Î÷ÃÅ×ÓDPµçÀ²åÍ·£º
FastConnect ²åÍ·²ÉÓþøÔµ´ÌÆÆÁ¬½Ó¼¼Êõ£¬¿ÉÈ·±£¼«¶ÌµÄ×éװʱ¼ä
¼¯³É¶Ë½Óµç×è (6ES7 972-0BA30-0XA0 Öв»¾ßÓÐ)
ͨ¹ý´ø Sub-D ½Ó¿ÚµÄÁ¬½ÓÆ÷¿ÉÒÔÁ¬½Ó±à³ÌÆ÷£¬ÎÞÐè¶îÍâ°²×°ÍøÂç½Úµã
Area of application
ÓÃÓÚ PROFIBUS µÄ RS485 ×ÜÏßÁ¬½ÓÆ÷£¬¿ÉÓÃÓÚÁ¬½Ó PROFIBUS ½Úµã»ò PROFIBUS ÍøÂ粿¼þµ½ PROFIBUS ×ÜÏßµçÀ¡£
Design
ÌṩÓи÷ÖÖÀàÐ͵Ä×ÜÏßÁ¬½ÓÆ÷£¬¿ÉÓÅ»¯ÓÃÓÚÁ¬½ÓµÄÉ豸£º
×ÜÏßÁ¬½ÓÆ÷¾ßÓÐÖáÏòµçÀÂÒý³öÏߣ¨180¡ã£©£¬¿ÉÓÃÓÚÈç PC ºÍ SIMATIC HMI OP£¬´«ÊäËÙÂʸߴï 12 Mbit/s£¬´ø¼¯³ÉµÄ×ÜÏ߶˽ӵç×è
´ø´¹Ö±µçÀÂÒý³öÏßµÄ×ÜÏßÁ¬½ÓÆ÷£¨90¡ã£©£»
ÕâÖÖ½ÓÍ·²ÉÓô¹Ö±µçÀÂÒý³öÏߣ¨ÓлòûÓбà³ÌÆ÷½Ó¿Ú£©£¬Êý¾Ý´«ÊäËÙÂʸߴï 12 Mbit/s£¬´ø¼¯³ÉµÄÖն˵ç×è¡£´«ÊäËÙÂÊΪ 3¡¢6 »ò12 Mbit/s ʱ£¬ÔÚ´ø±à³ÌÆ÷½Ó¿ÚµÄ×ÜÏß½ÓÍ·ºÍ±à³ÌÆ÷Ö®¼ä£¬ÐèҪʹÓà SIMATIC S5/S7 Á¬½ÓµçÀ¡£
ÓÐ 30¡ãµçÀÂÒý³öÏßµÄ×ÜÏß½ÓÍ·£¨¾¼ÃÐÍ£©£¬ÎÞ±à³ÌÆ÷½Ó¿Ú£¬Êý¾Ý´«ÊäËÙÂÊ×î´óΪ 1.5 Mbit/s£¬ÎÞ¼¯³ÉµÄ×ÜÏ߶˽ӵç×è¡£
PROFIBUS ¿ìËÙÁ¬½Ó RS485 ×ÜÏß½ÓÍ·£¨90¡ã»ò 180¡ãµçÀÂÒý³öÏߣ©£¬´«ÊäËÙÂÊ×î´óΪ 12Mbit/s£¬²ÉÓþøÔµ´ÌÆÆ¼¼Êõ¿ÉʵÏÖ¿ìËÙ¼òµ¥°²×°£¨ÓÃÓÚÓ²ÏߺÍÈíÏߣ©¡£
Functions
×ÜÏßÁ¬½ÓÆ÷¿ÉÖ±½Ó²åÈëµ½ PROFIBUS Õ¾»ò PROFIBUS ÍøÂç×é¼þµÄ PROFIBUS ½Ó¿Ú£¨9 Õë Sub-D ½Ó¿Ú£©ÖС£
¿ÉʹÓà 4 ¸ö¶Ë×ÓÔÚ²åÍ·ÖÐÁ¬½Ó½øÈëºÍÀ뿪µÄ PROFIBUS µçÀ¡£
ͨ¹ý´ÓÍⲿÇåÎú¿É¼ûµÄ±ãÓÚ½Ó´¥µÄ£¬¿ÉÒÔÁ¬½Ó×ÜÏßÁ¬½ÓÆ÷Öм¯³ÉµÄ×ÜÏß¶Ë½ÓÆ÷£¨²»ÊÊÓÃÓÚ 6ES7 972-0BA30-0XA0£©¡£Ôڴ˹ý³ÌÖУ¬Á¬½ÓÆ÷ÖеĽøÏߺͳöÏß×ÜÏßµçÀÂÊÇ·Ö¿ªµÄ£¨¸ôÀ빦ÄÜ£©¡£
±ØÐëÔÚ PROFIBUS Íø¶ÎµÄÁ½¶Ë½øÐÐÕâÖÖÁ¬½Ó¡£
Î÷ÃÅ×ÓDP½ÓÍ· Î÷ÃÅ×ÓDP×ÜÏßÁ¬½ÓÆ÷ Î÷ÃÅ×ÓDP×ÜÏß½ÓÍ·
Î÷ÃÅ×Ó¿ìËÙÁ¬ÏßÍøÂç½ÓÍ·£¨²»´ø±à³Ì¿Ú£©¶©»õºÅ£º6ES7 972-0BA50-0XA0
SIMATIC DP,BUS CONNECTOR FOR PROFIBUS UP TO 12 MBIT/S 90 DEGREE ANGLE CABLE OUTLET, 15,8 X 72,2 X 36,4 MM (WXHXD), IPCD TECHOLOGY FAST CONNECT, WITHOUT PG SOCKET
¿ìËÙÁ¬ÏßÍøÂç½ÓÍ·£¨´ø±à³Ì¿Ú£©¶©»õºÅ£º6ES7 972-0BB50-0XA0
SIMATIC DP, BUS CONNECTOR FOR PROFIBUS UP TO 12 MBIT/S 90 DEGREE ANGLE CABLE OUTLET, 15,8 X 72,2 X 36,4 MM (WXHXD), IPCD TECHOLOGY FAST CONNECT, WITH PG SOCKET
90¶ÈÍøÂç½ÓÍ·£¨²»´ø±à³Ì¿Ú£©¶©»õºÅ£º6ES7 972-0BA12-0XA0
SIMATIC DP£¬ ×ÜÏßÁ¬½ÓÆ÷£¬ÓÃÓÚPROFIBUS£¬¸ß´ï12 MBIT/S£¬90¶È³öÏßµçÀ£¨W X H X D£©£º15£¬8 X 54 X 34 MM£¬¶Ë½Óµç×裬´ø¸ôÀë
90¶ÈÍøÂç½ÓÍ·£¨´ø±à³Ì¿Ú£©¶©»õºÅ£º6ES7 972-0BB12-0XA0
SIMATIC DP£¬ ×ÜÏßÁ¬½ÓÆ÷£¬ÓÃÓÚPROFIBUS£¬¸ß´ï12 MBIT/S£¬90¶È³öÏßµçÀ£¨W X H X D£©£º15.8 X 54 X 34 MM£¬¶Ë½Óµç×裬´ø¸ôÀë
Î÷ÃÅ×Ó35¶ÈÍøÂç½ÓÍ·£¨²»´ø±à³Ì¿Ú£©¶©»õºÅ£º6ES7 972-0BA41-0XA0
SIMATIC DP£¬ ×ÜÏßÁ¬½ÓÆ÷£¬ÓÃÓÚPROFIBUS£¬¸ß´ï12 MBIT/S£¬´øÐ±³öÏßµçÀ£¨W X H X D£©£º16 X 54 X 34 MM£¬¶Ë½Óµç×裬´ø¸ôÀë
35¶ÈÍøÂç½ÓÍ·£¨´ø±à³Ì¿Ú£©¶©»õºÅ£º6ES7 972-0BB41-0XA0
Î޽ǶÈÍøÂç½ÓÍ·¶©»õºÅ£º6GK1 500-0EA02
PB BUS CONNECTOR WITH AXIAL CABLE OUTLET F.INDUSTR. PC, SIMATIC OP, OLM; TRANSMISSION RATE 12 MBIT/S; TERMINATING RESISTOR WITH SEPARATING FUNCTION, METAL HOUSING
Î޽ǶȿìËÙÁ¬ÏßÍøÂç½ÓÍ·£¨²»´ø±à³Ì¿Ú£©¶©»õºÅ£º6GK1 500-0FC00
SIMATIC NET, PB FC RS 485 PLUG 180,PB CONNECTOR W. FASTCONNECT CONNECTOR A. AXIAL CABLE OUTLET FOR INDUSTRIAL PC''''S, SIMATIC OP, OLM,TRANSFER RATE 12 MBIT/S TERMINATING RESISTOR WITH SEPARAT. FUNCTION, PLASTIC HOUSING
³ÏОӪ¡¢ÖÊÁ¿Îª±¾¡¢Ô¸½»Î÷ÃÅ×Ó¹¤¿ØÏµÁвúÆ·³¤ÆÚºÏ×÷»ï°é!
±¾¹«Ë¾ËùÊÛµÄÎ÷ÃÅ×Ó²úÆ·¶¼ÊÇÔ×°½ø¿Ú£¬È«Ð°ü×°£¬ÏÖ»õ¹©Ó¦£¬ÖÊÁ¿±£Ö¤µÄ
ÉϺ£ÌÚÏ£µçÆø¼¼ÊõÓÐÏÞ¹«Ë¾¾ß±¸ÈçÏÂÒµÎñÓÅÊÆ£º
SIEMENS PLC¡¡¡¡1¡¢ SIMATIC S7 ϵÁÐPLC¡¢S7200¡¢S7200Smart¡¢s71200¡¢S7300¡¢S7400¡¢ET200
¡¡¡¡2¡¢ Âß¼¿ØÖÆÄ£¿é LOGO£¡230RC¡¢230RCO¡¢230RCL¡¢24RC¡¢24RCLµÈ
¡¡¡¡3¡¢ SITOP ϵÁÐÖ±Á÷µçÔ´ 24V DC 1.3A¡¢2.5A¡¢3A¡¢5A¡¢10A¡¢20A¡¢40A
4¡¢HMI ´¥ÃþÆÁTD200 TD400C TP177,MP277 MP377 SMART700 SMART1000
SIEMENS ½»¡¢Ö±Á÷´«¶¯×°ÖÃ
¡¡¡¡1¡¢ MICROMASTERϵÁУºMM¡¢MM420¡¢MM430¡¢MM440¡¢ECO
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡MIDASTERϵÁУºMDV
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡6SE70ϵÁУ¨FC¡¢VC¡¢SC£©
¡¡¡¡2¡¢È«Êý×ÖÖ±Á÷µ÷ËÙ×°Öà 6RA23¡¢6RA24¡¢6RA28¡¢6RA70 ϵÁÐ
SIEMENS Êý¿Ø ËÅ·þ
1¡¢Êý¿ØÏµÍ³£º840D¡¢802S/C¡¢802SL¡¢828D 801D £º6FC5210,6FC6247,6FC5357,6FC5211,6FC5200,6FC5510,
2¡¢ËÅ·þϵͳ£º 611U: 6SN1123,6SN1145,6SN1146,6SN1118,6SN1110,6SN1124,6SN1125,6SN1128¡¢
3¡¢ËÅ·þϵͳ£ºS120: 6SL304¡¢6SL3210¡¢6SL3130¡¢6SL3055¡¢6SL3054
