Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú C73ÈýÏàACÂ˲¨µçÈÝ
²úÆ·Ãû³Æ£º C73ÈýÏàACÂ˲¨µçÈÝ
ÐÍ ºÅ£º C73
C73ÈýÏàACÂ˲¨µçÈÝ
ÐͺÅ
¹æ¸ñ
¼Û¸ñ(Ôª£©
³ß´ç£¨mm)
Òý³ö
C73
3*200vF/400V
500
225*120*235
M8
¼Û¸ñ½ö¹©²Î¿¼£¬ÒÔ±¨¼Ûµ¥Îª×¼¡£
Ö÷ÒªÓ¦ÓÃ/Application
¹ã·ºÓ¦ÓÃÓÚµçÁ¦µç×ÓÉ豸Öн»Á÷Â˲¨³¡ºÏ¡£
Widely used in for power electronic equipment£¬ACfilter applications.
²úÆ·ÌØµã/Characteristics
µç½éÖÊ£º¾Û±ûÏ©±¡Ä¤
½á¹¹£º½ðÊô»¯Ä¤¸Éʽ½á¹¹
·â×°£º½ðÊôÍâ¿Ç£¬×èȼ£¨UL94V-0¼¶£©»·Ñõ·â×°
Òý³ö£º¶ÆÎýÍ­ÂÝĸÒý³ö
¸ßµçÁ÷£¬´óÈÝÁ¿
µÍ×ԸУ¬µÍËðºÄ
¾ßÓÐ×ÔÓúÐÔ
Dielectric£ºPolypropylene film
Construction£ºExtended  metalized  film £¬dry connection
Coating£ºAluminum case with resin sealing.
Flame retardant execution£¨UL94V-0£©
Terminals£ºCopper nut or screw leads
High current£¬high capacitance
Low losses£¬low inductance
Self healing
¼¼ÊõÐÔÄÜ/Specifications
ÒýÓñê×¼/Reference standards
GB/T 17702  IEC 61071   GB/T 12747
¹¤×÷ζȷ¶Î§/Operating temperature range
-40¡æ¡«85¡æ
ÈÝÁ¿·¶Î§/Capacitance
3×20μF¡«3×500μF
¶î¶¨µçѹ/Rated Voltage
400Vac¡«1000Vac
ÈÝÁ¿Æ«²î/Tolerance
±5%  ±10%
¼«¼äÄ͵çѹ/Test voltage between terminals
2.0Un  10s  25¡æ±5¡æ
¼«¿ÇÄ͵çѹ/Test voltage between terminals and case
3000V 50Hz 60s£¬25¡æ±5¡æ
ËðºÄ½ÇÕýÇÐ/Dissipation factor
tgδ≤2×10-3   at 25¡æ±5¡æ£¬100Hz
¾øÔµµç×è/Insulation resistance
C×R≥5000s£¬at 100Vdc£¬25¡æ±5¡æ£¬60s
Ô¤ÆÚÊÙÃü/Life expectancy
200000h at Ur and 70¡æ£¬30000h at Urms
´Ë²úÆ·¹Ø¼ü×Ö£ºÈýÏཻÁ÷Â˲¨µçÈÝÆ÷¡¢ACÂ˲¨µçÈÝ¡¢½»Á÷Â˲¨µçÈݵÄ×÷ÓᢸßЧ½»Á÷Â˲¨µçÈÝ
»ªÔ£µçÈÝ-¸ßÆ·ÖʽðÊô»¯±¡Ä¤µçÈÝ×¨ÒµÖÆÔìÉÌ
¹«Ë¾Ãû³Æ£º ¹ã¶«»ªÔ£µç×ÓÓÐÏÞ¹«Ë¾
µç »°£º 020 66311928 / º«Ã·
ÊÖ»ú£º 18665682511
µØ Ö·£º ¹ã¶«Ê¡¹ãÖÝÊÐÌìºÓÇøÁú¶´µÚÈý¹¤ÒµÇøE¶°
ÓÊ ±à£º 510520
Ö÷ Ò³£º http://www.hy-el.com
  • CBB28½ðÊô»¯¾Û±ûϩĤµçÈÝÆ÷
  • CL23УÕýµçÈÝ£¨½ðÊô»¯¾ÛÒÒõ¥Ä¤£©-±à´ø
  • »ªÔ£ C74 ÈýÏàACÂ˲¨µçÈÝ
  • CBB65½»Á÷µç¶¯»úÓýðÊô»¯¾Û±ûϩĤ
  • CBB22½ðÊô»¯¾Û±ûϩĤµçÈÝÆ÷
  • CL20½ðÊô»¯¾Ûõ¥±¡Ä¤µçÈÝÆ÷
  • C82 SVGÈáÐÔÖ±Á÷ϵͳµçÈÝÆ÷
  • C33 IGBT»º³åÎüÊÕµçÈÝÆ÷
  • C47ϵÁÐ ¸ßѹгÕñÄ£¿éµçÈÝ
  • ÈýÏàACÂ˲¨µçÈÝ
