产品名称:
台湾阳明方形接近开关PL-08N,PL-08P
型 号:
PL-08N,PL-08P
价 格:
品 牌:
28
输出方式 |
感应距离 |
安裝安式 |
感应方向 |
工作電壓 |
反應頻率 |
PL-05N/QL-05N |
NPN |
5.0mm |
Flushed |
Horizontal |
10~30VDC |
800HZ |
PL-05P |
PNP |
PL-08N |
NPN |
8.0mm |
Non-Flushed |
PL-08P |
PNP |
PS-05N |
NPN |
5.0mm |
Flushed |
Horizontal |
10~30 |
800HZ |
PS-05P |
PNP |
VDC |
PS-08N |
NPN |
8.0mm |
Non-Flushed |
PS-08P |
PNP |
PS-04N-V |
NPN |
4.0mm |
Non-Flushed |
Vertical |
10~30 |
PS-04P-V |
PNP |
VDC |
PS-04N |
NPN |
4.0mm |
Horizontal |
2KHZ |
PS-04P |
PNP |
LS-04N-V |
NPN |
4.0mm |
Non-Flushed |
Vertical |
10~30 |
2KHZ |
LS-04P-V |
PNP |
VDC |
LS-04N |
NPN |
Horizontal |
LS-04P |
PNP |
BS-02N |
NPN |
2.0mm |
Flushed |
Vertical |
10~30 |
2KHZ |
BS-02P |
PNP |
VDC |
BS-04N |
NPN |
4.0mm |
Non-Flushed |
BS-04P |
PNP |
SP-05N |
NPN |
5.0mm |
Non-Flushed |
Vertical |
10~30VDC |
800HZ |
SP-05P |
PNP |
PP-05N |
NPN |
5.0mm |
Flushed |
Vertical |
10~30VDC |
800HZ |
PP-05P |
PNP |
PP-08N |
NPN |
8.0mm |
Non-Flushed |
PP-08P |
PNP |
PS-05S |
SCR |
5.0mm |
Flushed |
Horizontal |
90~250VAC |
20HZ |
PS-08S |
SCR |
8.0mm |
Non-Flushed |
PS-10N |
NPN |
10.0mm |
Flushed |
Horizontal |
10~30VDC |
500HZ |
PS-10P |
PNP |
PS-15N |
NPN |
15.0mm |
Non-Flushed |
PS-15P |
PNP |
PS-10S |
SCR |
10.0mm |
Flushed |
Horizontal |
90~250VAC |
20HZ |
SP-05N |
NPN |
5.0mm |
Non-Flushed |
Vertical |
10~30VDC |
800HZ | |
SP-05P |
PNP |
PP-05N |
NPN |
5.0mm |
Flushed |
Vertical |
10~30VDC |
800HZ |
PP-05P |
PNP |
PP-08N |
NPN |
8.0mm |
Non-Flushed |
PP-08P |
PNP |
PS-05S |
SCR |
5.0mm |
Flushed |
Horizontal |
90~250VAC |
20HZ |
PS-08S |
SCR |
8.0mm |
Non-Flushed |
PS-10N |
NPN |
10.0mm |
Flushed |
Horizontal |
10~30VDC |
500HZ |
PS-10P |
PNP |
PS-15N |
NPN |
15.0mm |
Non-Flushed |
PS-15P |
PNP |
PS-10S |
SCR |
10.0mm |
Flushed |
Horizontal |
90~250VAC |
20HZ |
