Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú C55Ö±Á÷Á´µçÈÝ
²úÆ·Ãû³Æ£º C55Ö±Á÷Á´µçÈÝ
ÐÍ ºÅ£º C55
C55Ö±Á÷Á´µçÈÝ
ÐͺÅ
¹æ¸ñ
¼Û¸ñ(Ôª£©
³ß´ç£¨mm)
Òý³ö
C55
2*16vF/400VDC
28
105.5*43*32  P1=42  P2=120.5
º¸Æ¬
¼Û¸ñ½ö¹©²Î¿¼£¬ÒÔ±¨¼Ûµ¥Îª×¼¡£
Ö÷ÒªÓ¦ÓÃ/Application
ÌØ±ðÊÊÓÃÓÚ²ÉÓõ¥¹ÜIGBT×ö¿ª¹ØÔªÆ÷¼þµÄСµçÁ÷º¸»ú£¨400AÒÔÏ£©
Particularly applicable to the single IGBT do switch components of the small current welder ( below 400A)
²úÆ·ÌØµã/Characteristics
µç½éÖÊ£º¾Û±ûÏ©±¡Ä¤
½á¹¹£º½ðÊô»¯Ä¤¸Éʽ½á¹¹
·â×°£ºËÜÁÏÍâ¿Ç£¬×èȼ£¨UL94V-0¼¶£©»·Ñõ·â×°
Òý³ö£º¶ÆÎýÍ­ÂÝĸÒý³ö
ÐÔÄÜÎȶ¨¡¢¿É¿¿ÐԸߡ¢Ìå»ýС¡¢°²×°·½±ã
Dielectric£ºPolypropylene film
Construction£ºExtended  metalized  film £¬dry connection
Coating£ºPlastic casing.Flame retardant execution£¨UL94V-0£©
Terminals£ºTinned copper nut extraction
Stable performance, high reliability, small volume, convenient installation
¼¼ÊõÐÔÄÜ/Specifications
ÒýÓñê×¼/Reference standards
GB/T 17702  IEC 61071
¹¤×÷ζȷ¶Î§/Operating temperature range
-40¡æ¡«+85¡æ
ÈÝÁ¿·¶Î§/Capacitance
2×10μF
2×16μF
2×30μF
¶î¶¨µçѹ/Rated Voltage
400Vdc
ÈÝÁ¿Æ«²î/Tolerance
±5%
ÀËÓ¿µçѹ/ Surge voltage
650Vdc  100ms
¹ýѹÔËÐÐʱ¼ä/Overvoltage operating time
1.1Un¿É³¤ÆÚÔËÐÐ
¼«¼äÄ͵çѹ/Test voltage between terminals
650Vdc   60s
¼«¿ÇÄ͵çѹ/Test voltage between terminals and case
2000Vac 10s
ËðºÄ½ÇÕýÇÐ/Dissipation factor
tgδ≤10×10-4
¾øÔµµç×è/Insulation resistance
C×R≥5000s£¬at 100Vdc£¬25¡æ±5¡æ£¬60s
ÓÐЧµçÁ÷/Effective current£¨ΔT£¼25¡æ£©
20A
30A
40A
µÈЧ´®Áªµç×è/ Equivalent series resistance
£¼2.3mΩ
£¼1.8mΩ
£¼1.6mΩ
ÔÓÉ¢µç¸Ð/Stray inductance
≤20nH
Ô¤ÆÚÊÙÃü/Life expectancy
200000h at Ur and 70¡æ
´Ë²úÆ·¹Ø¼ü×Ö£ºÂ˲¨µçÈÝ Äæ±äº¸»úרÓÃÂ˲¨µçÈÝ Ö±Á÷Á´µçÈÝ
»ªÔ£µçÈÝ-¸ßÆ·ÖʽðÊô»¯±¡Ä¤µçÈÝ×¨ÒµÖÆÔìÉÌ
¹«Ë¾Ãû³Æ£º ¹ã¶«»ªÔ£µç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 020 66311928 / º«Ã·
ÊÖ»ú£º 18665682511
µØ Ö·£º ¹ã¶«Ê¡¹ãÖÝÊÐÌìºÓÇøÁú¶´µÚÈý¹¤ÒµÇøE¶°
ÓÊ ±à£º 510520
Ö÷ Ò³£º http://www.hy-el.com
  • CBB28½ðÊô»¯¾Û±ûϩĤµçÈÝÆ÷
  • CL23УÕýµçÈÝ£¨½ðÊô»¯¾ÛÒÒõ¥Ä¤£©-±à´ø
  • »ªÔ£ C74 ÈýÏàACÂ˲¨µçÈÝ
  • CBB65½»Á÷µç¶¯»úÓýðÊô»¯¾Û±ûϩĤ
  • CBB22½ðÊô»¯¾Û±ûϩĤµçÈÝÆ÷
  • CL20½ðÊô»¯¾Ûõ¥±¡Ä¤µçÈÝÆ÷
  • C82 SVGÈáÐÔÖ±Á÷ϵͳµçÈÝÆ÷
  • C33 IGBT»º³åÎüÊÕµçÈÝÆ÷
  • C47ϵÁÐ ¸ßѹгÕñÄ£¿éµçÈÝ
  • ÈýÏàACÂ˲¨µçÈÝ
