C42谐振电容器
型号
规格
价格(元)
尺寸(mm)
引出
C42
0.47vF/400V
4.5
31.5*10.5*19.5
d=1.0
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于高脉冲和高峰值电流场合。
Widely used in high pulse operation and high peak current circuits.
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:铝箔与金属化膜内串结构
封装:塑料外壳,阻燃(UL94V-0级)环氧封装
引出:镀锡铜线
能承受很高脉冲电流,很高dv/dt
ESR,ESL小
高稳定性
具有自愈性
Dielectric:Polypropylene film
Construction:Metal foils internal series connection and metalized film
Coating:Resistant plastic case with resin sealing.
Flame retardant execution(UL94V-0)
Terminals:Tinned copper lugs
Very high pulse current,Very high dv/dt
Self healing
技术性能/Specifications
引用标准/Reference standards
IEC 61071 60068
工作温度范围/Operating temperature range
-40℃~85℃
容量范围/Capacitance
0.0068μF~1.0μF
额定电压/Rated Voltage
600Vdc~2000Vdc
容量偏差/Tolerance
±5% ±10%
极间耐电压/Test voltage between terminals
2.0Ur(Vdc) 10s 25℃±5℃
极壳耐电压/Test voltage between terminals and case
3000V 50Hz 60s,25℃±5℃
损耗角正切/Dissipation factor
tgδ≤6×10-4 at 25℃±5℃,1kHz
绝缘电阻/Insulation resistance
C×R≥30000s,at 100Vdc,25℃±5℃,60s
预期寿命/Life expectancy
100000h at Un and 70℃
此产品关键字:高频高压谐振电容、谐振电路电容的功能、谐振电容的影响
华裕电容-高品质金属化薄膜电容专业制造商
