Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Ö±Á÷µçÄܱí
²úÆ·Ãû³Æ£º Ö±Á÷µçÄܱí
ÐÍ ºÅ£º DCM3366P(DV DA)
Æ· ÅÆ£º 10453
Ò»¡¢¸ÅÊöGeneral
¡ô DCM3366P(DV+DA)Ö±Á÷µçÄܱí¸ù¾ÝÎÒ¹ú¶ÔµçÁ¦É豸ÔËÐкͼÆËã»úÖÇÄÜ»¯¼à¿ØÒªÇó¶ø
Éè¼Æ£¬Äܹ»Ö±½Ó²âÁ¿ÏÔʾϵͳµÄÓõçÁ¿ºÍÀúÊ·ÓõçÁ¿£¬²¢´øÓÐRS485 ½Ó¿Ú£¬Óë΢»ú½øÐÐÊý¾Ý½»
»»¡£ÊʺÏÐîµç³Ø£¬Ì«ÑôÄÜµç³Ø°åµÈÖ±Á÷ÐźÅÉ豸µçÁ¿²âÁ¿ºÍµçÄܼÆÁ¿Ê¹Óã¬Òà¿ÉÓÃÓÚ¹¤¿óÆóÒµ£¬
ÃñÓý¨Öþ£¬Â¥Óî×Ô¶¯»¯µÈÏÖ´ú¹©ÅäÖ±Á÷µçϵͳ¡£¡£DCM3366P(DV+DA) DC energy meter is able to
directly measure the display system power consumption and electricity history. The RS485
port can exchange data with the microcomputer. It is suitable to be used for batteries, solar
panels power DC signal measurement and energy metering equipment. Be used for industrial
and mining enterprises, civil construction, building automation and other modern DC system for distribution.
DCM3366 ϵÁвúÆ·ÓжàÖÖ²»Í¬Ðͺţ¬²úÆ·¹¦ÄÜÖڶ࣬¿ÉÂú×ãĿǰ¹úÄÚÍⲻͬ³¡ºÏµÄÌØÊâÒªÇó¡£
DCM3366 series provides many different types of products which can meet domestic and international market
specific requirements.
DCM3366P(DV+DA)¿É²âÁ¿ÈçϲÎÊýMeasure the following parameters:
􀁺 ʵʱֱÁ÷µçѹ¡¢Ö±Á÷µçÁ÷¡¢Ö±Á÷¹¦ÂʺÍÖ±Á÷µçÄÜ¡£
Real time measure DC voltage¡¢DC current¡¢DC power and DC energy.
􀁺 ÉÏ12 ÔÂÿÔ¶ÀÁ¢ÀۼƵçÄÜ¡¢¹ýÈ¥360 ÌìÿÌì¶ÀÁ¢ÀۼƵçÄÜ¡£
Independent cumulative energy of each day in the past 12 months monthly, independent cumulative energy of
each day in the past 360 days.
􀁺 Ò»¶Îʱ¼äÄÚ×î´óÐèÁ¿¡¢×îСÐèÁ¿¡£
􀁺 The max & min demand in a period of time.
􀁺 Á½Â·¿ª¹ØÁ¿ÊäÈë
Two switching value inputs (DI)
¶þ¡¢Ö÷Òª¼¼ÊõÖ¸±êTechnical indicators
¡ô DCM3366P(DV+DA)ÍâÐÎExternality
􀂗 Ö÷»ú³ß´çHost size£º 96¡À 0.5 mm¡Á96¡À0.5 mm¡Á98¡À0.5mm
􀂗 ¿ª¿×³ß´çHole size£º 92¡À0.5 mm¡Á92¡À0.5 mm
􀂗 ÏÔʾÀàÐÍDisplay type£º LCD ÏÔʾDisplay£¬8 λÓÐЧλÊý8-bit effective number bits
DV ÊäÈëInput
􀂗 DC4~20mA ÏÔʾ°´Óû§ÒªÇó¶©ÖÆCustomized
DA ÊäÈëInput
¹¦ÂÊPower
􀂗 ¹¦ÂÊPower£º0~9999.0000kW
ʱÖÓClock
􀂗 ²Î±ÈÌõ¼þÏ£¬ÈÕ¼ÆÊ±Îó²îСÓÚ0.5 ÃëUnder the reference conditions, the timing error is less than 0.5 seconds
􀂗 ¾ßÓй㲥¶Ôʱ¹¦ÄÜWith broadcasting timing function
ͨѶCommunication
􀂗 ½Ó¿ÚInterface£º RS485
􀂗 ²¨ÌØÂÊBaud rate£º 1200/2400/4800/9600/19200£¨³ö³§Ä¬ÈÏDefault £º9600bps£©
􀂗 ͨѶЭÒ飺Modbus (RTU ¸ñʽ)ºÍ DL/T645 ˫ЭÒé
Communication protocol: Modbus (RTU format) & DL/T645 double protocol)
²âÁ¿¾«¶ÈAccuracy
􀂗 µçÁ÷Current£º 0.5%
􀂗 µçѹVoltage£º 0.5%
􀂗 ¹¦ÂÊPower £º 1.0%
􀂗 µçÄÜEnergy£º 1.0%
¾øÔµÇ¿¶ÈInsulating Strength
􀂗 ÊäÈë/µçÔ´/Íâ¿Ç¼ä: Among input voltage / Power / Frame £º 2.0kV/min¡¤2mA
􀂗 ͨѶ¿Ú/µçÔ´¼ä£ºBetween communication port / Power : 2.0kV/min¡¤2mA
¹¤×÷Ìõ¼þWorking Conditions
􀂗 ¹¤×÷ζÈWorking temperature£º-10¡æ~55¡æ
􀂗 ´¢´æÎ¶ÈStorage temperature£º-40¡æ~70¡æ
􀂗 Ïà¶Ôʪ¶ÈRelative humidity£º 20~95£¥RH ÎÞÄý¶(Without condensation)
¸¨ÖúµçÔ´Auxiliary Power Supply
􀂗 AC85~265V or DC85~330V
􀂗 ¹¦ºÄPower Consumption£º¡Ü2VA
Èý¡¢DCM3366P(DV+DA)ÏÔʾ²Ù×÷Display Operating
ÿ´ÎÉϵçÏÔʾΪÈÕÆÚ»­Ã棬°´¼üÒÀ´ÎÏÔʾΪ£º¹¦ÂÊ¡¢µçÁ÷¡¢µçѹ¡¢µçÄÜ¡¢Ê±¼ä¡¢ÈÕÆÚ£»°´¼üÒÀ´ÎÏÔʾΪ£ºÊ±¼ä¡¢µç
ÄÜ¡¢µçѹ¡¢µçÁ÷¡¢¹¦ÂÊ¡¢ÈÕÆÚ¡£ÈôûÓа´¼ü²Ù×÷£¬³¬¹ýÉ趨µÄÑÓʱģʽÇл»Ê±¼äÔò½øÈë×Ô¶¯Ñ­»·ÏÔʾ״̬£¨ÂÖÏÔʱ¼ä£¬³ö³§
ĬÈÏÖµ£º60s£©,LCD ÏÔʾÊý¾ÝÆÁÓû§¿ÉÒÔ¸ù¾ÝÒªÇó×Ô¼ºÉ趨,¾ßÓÐÍ£µç³­±í¹¦ÄÜ¡£
The screen shows the date when the power is on. Press Power to display: power, current, voltage, energy, time,
date; Press key to display: time, energy, voltage, current, power, date. If there is no button operation and preset value
is overtime, it will enter the cycle display statues (default value: 60s), the display data on the LCD can be requested by the
customers. Meter reading function when power off .
¹«Ë¾Ãû³Æ£º °ÙÈð˳£¨±±¾©£©µçÆøÓÐÏÞ¹«Ë¾
µç »°£º 010 80480064 / ÎâÊ÷ÏÍ
ÊÖ»ú£º 13811807437
µØ Ö·£º ±±¾©ÊÐÃÜÔÆ¾­¼Ã¿ª·¢Çø
ÓÊ ±à£º 101500
Ö÷ Ò³£º http://www.bjbrs.com
  • ÖÇÄÜÂí´ï±£»¤Æ÷(BRS2302T)
  • ¶à¹¦ÄܵçÁ¦ÒDZíBRS194E
  • ÖÇÄܵç»ú±£»¤Æ÷BRS2310F
  • ÖÇÄܵçÁ÷±íBRS194I
  • ÖÇÄܵç»ú±£»¤Æ÷(BRS2321-L1/2)
  • ÖÇÄܵç»ú±£»¤Æ÷BRS2320-TL1/2
  • ÖÇÄܵç»ú±£»¤Æ÷BRS2310G
  • ¹©Ó¦Âí´ï±£»¤Æ÷
  • ÈýÏàµçÁ÷±íBRS194I-9K4Y
  • ¹©Ó¦²âÁ¿¹â·üÖ±Á÷¶à¹¦ÄÜÊýÏÔ±í
