EPXO压力传感器 The EPXO is a high performance, stainless steel flush diaphragm. It is designed for high temperature,high stability, and high sensitivity applications. The EPXO is offered in pressure ranges from 10 to 500 bar in gage (vented), sealed gage, and absolute pressure. Various compensated temperature ranges are available from-40°C up to 200°C. The sensor is offered with an amplified or unamplified output.
所属品牌: Schaevitz
输出: 9 mV或 5 Vdc
量程: 0-150~7500(Psi)
封装:高精度
工作温度范围:-40℃~220℃
精确度:0.25% FSO
供电电源:5~30V(视输出而定)
特点:高频动态响应,适应于高温环境
类型:表压、绝压
电气连接: 电缆
典型应用: 飞行器,油井,发动机,实验机 ,空气和气压系统,工程机械
资料下载:http://www.sensorway.cn/sensors/19.html
