̨Íå–¥³Ï¹«Ë¾¶«Ý¸–¥³Ïµç×Óרҵ´Óʸ÷ϵÁзÀË®¿ª¹ØµÄÉú²úÒÑÓÐ20¶àÄêµÄÀúÊ·£¬ÎÒ˾·ÀË®¿ª¹ØµÄÊÙÃüÓëÐÔÄÜÒѾ×ßÉϹú¼Ê·Ïߣ¬Ö÷Òª²úÆ·ÓУ¬12MM·ÀË®¿ª¹Ø£¬¸´Î»·ÀË®¿ª¹Ø£¬´øµÆ·ÀË®¿ª¹Ø£¬×ÔËø·ÀË®¿ª¹Ø£¬Îª¸ö¾ü¹¤ÆóÒµ£¬Æû³µÖÆÔìÉÌ£¬º£ÉÏÔËÊ乤¾ßµÈÌṩ¸ßÆ·ÖÊ·ÀË®°´Å¥¿ª¹Ø£¬¸÷¿ª¹Ø¾ù²»½öͨ¹ýIP67·ÀË®·À³¾²âÊÔ£¬²¢ÇÒͨ¹ýÎÒ˾¾ü¹¤ÆóÒµ¿Í»§×ö¹ý·À±¬²âÊÔ£¬¾ùͨ¹ý¿¼Ñ飡
·ÀË®¿ª¹Ø£¬·ÀË®°´Å¥¿ª¹Ø£¬·ÀË®°´¼ü¿ª¹Ø¼ò½é£º·ÀË®IP67°´Å¥¿ª¹ØIP67 waterproof Push button switch£¬·ÀË®°´¼ü¿ª¹Ø£¬¸´Î»·ÀË®°´¼ü¿ª¹Ø£¬´øµÆ·ÀË®°´¼ü¿ª¹Ø£¬¸ßÆ·ÖÊ·ÀË®´øµÆ°´Å¥¿ª¹Ø¼¼Êõ²ÎÊý¼ò½é
£¨IP67£©SPECIFICATIONSMax. current/voltage rating with resistive load: 100mA 24VDC INITIAL CONTACT RESISTANCE: 100 mΩ max.INSULATION RESISTANCE: 1 GΩ min. at 500VDC.DIELETRIC STRENGTH: 1,000 VAC rms.ELECTRICAL LIFE AT FULL LOAD: 200,000 cycles. PANEL THICKNESS: Series:1.5 mm (.059) min. - 4 mm (.157) max.TOTAL TRAVEL: 2.5 mm(.098). OPERATING FORCE: 4.5N~6.5N.CONTACT BOUNCE: 10 ms.TORQUE: 0.5 Nm max. applied to nut.SOLDERING: 350°C max. for 5 seconds.°´Å¥¿ª¹ØÊǾɱê×¼ÓÃÊõÓбê×¼£¨GB2900·18£©Öмò³ÆÎª°´Å¥¡£
¡¡¡¡°´Å¥¿ª¹ØÊÇÓÃÀ´ÇжϺͽÓͨ¿ØÖƵ緵ĵÍѹ¿ª¹ØµçÆ÷¡£°´Å¥¿ª¹ØµÄ´¥Í·µÄ¶î¶¨µçÁ÷Ϊ5A¡£ËùÒÔ£¬²Ù×÷°´Å¥¿ª¹ØËù¿ØÖƵĵç·ÊôÓÚСµçÁ÷µç·¡£
¡¡¡¡°´Å¥Óе¥¼«Ë«Î»¿ª¹Ø»òË«¼«Ë«Î»¿ª¹Ø£¬Ëü°´¶¯ÄÜÓëÓÃ;ÓÖ·ÖΪÆð¶¯°´Å¥¡¢¸´Î»°´Å¥¡¢¼ì²é°´Å¥¡¢¿ØÖư´Å¥¡¢ÏÞλ°´Å¥µÈ¶àÖÖ¡£
¡¡¡¡°´Å¥Óж¯ºÏ£¨³£¿ª£©ºÍ¶¯¶Ï£¨³£±Õ£©Ö®·Ö¡£
¡¡¡¡Î¢ÐͰ´Å¥Óõ¼µçÏ𽺻ò½ðÊôƬµÈ×÷µ¼Ì壬¿É×÷Ϊ״̬ѡÔñ¿ª¹Ø£¬ÓÃÓÚСÐͰ뵼ÌåÊÕÒô»ú¡¢Ò£¿ØÆ÷¡¢Ñé³®Æ÷µÈ²úÆ·ÖС£
ÎÒ¹«Ë¾Éú²úµÄ¸÷·ÀË®¿ª¹Ø£¬·ÀË®°´Å¥¿ª¹Ø£¬×ÔËø·ÀË®°´Å¥¿ª¹Ø£¬´øµÆ·ÀË®°´µçÆøÊÙÃü50Íò´Î£¬»úеÊÙÃü100Íò´Î ·À³¾£¡·ÀË®£¡·À±¬£¡Å¥¿ª¹Ø¾ù¿ÉÔÚË®ÖÐÕý³£¹¤×÷£¡
