ACOPOS 伺服驱动
8V1010.50-2, 伺服驱动 3x 110- 230V / 1?x? 110- 230V?? 2.0A ?0.45?kW, 集成线路滤波器,制动电阻和安全重启抑制
8V1016.50-2, 伺服驱动 3x 110- 230V / 1?x? 110- 230V?? 3.2A ?0.7?kW, 集成线路滤波器,制动电阻和安全重启抑制
8V1010.00-2, 伺服驱动 3x 400- 480V ?1.0A ?0.45 kW, 集成线路滤波器,制动电阻和安全重启抑制
8V1016.00-2, 伺服驱动 3x 400- 480V ?1.6A ?0.7 kW, 集成线路滤波器,制动电阻和安全重启抑制
8V1022.00-2, 伺服驱动 3x 400- 480V ?2.2 A ?1kW,集成线路滤波器,制动电阻和安全重启抑制
8V1045.00-2, 伺服驱动 3x 400- 480V ?4.4 A ?2kW,集成线路滤波器,制动电阻和安全重启抑制
8V1090.00-2, 伺服驱动 3x 400- 480V ?8.8 A ?4kW,集成线路滤波器,制动电阻和安全重启抑制
8V1180.00-2, 伺服驱动 3x 400- 480V ?19A ?9kW, 集成线路滤波器,制动电阻和安全重启抑制,DC总线电源
8V1320.00-2, 伺服驱动 3x 400- 480V ?34A ?16kW, 集成线路滤波器,制动电阻和安全重启抑制,DC总线电源
8V1640.00-2, 伺服驱动 3x 400- 480V ?64A ?32kW, 集成线路滤波器,制动电阻和安全重启抑制,DC总线电源
8V128M.00-2, 伺服驱动 3x 400- 480V ?128A ?64kW, 集成线路滤波器,制动电阻和安全重启抑制,DC总线电源
5S0500.02 Automation
5S0500.02U Automation
5S0500.99 Automation
5S0510.01 Automation
5S0510.02 Automation
5S0510.02U Automation
5S0510.99 Automation
9S0001.29-020
9S0001.36-020
9S0001.32-020
9S0001.33-020
9S0001.34-020
9S0001.35-020
9S0000.08-010
9S0000.08-020
9S0000.09-090
9S0001.11-090
9S0001.24-020
9S0001.28-020
9S0001.22-020
9S0001.26-020
9S0001.25-020
5SWOSU.0000-EN
5SWOSU.0001-EN
5SWHMI.0000-00
5SWUTI.0000-00
5SWFON.0000-00
5SWFON.0001-00
5SWFON.0000-10
5SWFON.0001-10
