EPXNѹÁ¦´«¸ÐÆ÷The EPXN is a high performance small pressure sensor using silicon chip for clean media (non corrosive).With it's recessed port, it is best recommended for static applications or low frequency. Available with 10-32UNForM5 thread, EPXN is available with a cable or integral connector. Offered in pressure ranges from 5 to 150 psi (0.3 to 10 bar), vented and absolute pressure.Various compensated temperature ranges are available from -40¡ãC up to 90¡ãC. The sensor is offered with an amplified or unamplified output.
ËùÊôÆ·ÅÆ£º Entran
Êä³ö£º 50-75 mV »ò 5 Vdc
Á¿³Ì£º 0-5¡«150£¨Psi£©
·â×°£º²»Ðâ¸ÖÍâ¿Ç·â×°
¹¤×÷ζȷ¶Î§£º-40¡æ~120¡æ
¾«È·¶È£º0.1% FSO
¹©µçµçÔ´£º5~30V(ÊÓÊä³ö¶ø¶¨)
ÌØµã£º³¤ÆÚÎȶ¨ÐԺ㬰¼Ä¤Æ¬£¬ÂÝÎÆ½Ó¿Ú
ÀàÐÍ£º±íѹ¡¢¾øÑ¹
µçÆøÁ¬½Ó£ºµçÀÂ
µäÐÍÓ¦Ó㺠ʵÑé»ú¡¢·ÉÐÐÆ÷¡¢Ó£¬¸Éʽ¾²Ì¬Ñ¹Á¦³¤ÆÚÎȶ¨ÐÔÄܼà²â
×ÊÁÏÏÂÔØ£º
http://www.sensorway.cn/sensors/20.html
