EGCS加速度传感器:The Model EGCS accelerometers combine a damping ratio of 0.7 (Nominal) with built-in overange stops that are set to protect the unit against 10,000 g shocks. This is ideal for applications which may experience rough handling or in situations where the accelerometer must survive a high initial overload in order to make a low g measurement. These units feature a Wheatsone Bridge output with compensated temperature range of 20 to 80°C.
所属品牌: Entran
输出: ±200mV
量程: ±5 ,±10 ,±25 ,±50 ,±100 ,±250 ,±500 ,±1000 ,±2500 ,±5000g
封装:不锈钢
工作温度范围: -40℃ ~ 125℃
精确度:1% FSO(非线性)
供电电源:15 VDC
特点:同时具有高灵敏度和重型结构, 在没有放大器的情况下它可以输出100mV/g的高精度数值,过载保护可达10,000g,CE认证
类型:螺钉安装
电气连接:电缆连接
典型应用: 飞行测试,机械设备,破坏性测试,发动机测试
资料下载:
http://www.sensorway.cn/sensors/110.html
