C54直流链电容
型号
规格
价格(元)
尺寸(mm)
引出
C54
30vF/800V
38
93*75*30
2*M6
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于感应加热等设备中的直流母线支撑,平滑滤波电路。
Widely used in induction heating equipment in the DC bus bar support, smoothing filter circuit.
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:金属化膜干式结构
封装:金属铝外壳,阻燃(UL94V-0级)环氧封装
引出:镀锡铜螺母引出
容量大、体积小、高纹波电流承受能力、温升低,散热好、寿命长
Dielectric:Polypropylene film
Construction:Extended metalized film ,dry connection
Coating:Aluminum case with resin sealing.
Flame retardant execution(UL94V-0)
Terminals:Tinned copper nut extraction
Large capacity, small volume, high ripple current capability, low temperature rise, good heat dissipation, long service life
技术性能/Specifications
引用标准/Reference standards
GB/T 17702 IEC 61071
工作温度范围/Operating temperature range
-40℃~+85℃
容量范围/Capacitance
20μF~45μF
额定电压/Rated Voltage
800Vdc
容量偏差/Tolerance
±5% ±10%
耐电压/Withstand voltage
1.5Ur(Vdc)60s
损耗角正切/Dissipation factor
tgδ≤10×10-4 at 25℃±5℃,1kHz
绝缘电阻/Insulation resistance
C×R≥5000s,at 100Vdc,25℃±5℃,60s
耐电流冲击能力/Withstand strike current ability
dv/dt>30V/μs
有效电流/Effective current
30A~80A
杂散电感/Stray inductance
≤30nH
预期寿命/Life expectancy
200000h at Ur and 70℃
此产品关键字:直流支撑电容器、DC-LINGK直流链电容
华裕电容-高品质金属化薄膜电容专业制造商
