免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → ST-4012,SR-4012光幕
产品名称: ST-4012,SR-4012光幕
型 号: ST-4012,SR-4012
价 格: 0.00
品 牌:
SUN WANG安全光幕ST-4012,SR-4012,SK-4016R,SK-4020R
韩国鲜光SUN KWANG SK-2008R,SK-2016R,SK-4012R
Model
SK-2008R
SK-2012R
SK-2016R
SK-2020R
SK-2024R
SK-2028R
SK-2032R
SK-2036R
SK-2040R
Transmitter
ST-2008R
ST-2012R
ST-2016R
ST-2020R
ST-2024R
ST-2028R
ST-2032R
ST-2036R
ST-2040R
Receiver
SR-2008R
SR-2012R
SR-2016R
SR-2020R
SR-2024R
SR-2028R
SR-2032R
SR-2036R
SR-2040R
Dectection
Through-beam
Range
7m (Max)
Object
Ø32mm(Min) Opaque object (Refer to the chart below right)
No. of optical axis
8
12
16
20
24
28
32
36
40
Detecting width
140mm
220mm
300mm
380mm
460mm
540mm
620mm
700mm
780mm
optical axis
20mm
Power Current consumption(Max)
12V-24V DC±10%, Ripple 10% (Max)
60mA
80mA
90mA
100mA
110mA
120mA
130mA
140mA
150mA
Output mode
NPN Open collector
Rating
Current output : Sink current 100mA, DC30V (Max)
Response time
15msec (Max)
Light source
Infrared LED, Wave-length 95mm
sensing cell
Photo-transistor
LED indicator
Transmitter : Power indicator (Green LED, Red LED)
Receiver : Stability indicator (Green LED), Operation indicator (Red LED)
Incidental Function
Built-in Output short circuit protection, discontinuity of transfer line protection and function preventing interference when installing in parallel.
Material
Case : Aluminum, Front cover and Lens : Acrylic
Connection
Connector 0.5sq X 4, Output dia.Ø6.0, 0.3m length, With 4 pins in the connector(*)
Weight
(max)
Trns
192g
245g
285g
340g
390g
445g
485g
540g
580g
Rcvr
192g
245g
285g
340g
390g
445g
485g
540g
580g
Notes
* All models has a PNP output type.
MODEL
A
B
C
D
SK - 4004R
235
215
179
114
SK - 4006R
334
314
221
190
SK - 4008R
410
390
321
266
SK - 4010R
486
466
379
342
SK - 4012R
562
542
479
418
SK - 4014R
638
618
521
494
SK - 4016R
714
694
621
570
SK - 4018R
790
770
679
646
SK - 4020R
866
846
779
722
SK - 4022R
942
922
821
798
SK - 4024R
1018
998
921
874
公司名称: 深圳市创丰仪器仪表有限公司
电 话: 0755 29796001-806 / 钱军辉
手机: 13143436561
地 址: 深圳市宝安九区白金酒店商务大厦1001-1002室
邮 编: 518052
主 页: www.Lansea.net
  • ZCMD25施耐德限位开关组件
  • 施耐德ZCMD21限位开关零部件
  • XCM-D2516L3施耐德限位开关零部件
  • XCM-D2516L1限位开关零部件
  • Panasonic松下GD-C1双层重叠检测器
  • 全新原装松下聚焦镜FX-LE2
  • omron欧姆龙W4S1-03B可编程控制器
  • omron欧姆龙E39-R3不锈钢外壳小型光电传感器
  • OMRON欧姆龙D4E-1D10N 限位开关
  • KEYENCE基恩士光幕电源线GL-RP10P
