RAM
6ES7 952-0AF00-0AA0 64K×Ö½Ú RAM
6ES7 952-1AH00-0AA0 256K×Ö½Ú RAM
6ES7 952-1AK00-0AA0 1M×Ö½Ú RAM
6ES7 952-1AL00-0AA0 2M×Ö½Ú RAM
6ES7 952-1AM00-0AA0 4M×Ö½Ú RAM
6ES7 952-1AP00-0AA0 8M×Ö½Ú RAM
6ES7 952-1AS00-0AA0 16M×Ö½Ú RAM
6ES7 952-1AY00-0AA0 64M×Ö½Ú RAM
6ES7 952-0KF00-0AA0 64K×Ö½Ú FLASH EPROM
6ES7 952-0KH00-0AA0 256K×Ö½Ú FLASH EPROM
6ES7 952-1KK00-0AA0 1M×Ö½Ú FLASH EPROM
6ES7 952-1KL00-0AA0 2M×Ö½Ú FLASH EPROM
6ES7 952-1KM00-0AA0 4M×Ö½Ú FLASH EPROM
6ES7 952-1KP00-0AA0 8M×Ö½Ú FLASH EPROM
6ES7 952-1KS00-0AA0 16M×Ö½Ú FLASH EPROM
6ES7 952-1KT00-0AA0 32M×Ö½Ú FLASH EPROM
6ES7 952-1KY00-0AA0 64M×Ö½Ú FLASH EPROM
¿ª¹ØÁ¿ÊäÈëÄ£°å
6ES7 421-7BH01-0AB0 ¿ª¹ØÁ¿ÊäÈëÄ£¿é(16µã,24VDC)ÖжÏ
6ES7 421-1BL01-0AA0 ¿ª¹ØÁ¿ÊäÈëÄ£¿é(32µã,24VDC)
6ES7 421-1EL00-0AA0 ¿ª¹ØÁ¿ÊäÈëÄ£¿é(32µã,120VUC)
6ES7 421-1FH20-0AA0 ¿ª¹ØÁ¿ÊäÈëÄ£¿é(16µã,120/230VUC)
6ES7 421-7DH00-0AB0 ¿ª¹ØÁ¿ÊäÈëÄ£¿é(16µã,24Vµ½60VUC)
¿ª¹ØÁ¿Êä³öÄ£°å
6ES7 422-1BH11-0AA0 ¿ª¹ØÁ¿Êä³öÄ£¿é(16µã,24VDC£¬2A£©
6ES7 422-1BL00-0AA0 32µãÊä³ö£¬24VDC,0.5A
6ES7 422-7BL00-0AB0 32µãÊä³ö£¬24VDC,0.5A,ÖжÏ
6ES7 422-1FH00-0AA0 16µãÊä³ö£¬120/230VAC£¬2A
6ES7 422-1HH00-0AA0 16µãÊä³ö£¬¼ÌµçÆ÷£¬5A
Ä£ÄâÁ¿Ä£¿é
6ES7 431-0HH00-0AB0 16·ģÄâÊäÈ룬13λ
6ES7 431-1KF00-0AB0 8·ģÄâÊäÈ룬13룬¸ôÀë
6ES7 431-1KF10-0AB0 8·ģÄâÊäÈ룬14룬¸ôÀ룬ÏßÐÔ»¯
6ES7 431-1KF20-0AB0 8·ģÄâÊäÈ룬14룬¸ôÀë
6ES7 431-7QH00-0AB0 16·ģÄâÊäÈ룬16룬¸ôÀë
6ES7 431-7KF00-0AB0 8·ģÄâÊäÈ룬16룬¸ôÀ룬Èȵçż
6ES7 431-7KF10-0AB0 8·ģÄâÊäÈ룬16룬¸ôÀ룬Èȵç×è
6ES7 432-1HF00-0AB0 8·ģÄâÊä³ö£¬13룬¸ôÀë
¹¦ÄÜÄ£°å
6ES7 450-1AP00-0AE0 FM450-1¼ÆÊýÆ÷Ä£°å
6ES7 451-3AL00-0AE0 FM451¶¨Î»Ä£°å
6ES7 452-1AH00-0AE0 FM452µç×Ó͹ÂÖ¿ØÖÆÆ÷
6ES7 453-3AH00-0AE0 FM453¶¨Î»Ä£°å
6ES7 455-0VS00-0AE0 FM455C±Õ»·¿ØÖÆÄ£¿é
6ES7 455-1VS00-0AE0 FM455S±Õ»·¿ØÖÆÄ£¿é
6DD1 607-0AA2 FM 458-1DP¿ìËÙ´¦Àíϵͳ
6ES7 953-8LJ20-0AA0 ÓÃÓÚFM458-1DP »ù±¾Ä£°å 512KByte(MMC)
6ES7 953-8LL20-0AA0 ÓÃÓÚFM458-1DP »ù±¾Ä£°å 2MByte(MMC)
6ES7 953-8LM20-0AA0 ÓÃÓÚFM458-1DP »ù±¾Ä£°å 4MByte(MMC)
6DD1 607-0CA1 EXM 438-1 I/OÀ©Õ¹Ä£°å
6DD1 607-0EA0 EXM 448 ͨѶÀ©Õ¹Ä£°å
6DD1 607-0EA2 EXM 448-2 ͨѶÀ©Õ¹Ä£°å
6DD1 684-0GE0 SC64Á¬½ÓµçÀÂ
6DD1 684-0GD0 SC63Á¬½ÓµçÀÂ
6DD1 684-0GC0 SC62Á¬½ÓµçÀÂ
6DD1 681-0AE2 SB10¶Ë×ÓÄ£¿é
6DD1 681-0AF4 SB60¶Ë×ÓÄ£¿é
6DD1 681-0EB3 SB61¶Ë×ÓÄ£¿é
6DD1 681-0AG2 SB70¶Ë×ÓÄ£¿é
6DD1 681-0DH1 SB71¶Ë×ÓÄ£¿é
6DD1 681-0AJ1 SU12¶Ë×ÓÄ£¿é
6DD1 681-0GK0 SU13¶Ë×ÓÄ£¿é
ͨѶģ°å
6ES7 440-1CS00-0YE0 CP440ͨѶ´¦ÀíÆ÷
6ES7 441-1AA04-0AE0 CP441-1ͨѶ´¦ÀíÆ÷
6ES7 441-2AA04-0AE0 CP441-2ͨѶ´¦ÀíÆ÷
6ES7 963-1AA00-0AA0 RS232C½Ó¿ÚÄ£°å
6ES7 963-2AA00-0AA0 20mA½Ó¿ÚÄ£°å
6ES7 963-3AA00-0AA0 RS422/485½Ó¿ÚÄ£°å
6ES7 870-1AA01-0YA0 ¿É×°ÔØÇý¶¯ MODBUS RTU Ö÷Õ¾
6ES7 870-1AB01-0YA0 ¿É×°ÔØÇý¶¯ MODBUS RTU ´ÓÕ¾
6GK7 443-5FX02-0XE0 CP443-5»ù±¾ÐÍͨѶ´¦ÀíÆ÷,Ö§³ÖProfibus-FmsЭÒé
6GK7 443-5DX04-0XE0 CP443-5À©Õ¹ÐÍͨѶ´¦ÀíÆ÷,Ö§³ÖProfibus-DPЭÒé
6GK7 443-1EX11-0XE0 CP443-1 ÒÔÌ«ÍøÍ¨Ñ¶´¦ÀíÆ÷
6GK7 443-1EX41-0XE0 CP443-1 ¸ß¼¶ÒÔÌ«ÍøÍ¨Ñ¶´¦ÀíÆ÷
¸½¼þ
6ES7 960-1AA04-0XA0 ÈßÓàϵͳͬ²½Ä£°å£¨Ð£©½ü¾àÀëͬ²½£¨10Ã×ÒÔÄÚ£©
6ES7 960-1AB04-0XA0 ÈßÓàϵͳͬ²½Ä£°å£¨Ð£©Ô¶³Ìͬ²½Ä£°å£¨10Ã×µ½10¹«ÀÓÃͬ³¤¶ÈµÄ¹âÀ£©
6ES7 960-1AA04-5AA0 ÈßÓàϵͳ¹âÏËÁ¬½ÓµçÀ£¨1Ã×£©£¨Ð£©
6ES7 960-1AA04-5BA0 ÈßÓàϵͳ¹âÏËÁ¬½ÓµçÀ£¨2Ã×£©£¨Ð£©
6ES7 960-1AA04-5KA0 ÈßÓàϵͳ¹âÏËÁ¬½ÓµçÀ£¨10Ã×£©£¨Ð£©
6ES7 833-1CC01-0YA5 S7Fϵͳ¿ÉÑ¡Èí¼þ°ü
6ES7 833-1CC00-6YX0 FÔËÐÐÊÚȨ
6ES7 197-1LA03-0XA0 Y-LINK
6ES7 492-1AL00-0AA0 ǰÁ¬½ÓÆ÷
6ES7 400-1TA01-0AA0 Ö÷°å(18²Û)
6ES7 400-1JA01-0AA0 Ö÷°å(9²Û)
6ES7 400-1TA11-0AA0 Ö÷°å(18²Û)ÂÁ°å
6ES7 400-1JA11-0AA0 Ö÷°å(9²Û)ÂÁ°å
6ES7 401-2TA01-0AA0 CR2Ö÷°å£¨18²Û£©
6ES7 400-2JA00-0AA0 UR2-HÖ÷°å£¨18²Û£©
6ES7 400-2JA10-0AA0 UR2-HÖ÷°å£¨18²Û£©ÂÁ°å
6ES7 403-1TA01-0AA0 ER1»ú¼Ü£¨18²Û£©
6ES7 403-1JA01-0AA0 ER2»ú¼Ü£¨9²Û£©
6ES7 403-1TA11-0AA0 ER1»ú¼Ü£¨18²Û£©ÂÁ°å
6ES7 403-1JA11-0AA0 ER2»ú¼Ü£¨9²Û£©ÂÁ°å
6ES7 460-0AA01-0AB0 IM460-0
6ES7 461-0AA01-0AA0 IM461-0
6ES7 468-1AH50-0AA0 Á¬½ÓµçÀ  (0.75Ã×£©
6ES7 468-1BB50-0AA0 Á¬½ÓµçÀ (1.5Ã×£©
6ES7 461-0AA00-7AA0 ÖÕ¶ËÆ÷
6ES7 460-1BA01-0AB0 IM460-1
6ES7 461-1BA01-0AA0 IM461-1
6ES7 468-3AH50-0AA0 468-3Á¬½ÓµçÀ  (0.75Ã×£©
6ES7 468-3BB50-0AA0 468-3Á¬½ÓµçÀ (1.5Ã×£©
6ES7 460-3AA01-0AB0 IM460-3
6ES7 461-3AA01-0AA0 IM461-3
6ES7 468-1BF00-0AA0 468-1Á¬½ÓµçÀ£¨5Ã×£©
6ES7 468-1CB00-0AA0 468-1Á¬½ÓµçÀ£¨10Ã×£©
6ES7 468-1CC50-0AA0 468-1Á¬½ÓµçÀ£¨25Ã×£©
6ES7 468-1CF00-0AA0 468-1Á¬½ÓµçÀ£¨50Ã×£©
6ES7 468-1DB00-0AA0 468-1Á¬½ÓµçÀ£¨100Ã×£©
6ES7 461-3AA00-7AA0 ÖÕ¶ËÆ÷
6ES7 463-2AA00-0AA0 IM463-2½Ó¿ÚÄ£¿é
6ES7 964-2AA04-0AB0 IF-964 DP½Ó¿ÚÄ£¿é
, class=xl85 width=233>EXM 448-2 ͨѶÀ©Õ¹Ä£°å
ͨѶģ°å
¸½¼þ
¹«Ë¾Ãû³Æ£º ÉϺ£ØÂΌ¤Òµ¿ØÖÆÉ豸ÓÐÏÞ¹«Ë¾
µç »°£º 021 60346029 / ³ÂºÆ
ÊÖ»ú£º 13482833481
µØ Ö·£º Ëɽ­ÇøÎijÇ·¼ÎºÌÉÌÎñÖÐÐÄ358Ū1407ÊÒ
ÓÊ ±à£º 261620
Ö÷ Ò³£º http://www.gkong.com/products/pro_content.asp?products_id=1352431
  • Î÷ÃÅ×ÓËÅ·þÇý¶¯
  • Î÷ÃÅ×Ó×ÜÏßµçÀÂPROFIBUS DP×ÜÏß
  • Î÷ÃÅ×Ó1PH/1FNÖ÷Öáµç»ú
  • ÊÖ³Öʽµ¥ÔªB-MPIÐÍ
  • Î÷ÃÅ×ÓËÅ·þÇý¶¯Æ÷
  • Î÷ÃÅ×ÓÐÂÆÁ
  • ´¥ÃþÆÁ10´ç6AV6648
  • Î÷ÃÅ×ÓËÅ·þµç»ú
  • Î÷ÃÅ×Ó½»Á÷µ÷ËÙÆ÷
  • Î÷ÃÅ×ÓDP×ÜÏß½ÓÍ·
