C43гÕñÒý»¡µçÈÝÆ÷
ÐͺÅ
¹æ¸ñ
¼Û¸ñ(Ôª£©
³ß´ç£¨mm)
Òý³ö
C43
402/3000VAC
200
50*60*30
¶Ë×Ó
¼Û¸ñ½ö¹©²Î¿¼£¬ÒÔ±¨¼Ûµ¥Îª×¼¡£
Ö÷ÒªÓ¦ÓÃ/Application
¹ã·ºÓ¦ÓÃÓÚ´¢ÄÜ¡¢Âö³å¡¢Õñµ´µç·£¬½»Á÷µçѹ¿É´ï6000V£¬Ê¹ÓÃÆµÂʿɴï30kHz¡£ÌرðÊÊÓÃÓÚµã»ðÒý»¡µçº¸»úÖС£
Widely used in energy, impulse, oscillation circuit, AC voltage up to 6000V, use a frequency of up to 30kHz. Especially suitable for igniting arc welder.
²úÆ·ÌØµã/Characteristics
µç½éÖÊ£º¾Û±ûÏ©±¡Ä¤
½á¹¹£ºÂÁ²¡¢½ðÊô»¯Ä¤ÄÚ´®½á¹¹
·â×°£º½ðÊôÍâ¿Ç£¬½þÓÍÈ«ÃÜ·â
Òý³ö£ºº¸Æ¬Òý³ö
¸ßµçѹ¡¢¸ß¾øÔµ¡¢µÍËðºÄ¡¢ÄÍÂö³å
°²È«·À±¬
¾ßÓÐ×ÔÓúÐÔ
Dielectric: polypropylene film
Structure: aluminum foil, metal film inner series structure
Package: metal shell, oil seal
Derivative: welding pieces
High voltage, high insulation, low loss, high pulse
Safety explosion-proof
Self healing
¼¼ÊõÐÔÄÜ/Specifications
ÒýÓñê×¼/Reference standards
GB/T 17702 IEC 61071 GB/T 12747
¹¤×÷ζȷ¶Î§/Operating temperature range
-55¡æ¡«85¡æ
ÈÝÁ¿·¶Î§/Capacitance
1000pF¡«4700pFat 25¡æ±5¡æ£¬10kHz
¶î¶¨µçѹ/Rated Voltage
3000Vac
ÈÝÁ¿Æ«²î/Tolerance
±5% ±10%
¼«¼äÄ͵çѹ/Test voltage between terminals
2.0UN10s 25¡æ±5¡æ
¼«¿ÇÄ͵çѹ/Test voltage between terminals and case
6000Vac»ò9000Vdc 50Hz 60s£¬25¡æ±5¡æ
ËðºÄ½ÇÕýÇÐ/Dissipation factor
tgδ≤5×10-4 at 25¡æ±5¡æ£¬10kHz
¾øÔµµç×è/Insulation resistance
R≥100000MΩ£¬at 500Vdc£¬25¡æ±5¡æ£¬60s
Ô¤ÆÚÊÙÃü/Life expectancy
200000h at Ur and 70¡æ£¬30000h at Urms
´Ë²úÆ·¹Ø¼ü×Ö£º
¸ßƵ¸ßѹгÕñµçÈÝ¡¢Ð³Õñµç·µçÈݵŦÄÜ¡¢Ð³ÕñµçÈݵÄÓ°Ïì
»ªÔ£µçÈÝ-¸ßÆ·ÖʽðÊô»¯±¡Ä¤µçÈÝ×¨ÒµÖÆÔìÉÌ
