产品名称: EAC-0945A工控单板
型  号: EAC-0945A
Features
  • ARM926EJ-S CPU、400MHz Processor core
  • 64MB DDR2 RAM,128MB SLC Nand
  • Interfaces: Ethernet, 2xUSB 2.0 host(High Speed), 6xUSART,MicroSD, LCD/LVDS/TFT, IIC,SPI, I/O ports
  • WM8731L 24BIT AUDIO
  • IS1208 RTC WITH BATTERY
  • OS Linux2.6 /wince 6.0 pre-installed
  • SIZE:96x90MM(PC104 Standard)
Specifications
FUNCTION
EAC-0945
Kernel
CPU
ATMEL AT91SAM9G45,ARM926EJ-S,400MHz
System RAM
64MB DDR2
Flash
128MB (up to 256MB)
Graphic Chip
16-bit LCD controller by CPU
Rtc
YES
Watchdog Timer
YES
Power Management
NO
Exernal Reset
H/W reset & S/W reset (by ADM706R)
I/O
UART
TTL level x6 (4-wire x1 & 2-wire x4)
Ethernet LAN
10/100Mbps
USB 2.0 Client
1
USB 2.0 Host
2
SD/MMC
1(4-wire)
Touch
1(4-wire resistive type)
System bus
no
IIC interface
1
SPI interface
1
GPIO
12-pin 3.3V TTL level GPIOs
IIS
1
KEYPAD
8x8 matrix keypad expand via IIC interface(optional)
Multimedia
Graphic Chip
CPU internal 24-bit LCD controller
Resolution
Max 1280×860、24bits(320 x 240 ~ 1280 x 860 as optional)
LCD interface
16-bit TTL/16-bit LVDS connector
Audio
Headphone out and Mic in
Power
Power input
5.0 VDC (+-5%) & 12.0 VDC (+-5%, for backlight)
Power Consumption
TBD
Mechanical & Environment
Board Size
96x90MM
Weight
TBD
Operating Temperature
-20 ~ 70° C (-40 ~85° C by project base)
Operating Humidity
5 ~ 95 % relative humidity, non-condensing
Other
RoHS
YES
Certifications
CE/FCC Class A
Software Support
Embedded Linux 2.6 (WCE6.0 by project support)
关 键 词: ARM9 工控主板 ATMEL
公司名称: 深圳盈鹏飞科技有限公司
联 系 人: 廖阳
电  话: 0755-82523175-816
手  机: 13926597054
地  址: 深圳市福田区福明路雷圳大厦12A06
邮  编: 518033
COM-9G45核心模块(COM-9G45)
