C41гÕñµçÈÝÆ÷
ÐͺÅ
¹æ¸ñ
¼Û¸ñ(Ôª£©
³ß´ç£¨mm)
C41
0.68vF/300KVAC
400
80*80*36.5V 700Vrms
¼Û¸ñ½ö¹©²Î¿¼£¬ÒÔ±¨¼Ûµ¥Îª×¼¡£
Ö÷ÒªÓ¦ÓÃ/Application
¹ã·ºÓ¦ÓÃÓÚ´ó¹¦ÂÊµÄ¸ßÆµÐ³ÕñÉ豸ÖÐ
Widely used in high power high frequency resonant device
²úÆ·ÌØµã/Characteristics
µç½éÖÊ£º¾Û±ûÏ©±¡Ä¤
½á¹¹£ºÂÁ²¡¢½ðÊô»¯Ä¤ÄÚ´®½á¹¹
·â×°£ºÍ°å
¸ßµçѹ¡¢¸ßƵÂÊ¡¢¸ßdv/dtÌØÐÔ
ÄܳÐÊÜ´óµçÁ÷£¬É¢ÈÈÐÔÄܺÃ
Dielectric£ºPolypropylene film
Structure: aluminum foil, metal film inner series structure
Package: Copper
High voltage, high frequency, high dv/dt characteristics
Can bear high current, good heat radiation performance
¼¼ÊõÐÔÄÜ/Specifications
ÒýÓñê×¼/Reference standards
GB/T 17702 IEC 61071 GB/T 12747
¹¤×÷ζȷ¶Î§/Operating temperature range
-40¡æ¡«85¡æ
ÈÝÁ¿·¶Î§/Capacitance
0.24μF¡«1.2μF
ÈÝÁ¿Æ«²î/Tolerance
±5% ±10%
¼«¼äÄ͵çѹ/Test voltage between terminals
5.0Ur10s 25¡æ±5¡æ
¼«¿ÇÄ͵çѹ/Test voltage between terminals and case
6000Vac»ò9000Vdc 50Hz 60s£¬25¡æ±5¡æ
ËðºÄ½ÇÕýÇÐ/Dissipation factor
tgδ≤5×10-4 at 25¡æ±5¡æ£¬1kHz
¾øÔµµç×è/Insulation resistance
R≥200000MΩ£¬at 500Vdc£¬25¡æ±5¡æ£¬60s
Ô¤ÆÚÊÙÃü/Life expectancy
200000h at Ur and 70¡æ£¬30000h at Urms
´Ë²úÆ·¹Ø¼ü×Ö£º¸ßƵ¸ßѹгÕñµçÈÝ¡¢Ð³Õñµç·µçÈݵŦÄÜ¡¢Ð³ÕñµçÈݵÄÓ°Ïì
»ªÔ£µçÈÝ-¸ßÆ·ÖʽðÊô»¯±¡Ä¤µçÈÝ×¨ÒµÖÆÔìÉÌ
