产品名称: hetronik加热控制系统,Hetronik控制器,Hetronik加热卡
型  号: HC500-CU-HN
hetronik加热控制系统,Hetronik控制器,加热控制卡,Hetronik Gmbh,hetronik控制模块,hetronik输入模块,hetronik CUP单元,hetronik输出卡,hetronik机架,hetronik输出模块,hetronik输出单元,HC500产品系列已经取代了先行者的产品HC100,HC200,HC300,HC400,但是HC100,HC200,HC300,HC400将继续被生产,以确保全球上千台机器备件供应
hetronik加热器优点:需要更少的空间相比,HC解决方案更加便宜
HC的应用:产品广泛应用于热成型机,PET吹瓶机,干燥/固化(即漆)或一般材料加热
HC500-CU-HN;
HC500-CU-HCOM;
HC500-CU-2DP;
HC500-CU-DP;
HC500-CU;
HC500-CU-HN;
HC500-CU;
HC500-CU-HN;
HC500-CU-DP;
HC500-CU-DP;
HC500-CU-HCM100;
HC500-CU-HN;
HC500-VU-230;
HC500-VU-480;
HC-BUS-CAB;
HC510-OC-230-16
HC200-HN-12
HC200-HN-24
HC200-HN-12
HC200-HN-24
HC200-HN-12
HC100-3-HN-9 输出模块
HC200-HN-24
HC200-HN-24
HC200-HN-24
HC 510-0C-230-10-S
HC200-FU-230
HC200-HN-24
HC200-HN-24
HC-SI-63-5x20
HC200-FU-230
HC200-HN-24
HCM 100-HN-12
HC 200-HN-24
HCM100-HN-8
HCM100-HN-12
HC200-HN-24
HC200-HN-12
FF6.3AHetronik
HC100-3-HN-9
HC500-CU-2DP
HC510-0C-230-16-I
HC510-RK-8-230
HC500-VU-230
HC510-OC-230-16
HC510-CU
HC510-VU-230
HC-BUS-CON-R
HC-BUS-CON-L
HCBUS-JC-SET
HC510-RK-8-230
HC-BUS-CON;
HC510-OC-230-16;
HC510-OC-230-16-S;
HC510-OC-230-16-I;
HC510-OC-230-16-SL;
HC500-CON-230-16;
HC510-OC-230-16;
HC510-OC-230-16-S;
HC510-OC-230-10;
HC510-OC-230-10-I;
HC510-OC-230-10-S ;
HC510-OC-230-10-SL;
HC500-OC-230-168;
HC510-OC-230-10;
HC500-OC-230-168-S;
HC510-OC-230-10-SL;
HC510-OC-480-12;
HC510-OC-480-12-I;
HC510-OC-480-12-SL;
HC510-RK-4-230;
HC510-RK-4-110;
HC510-RK-8-230;
HC510-RK-8-110;
HC510-RK-FU-110;
HC510-RK-FU-230;
HC510-RK-4;
HC510-RK-4-230;
HC510-RK-8 ;
HC510-RK-8-230 ;
HC510-RK-8-110;
HC510-SC;
HC500-OM-230-3;
HC500-OM-230-3-HS;
HC500-OM-230-3-SL;
HC500-OM-230-3-HS-SL;
HC500-OM-480-3 ;
HC500-OM-480-3-HS;
HC500-OM-480-3-SL;
HC500-OM-480-3-HS-SL;
HC500-OM-FU-24;
HC-SI-63-5X20;
HC510-OC-230-16
HC-SI-100-5X20 ;
HC510-OC-230-16-S;
HC-SI-125-6X32 ;
HC510-OC-230-10;
HC510-OC-480-12-SL;
HC-SI-160GRL-6X32 ;
HC510-OC-230-10-S
HC-SI-160F-6X32;
HC510-OC-230-10-I
HC-SI-63-6X32;
HC510-OC-480-12
HC510-OC-230-12-I
HC-SI-200-6X32;
HC500-TU-8-PT100;
HC500-TU-8-PT100-PID;
关 键 词: 加热控制系统 控制器 加热控制卡
公司名称: 上海语力实业有限公司
联 系 人: 李力
电  话: 21-61559965
手  机:
地  址: 虹口区武昌路559号C楼124室
邮  编: 200085
hydac贺德克压力传感(HDA 4445-B-060-000)
TWK编码器CE58-0(CE58-0180EC01)
Kissling开关 D(D-72215)
