Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Agilent 81594B Ä£¿é
²úÆ·Ãû³Æ£º Agilent 81594B Ä£¿é
ÐÍ ºÅ£º 81594B
Agilent 81594B  Ä£¿é
Key Features & Specifications
Key performance specifications:
·         Insertion Loss < 1.5dB
·         Guaranteed lifetime > 10 Mio. cycles
·         PDL < 0.05dB for single-mode option
·         Highest repeatablity specified over 10.000 random switch cycles: 0.02dB
Description
The plug-in module for Agilent's Lightwave Solution Platform 8163B, 8164B, 8166B is ideal for flexible system configuration in applications such as transceiver/receiver test with small foot-print or multiple passive component test with complex cascade. The Agilent modular design of the optical switch features a 2x2 matrix in both SMF and MMF with low insertion loss and highly repeatable switch routing in <10 ms switching time.
Routing of various optical sources such as laser in various wavelenght range and routing of various optical receiver such as power sensor, oscilloscope, BERT.
Features:
Benefits:
·         Using one test setup for testing DUTs in all transmission bands.
·         Minimize test uncertainties, maximize power budget enables higher production yield an highly competitive product specifications
·         Minimize test times - maximize production throughput.
·         Minimal influence on transmitted signal.
¹«Ë¾Ãû³Æ£º ÉîÛÚÊж«²â¿Æ¼¼ÓÐÏÞ¹«Ë¾
µç »°£º 0755 88859217 / »ÆÎÄ¿¡
ÊÖ»ú£º 13928415151
µØ Ö·£º ÉîÛÚÊÐÁú»ªÐÂÇøÈËÃñÄÏ·À³ÃÉˮ鿴ºÌì7¶°·ï»ËÔ·24C/24D
ÓÊ ±à£º 518131
Ö÷ Ò³£º http://www.itestworld.com
  • E4808A
  • E4805B
  • 8703A
  • 86145B
  • 86140B
  • 86120C
  • 86112A
  • 86105C
  • 86105B
  • 86105A
