Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú C52Ö±Á÷Ö§³ÅDC-Link/ñîºÏ¡¢Â˲¨µçÈÝÆ÷
²úÆ·Ãû³Æ£º C52Ö±Á÷Ö§³ÅDC-Link/ñîºÏ¡¢Â˲¨µçÈÝÆ÷
ÐÍ ºÅ£º C52
ÐͺÅ
¹æ¸ñ
¼Û¸ñ(Ôª£©
³ß´ç£¨mm)
Òý³ö
C52
15vF/700V
8
42.5*22*33  P=37.5
d=1.2
¼Û¸ñ½ö¹©²Î¿¼£¬ÒÔ±¨¼Ûµ¥Îª×¼¡£
Ö÷ÒªÓ¦ÓÃ/Application
¹ã·ºÓ¦ÓÃÓÚUPS¡¢SMPSs£¬Äæ±äµçÔ´¡¢º¸»úµçÔ´µÈÉ豸ÖÐÆðñîºÏ¸ôÖ±/Â˲¨»òDC-LinkÓá£
DC-Link and coupling/filtering for UPS£¬SMPSs£¬inverter£¬welding machine power.
²úÆ·ÌØµã/Characteristics
µç½éÖÊ£º¾Û±ûÏ©±¡Ä¤
½á¹¹£º½ðÊô»¯Ä¤¸Éʽ½á¹¹
·â×°£ºËÜÁÏÍâ¿Ç£¬×èȼ£¨94V-0¼¶£©»·Ñõ·â×°
Òý³ö£º¶ÆÎýÍ­ÏßÒý³ö
¸ßƵ¡¢µÍµç¸Ð
¸ßÎȶ¨ÐÔ
¾ßÓÐ×ÔÓúÐÔ
Dielectric£ºPolypropylene film
Construction£ºExtended  metalized  film £¬dry connection
Coating£ºResistant plastic case with resin sealing.
Flame retardant execution£¨UL94V-0£©
Terminals£ºTinned copper wire
High frequency£¬low inductance
High stability
Self healing
¼¼ÊõÐÔÄÜ/Specifications
ÒýÓñê×¼/Reference standards
GB/T 17702  IEC 61071
¹¤×÷ζȷ¶Î§/Operating temperature range
-40¡æ¡«85¡æ
ÈÝÁ¿·¶Î§/Capacitance
5.0μF¡«90μF
¶î¶¨µçѹ/Rated Voltage
500Vdc¡«1200Vdc
ÈÝÁ¿Æ«²î/Tolerance
±5%  ±10%
¼«¼äÄ͵çѹ/Test voltage between terminals
1.5Ur£¨Vdc£©10s  25¡æ±5¡æ
¼«¿ÇÄ͵çѹ/Test voltage between terminals and case
3000V 50Hz 60s£¬25¡æ±5¡æ
ËðºÄ½ÇÕýÇÐ/Dissipation factor
tgδ≤1×10-3   at 25¡æ±5¡æ£¬1kHz
¾øÔµµç×è/Insulation resistance
C×R≥5000s£¬at 100Vdc£¬25¡æ±5¡æ£¬60s
Ô¤ÆÚÊÙÃü/Life expectancy
200000h at Ur and 70¡æ
´Ë²úÆ·¹Ø¼ü×Ö£ºñîºÏµçÈÝÆ÷¡¢Â˲¨µçÈÝÆ÷¡¢¸ßѹÂ˲¨µçÈÝÆ÷
»ªÔ£µçÈÝ-¸ßÆ·ÖʽðÊô»¯±¡Ä¤µçÈÝ×¨ÒµÖÆÔìÉÌ
¹«Ë¾Ãû³Æ£º ¹ã¶«»ªÔ£µç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 020 66311928 / º«Ã·
ÊÖ»ú£º 18665682511
µØ Ö·£º ¹ã¶«Ê¡¹ãÖÝÊÐÌìºÓÇøÁú¶´µÚÈý¹¤ÒµÇøE¶°
ÓÊ ±à£º 510520
Ö÷ Ò³£º http://www.hy-el.com
  • CBB28½ðÊô»¯¾Û±ûϩĤµçÈÝÆ÷
  • CL23УÕýµçÈÝ£¨½ðÊô»¯¾ÛÒÒõ¥Ä¤£©-±à´ø
  • »ªÔ£ C74 ÈýÏàACÂ˲¨µçÈÝ
  • CBB65½»Á÷µç¶¯»úÓýðÊô»¯¾Û±ûϩĤ
  • CBB22½ðÊô»¯¾Û±ûϩĤµçÈÝÆ÷
  • CL20½ðÊô»¯¾Ûõ¥±¡Ä¤µçÈÝÆ÷
  • C82 SVGÈáÐÔÖ±Á÷ϵͳµçÈÝÆ÷
  • C33 IGBT»º³åÎüÊÕµçÈÝÆ÷
  • C47ϵÁÐ ¸ßѹгÕñÄ£¿éµçÈÝ
  • ÈýÏàACÂ˲¨µçÈÝ
