Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú AIA1800-200-04
²úÆ·Ãû³Æ£º AIA1800-200-04
ÐÍ ºÅ£º AIA1800-200-04
FEATURES & BENEFITS
¡ö Layer the Ethernet communication over the fieldbus wires
¡ö Compatible with all Ethernet ready I/O modules
¡ö Simple Plug-and-Play installation
¡ö 168-bit Tri-DES encryption for secure data transmission
¡ö Robust housing compliant to IP-67 standard
¡ö Supports Industrial operating temperature
¡ö DIN-Rail ready mounting installation
¡ö Ident-and-Connect™ feature allows ease of network setup and monitoring
¡ö Web configurable
¡ö Up to 300 meters of operational distance
¡ö Compliance with IEEE802.3, IEEE802.3u
OVERVIEW
The traditional Ethernet network cabling for the industrial automation I/O device network requires the deployment of new CAT5 wiring in addition to the legacy I/O process and control infrastructure. This addition of another paralleled wiring infrastructure at the I/O network level increase the Total Cost of Ownership (TCO) and on going operational maintenance expenditures. Aboundi¡¯s patent pending AIA1800-200 series of EtherHighway™ Industrial Ethernet NetBridge™ allows a Plug-and-Play simplicity utilizing the existing robust floor DC power electrical wiring as means of providing the network service. The Aboundi solution dramatically reduce the Total Cost of Operation (TCO) with its product line installation flexibility.
The robust AIA1800-200 NetBridge™ enclosure is designed to withstand the harsh industrial operating environments and comes with the IP67 RJ45 and M12 male connectors.
SPECIFICATIONS
Compliance:
‧ IEEE802.3 10BASE-T
‧ IEEE802.3u 100BASE-TX
Interface
‧ IP-67 RJ-45 Connector
‧ Micro Type M12 Male Connector
Access Methods:
‧ TDMA
Encryption:
‧ 168-bit Tri-DES algorithm
Nodes:
‧ Supports up to 15 nodes per network domain
Mechanical:
‧ W x D x H : 1.3 x 3.2 x 3.1 inch / 34 x 82 x 80 mm
‧ Weight : 0.6 lb / 260 g
LED:
‧ Power LED: Green ( PWR )
                    On: Power On Off: Power Off
‧ Status LED:
      PowerLine :
      Blue ( LNK/ACT)         On : Link speed over 12 Mbps
      Purple ( LNK/ACT)     On : Link speed between 6-12 Mbps
      Amber ( LNK/ACT)     On : Link speed under 6 Mbps
                                         Blink : Activity
     Ethernet Ports : Green ( LNK/ACT )
                         On : Link       Blink : Activity
Environmental:
‧ Water and Dust Resistance: IP67
‧ Temperature
     Operating :-40 ~ +85¡æ/ -40~ +185¡ãF
     Storage : -50 ~ +90¡æ/ -58 ~ +194¡ãF
‧ Humidity
     Operating : 0 ~ 95% RH (condensing)
     Storage : 0 ~ 95% RH (condensing)
Power Supply:
‧ Input rating : 12-30VDC, Power Consumption: 4Watt
Surge Protection:
‧ 2KV, EN6100-4-5; Power and I/O Isolated Design
Certification:
‧ EMI: FCC Class A, CE
‧ EMS: EN6100-4-2, EN6100-4-3, EN6100-4-4, EN6100-4-5, EN6100-4-6, EN6100-4-8, EN6100-4-11
‧ MTBF: 200,000 Hours
ORDERING INFORMATION
AIA1800-200-04: IP67 Industrial Ethernet NetBridge
Ethernet over Industrial Power Line, Ethernet over high voltage power line, Ethernet over Powerline, Ethernet over High Voltage DC, Industrial Ethernet over High Voltage DC, Ethernet over Industrial High Voltage DC
¹«Ë¾Ãû³Æ£º ÉîÛÚÊа¬Àñ¸»ºìÍâ¼¼ÊõÓÐÏÞ¹«Ë¾
µç »°£º 0755 88822665 / ³ÂºêÃÀ
ÊÖ»ú£º 13620999597
µØ Ö·£º ÉîÛÚÊÐÄÏÉ½ÇøÄϺ£´óµÀÔÁº£´óÏÃB×ù10A
ÓÊ ±à£º 518054
Ö÷ Ò³£º http://www.szaleph.cn/
  • AIA1801-200-04
  • AIA1800-200-04
