Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú C71 ACг²¨Â˲¨µçÈÝ
²úÆ·Ãû³Æ£º C71 ACг²¨Â˲¨µçÈÝ
ÐÍ ºÅ£º C71
C71  ACг²¨Â˲¨µçÈÝ
ÐͺÅ
¹æ¸ñ
¼Û¸ñ(Ôª£©
³ß´ç£¨mm)
Òý³ö
C71
50vF/450V
180
D105*L76  3.18KVar
M8
¼Û¸ñ½ö¹©²Î¿¼£¬ÒÔ±¨¼Ûµ¥Îª×¼¡£
Ö÷ÒªÓ¦ÓÃ/Application
Ó¦ÓÃÓÚÂ˳ýµçÁ¦ÏµÍ³µÄг²¨£¬´Ó¶øÌá¸ß¹¦ÂÊÒòÊý£¬¸ÄÉÆ¹©µçÖÊÁ¿
Applied to filter the harmonic of power system, so as to improve the power factor, improve the quality of power supply
²úÆ·ÌØµã/Characteristics
µç½éÖÊ£º¾Û±ûÏ©±¡Ä¤
½á¹¹£º½ðÊô»¯Ä¤¸Éʽ½á¹¹
·â×°£º½ðÊôÂÁÍâ¿Ç£¬½þÓÍ·â×°
Òý³ö£ºÂÝ˨Òý³ö
¸ßµçѹ¡¢´óµçÁ÷£¬µÍËðºÄ
ÄÚ²¿ÎÂÉýС
Dielectric£ºPolypropylene film
Structure: metallized film dry structure
Package: metal aluminum shell, dip package
Derivative: bolt extraction
High voltage, high current, low loss
Inside Wen Shengxiao
¼¼ÊõÐÔÄÜ/Specifications
ÒýÓñê×¼/Reference standards
GB/T 17702  IEC 61071  GB/T 12747
¶î¶¨ÆµÂÊRated frequency (fn)
50/60Hz
µçÈÝÁ¿Æ«²îCapacitance tolerance
±5%(ͨ³£ÔÚ±2%ÒÔÄÚ)
˲¼äµçÁ÷Inrush current (Is)
200 Irms
×î´ó¹ýµçÁ÷Overcurrent (Imax)
1.3Irms/24h
¼«¼äÄÍѹTest voltage (UT-T)
1000Vac,10s
¼«¿ÇÄÍѹTest voltage (UT-C)
3000Vac,10s
ËðºÄDissipation factor(tgδ)@1kHz
£¼0.0060
ÆøºòÀà±ðClimatic category
40/70/21
¹¤×÷ζȷ¶Î§Operating temperature range
-25¡æ¡«55¡æ
´æ´¢Î¶Èstorage Temperature
-30¡æ¡«85¡æ
ÔÊÐí×î¸ßʪ¶ÈPermissible max relative humidity
95%RII
±£»¤µÈ¼¶Degree of protection
IP00
ƽ¾ùÊÙÃüLife Expectancy
After 50 000 hours at Urms¡¢Irms¡¢fn¡¢50¡æΔC/C≤3%
ÀäÈ´·½Ê½Cooling
Naturally air-cooled(or forced cooling)
°²×°·½Ê½(Vertical/Horizontal/Both)
Both
Òý³ö¶ËŤÁ¦Terminals & torque
5 N·m
×î¸ßʹÓú£°ÎMax Altitude
2000 m
´Ë²úÆ·¹Ø¼ü×Ö£º
г²¨Â˲¨µçÈÝÆ÷ ¸ß´Îг²¨Â˲¨µçÈÝ ¹¦ÂÊÒòÊý µçÍøÖÊÁ¿
»ªÔ£µçÈÝ-¸ßÆ·ÖʽðÊô»¯±¡Ä¤µçÈÝ×¨ÒµÖÆÔìÉÌ
¹«Ë¾Ãû³Æ£º ¹ã¶«»ªÔ£µç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 020 66311928 / º«Ã·
ÊÖ»ú£º 18665682511
µØ Ö·£º ¹ã¶«Ê¡¹ãÖÝÊÐÌìºÓÇøÁú¶´µÚÈý¹¤ÒµÇøE¶°
ÓÊ ±à£º 510520
Ö÷ Ò³£º http://www.hy-el.com
  • CBB28½ðÊô»¯¾Û±ûϩĤµçÈÝÆ÷
  • CL23УÕýµçÈÝ£¨½ðÊô»¯¾ÛÒÒõ¥Ä¤£©-±à´ø
  • »ªÔ£ C74 ÈýÏàACÂ˲¨µçÈÝ
  • CBB65½»Á÷µç¶¯»úÓýðÊô»¯¾Û±ûϩĤ
  • CBB22½ðÊô»¯¾Û±ûϩĤµçÈÝÆ÷
  • CL20½ðÊô»¯¾Ûõ¥±¡Ä¤µçÈÝÆ÷
  • C82 SVGÈáÐÔÖ±Á÷ϵͳµçÈÝÆ÷
  • C33 IGBT»º³åÎüÊÕµçÈÝÆ÷
  • C47ϵÁÐ ¸ßѹгÕñÄ£¿éµçÈÝ
  • ÈýÏàACÂ˲¨µçÈÝ
