Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú PHISON SSD PATA½Ó¿Ú
²úÆ·Ãû³Æ£º PHISON SSD PATA½Ó¿Ú
ÐÍ ºÅ£º PHISON PS3016-P8
Product Features
 Form factor: 2.5”
 Supports host interface with IDE (PATA)
       512 Bytes/Sector
       ATA command set compatible
 Provides 4-channel performance1 for both SLC/MLC-based flash memory
       SLC2: Read/Write (MB/s) = 85/80
       MLC3: Read/Write (MB/s) = 85/65
 Max. capacity up to 512GB
 Intelligent ATA/IDE Module
 Built-in embedded flash file system
 Implemented with both dynamic and static wear-leveling algorithms to increase endurance of flash media
 Strong ECC hardware design, correcting up to 68-bit random error per 1K byte
 Both commercial/extensive grades are available.
 RoHS-Compliance/CE/FCC
 Selectable Master/Slave setting
Technical Specifications Support Data Transfer up to PIO 4, Multiword DMA 2, and UDMA 6
 Operating voltage: 3.3V and 5.0V
 Operating temperature: -40¡æ – +85¡æ
 Storage temperature: -45¡æ – +90¡æ
¹«Ë¾Ãû³Æ£º ±±¾©»ªºãΰҵ¿Æ¼¼·¢Õ¹ÓÐÏÞ¹«Ë¾
µç »°£º 010 82666337 / ÕÅÆäÈç
ÊÖ»ú£º 13910691377
µØ Ö·£º ±±¾©Êк£µíÇøÉϵØ10½Ö»Ô»Í¹ú¼Ê5ºÅÂ¥0516
ÓÊ ±à£º 100085
Ö÷ Ò³£º http://www.satassd.net
  • MT29F128G08CFAAAWP-IT
  • MICRON ¿íÎÂ16GB MLC FLASH
  • NVS 3600A SATA3½Ó¿Ú SSD
  • PHISON SSD PATA½Ó¿Ú
  • PHISON SSD SATA3½Ó¿Ú
