Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú CM362-7AÃÀ¹úCTC¸ßμÓËÙ¶È´«¸ÐÆ÷
²úÆ·Ãû³Æ£º CM362-7AÃÀ¹úCTC¸ßμÓËÙ¶È´«¸ÐÆ÷
ÐÍ ºÅ£º CM362-7AÃÀ¹úCTC¸ßμÓËÙ¶È´«¸ÐÆ÷
Æ· ÅÆ£º 1012
CM362-7A,HA602-A050£¬HA602-A100£¬HA602-V100
ÃÀ¹úCTCÕñ¶¯¼ÓËÙ¶È´«¸ÐÆ÷AC102£¬AC104£¬AC184£¬AC188£¬AC230£¬VE101,VE102,LP202,LP204£¬LP802£¬AC806
ÐͺÅ
CM362-7A
HA602-A050
HA602-A100
HA602-V100
ÃèÊö
High Temperature Accelerometer, 650F (343 C) Top Exit Flexible Hardline Integral Cable 25 pC/g
Charge Amplifier for use with CM362 High Temperature Accelerometers, 50 mV/g Acceleration Output
Charge Amplifier for use with CM362 High Temperature Accelerometers, 100 mV/g Acceleration Output
Charge Amplifier for use with CM362 High Temperature Accelerometers, 100 mV/IPS Velocity Output
ÁéÃô¶È
25 pC/g
50 mV/g
100 mV/g
100 mV/IPS
ƵÂÊÏìÓ¦ (¡À3dB)
N/A
N/A
N/A
N/A
¶¯Ì¬·¶Î§
+ - 50 g, peak when combined with HA602-100A
+ - 50 g, peak
+ - 50 g, peak
+/- 50 IPS, peak
µçѹԴ¹©µç·¶Î§ÒªÇó
NA
18-30 VDC
18-30 VDC
18-30 VDC
ζȷ¶Î§
-40 ~ 343¡ãC
-40 ~ 121¡ãC
-40 ~ 121¡ãC
-40 ~ 121¡ãC
Íâ¿Ç²ÄÁÏ
300 Series Stainless Steel
Á¬½ÓÍ·
2 Pin MIL-C-5015
2 Pin MIL-C-5015
2 Pin MIL-C-5015
2 Pin MIL-C-5015
×î¸ßζÈ
343¡ãC
121¡ãC
121¡ãC
121¡ãC
¹«Ë¾Ãû³Æ£º ÉϺ£»ú½ÝʵҵÓÐÏÞ¹«Ë¾
µç »°£º 021 13116719459 / Íõº£¸£
ÊÖ»ú£º 15201780835
µØ Ö·£º ÆÖ¶«ÐÂÇø³Â´ºÂ·222Ū
ÓÊ ±à£º 200051
Ö÷ Ò³£º http://
  • LE100/1-0063´Å±àÂëÆ÷SIKO´ÅÕ¤¶ÁÊýÍ·¹âÕ¤³ß
  • DA04λÖÃÏÔ/ָʾÆ÷SIKO¼ÆÊýÆ÷ELESAÊýÏÔ±íDD51
  • DA02λÖÃÏÔ/ָʾÆ÷SIKO¼ÆÊýÆ÷DD50ÏÔʾÆ÷ELESA
  • DA10λÖÃÏÔ/ָʾÆ÷SIKO¼ÆÊýÆ÷
  • DA08-2185¼ÆÊýÆ÷SIKOλÖÃָʾÆ÷ÏÔʾÆ÷
  • DA05/1Êý×ÖλÖÃָʾÆ÷SIKOÏÔʾÆ÷¼ÆÊýÆ÷
  • DA09SλÖÃÏÔ/ָʾÆ÷SIKO¼ÆÊýÆ÷ELESAÊýÏÔ±íDD52R
  • MSK1000-0256´ÅÕ¤³ß¶ÁÊýÍ·SIKO¹âÕ¤±àÂëÆ÷
  • MSK200/1-0085´ÅÕ¤³ß¶ÁÊýÍ·SIKO¹âÕ¤±àÂëÆ÷
  • MSK500AS-0004/5´ÅÕ¤¶ÁÊýÍ·SIKO¹âÕ¤±àÂëÆ÷´Å³ßMB500AS
