C53直流支撑DC-Link/耦合、滤波电容器
型号
规格
价格(元)
尺寸(mm)
引出
C53
30vF/800V
23
D46*L 50
M6.M8
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于UPS、SMPSs,逆变电源、焊机电源等设备中起耦合隔直/滤波或DC-Link用。
DC-Link and coupling/filtering for UPS,SMPSs,inverter,welding machine power.
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:金属化膜干式结构
封装:阻燃迈拉胶带,阻燃(94V-0级)环氧封装
引出:镀锡铜螺母引出
大电流、低电感
高稳定性
具有自愈性
Dielectric:Polypropylene film
Construction:Extended metalized film ,dry connection
Coating:Polyester tape wrapping with resin sealing.
Flame retardant execution(UL94V-0)
Terminals:Copper nut leads
High current,low inductance
High stability
Self healing
技术性能/Specifications
引用标准/Reference standards
GB/T 17702 IEC 61071
工作温度范围/Operating temperature range
-40℃~85℃
容量范围/Capacitance
15μF~300μF
额定电压/Rated Voltage
600Vdc~1200Vdc
容量偏差/Tolerance
±5% ±10%
极间耐电压/Test voltage between terminals
1.5Ur(Vdc)10s 25℃±5℃
极壳耐电压/Test voltage between terminals and case
3000V 50Hz 60s,25℃±5℃
损耗角正切/Dissipation factor
tgδ≤20×10-4 at 25℃±5℃,100Hz
绝缘电阻/Insulation resistance
C×R≥5000s,at 100Vdc,25℃±5℃,60s
预期寿命/Life expectancy
200000h at Ur and 70℃
此产品关键字:耦合电容器、滤波电容器、高压滤波电容器
华裕电容-高品质金属化薄膜电容专业制造商
