C61 交直流滤波和高纹波电流电容
型号
规格
价格(元)
尺寸(mm)
引出
C61
20vF/400V
18
D44*L 44
M6
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于UPS、SMPSs,逆变电源、焊机电源等设备中输入输出滤波
Input and output filtering in UPS,SMPSs,inverter,welding machine power
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:金属化膜干式结构
封装:阻燃迈拉胶带,阻燃(UL94V-0级)环氧封装
引出:镀锡铜螺母引出
高纹波电流高稳定性低损耗具有自愈性
Dielectric:Polypropylene film
Construction:Extended metalized film ,dry connection
Coating:Polyester tape wrapping with resin sealing.
Flame retardant execution(UL94V-0)
Terminals:Tinned copper nut extraction
Heavy ripple current,High stability,Low losses,Self healing
技术性能/Specifications
引用标准/Reference standards
GB/T 17702 IEC 61071
工作温度范围/Operating temperature range
-40℃~85℃
容量范围/Capacitance
5.0μF~100μF
额定电压/Rated Voltage
400Vdc~1200Vdc(250Vac~500Vac)
容量偏差/Tolerance
±5% ±10%
极间耐电压/Test voltage between terminals
1.6Ur 10s 25℃±5℃
极壳耐电压/Test voltage between terminals and case
3000V 50Hz 60s,25℃±5℃
损耗角正切/Dissipation factor
tgδ≤1×10-3 at 25℃±5℃,100Hz
绝缘电阻/Insulation resistance
C×R≥5000s,at 100Vdc,25℃±5℃,60s
预期寿命/Life expectancy
200000h at Ur and 70℃
此产品关键字:
高纹波滤波电容器 大电流滤波电容器 交流滤波电容器
华裕电容-高品质金属化薄膜电容专业制造商
