IP67·ÀË®´øµÆ5Ïò¼üµ¼º½¿ª¹Ø£¬General SpecificationsÒ»°ã¹æ¸ñ:
Switch Circuit¿ª¹Øµç· :SP5T
Current Rating¶î¶¨µçÁ÷ :µçÁ÷£º50mA
Voltage Rating¶î¶¨µçѹ :12VDC
Dielectric Withstanding VoltageÄ͵çѹ :250VAC for 1 minute£º250VAC1·ÖÖÓ
Contact Resistance½Ó´¥µç×è :1 Ohm Max.(initial)£º×î´ó1Å·Ä·£¨³õʼ£©
Insulation Resistance¾øÔµµç×è :100M Ohm Min.£º100MÅ·Ä·×îС¡£
Operating Force²Ù×÷Á¦ :400gf 100gf£º
Total Travel×ÜÐÐ³Ì 1.0mm 0.3mm£º1.0ºÁÃ×0.3ºÁÃ×
Operating Life¹¤×÷ÊÙÃü :100,000 cycles Min.£º100,000´Î×îС¡£
Operating Temperature¹¤×÷ζÈ:-10 deg.~+60
SF25WA waterproof
SF25WA series water-proof navigation push button switch module, the 5-key/5-way tactile switch module, integrated LED backlight on each Key, it easy for identify the status of equipment, and low body with seald especially for outdoor control panel or boats, bathroom equipment, swimming pool equipment.....somewher require water proof.SF25WA·ÀË®¿ª¹Ø
SF25WAϵÁзÀË®µ¼º½°´Å¥¿ª¹ØÄ£¿é£¬5-key/5-wayÇá´¥¿ª¹ØÄ£¿é£¬¼¯³ÉLED±³¹âÔ´ÉϵÄÿ¸ö°´¼ü£¬±ãÓÚʶ±ðÓëSEALDÌØ±ðÊʺϻ§Íâ¿ØÖÆÃæ°åÉ豸µÄ״̬£¬ÒÔ¼°µÍ°«µÄ³µÉí»ò´¬£¬ÎÀÔ¡É豸£¬Ó¾³ØÉ豸..... һЩÐèÒª·ÀË®µÄµØ·½¡£
*Panel cutting dia. 25mm.*Ãæ°åÇиװֱ¾¶¡£ 25mm´¦¡£
*IP67.*IP67·À³¾·ÀË®µÈ¼¶
*single LED for each key.*µ¥ÎªÃ¿¸ö¼üµÄLED¡£
*Metal Housing (stainless).*½ðÊôÍâ¿Ç£¨²»Ðâ¸Ö£©¡£
*FFC cable quickly install.* FFCÅÅÏß¿ìËÙ°²×°¡£
*offer Adapter for hand soldering using.*±¨¼ÛÊÊÅäÆ÷²ÉÓÃÊÖ¹¤º¸½Ó¡£
*Customize laster etching service.*Ϊ¿Í»§ÌṩÀØÉäµñ¿Ì·þÎñ¡£
Application
*Residential and Commercial audio-visual market*סլ¼°ÉÌÒµÒôÏñÊг¡
*Industrial equipment*¹¤ÒµÉ豸
*Traffic and Transportation *½»Í¨ÔËÊä
*Outdoor equipment *»§Íâ×°±¸
*Agricultural Market*ũҵÊг¡
*Defense*·ÀÓù
*Education*½ÌÓý
*Telecom Communications*µçÐÅͨѶ
