AI-1664LA-LPE是PCI Express(Low Profile)总线100KSPS 16位模拟量输入接口板
AI-1664LAX-USB是USB 100KSPS 16位模拟量输入单元
AIO-121601E3-PE是PCI Express总线 100KSPS 12位模拟量I/O接口板
AI-1664LA-LPE是PCI Express(Low Profile)总线100KSPS 16位模拟量输入接口板,This product is a Low Profile, PCI Express bus-compliant interface board used to provide an analog signal input function on a PC. This product is multi-channels and multifunction type with 16-bit analog input 64 channels (single-ended input 64 channels or differential input 32 channels), digital I/O and counter function. This product carries buffer memory for 1K of data, allowing sampling to be performed in a variety of trigger / clock conditions. Windows/Linux driver and full-fledged data logger software [C-LOGGER] is bundled with this product.
AI-1664LAX-USB是USB 100KSPS 16位模拟量输入单元,This product is a USB2.0-compliant analog input unit that extends the analog input function of USB port of PCs. This product is multi-channels and multifunction type with 16-bit analog input 64 channels (single-ended input 64 channels or differential input 32 channels), digital I/O and counter function. This product carries buffer memory for 1K of data, allowing sampling to be performed in a variety of trigger / clock conditions.
AIO-121601E3-PE是PCI Express总线 100KSPS 12位模拟量I/O接口板,This product is an unisolated PCI Express bus-compliant interface board that expands the I/O function of a PC for analog signals. This product carries high-capacity buffer memory for 16MB of data for analog input, allowing background sampling to be performed in a variety of trigger conditions.
