C81 SVG柔性直流系统电容器
型号
规格
价格(元)
尺寸(mm)
C81
1120UF/2000V
1300
400*125*240
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于UPS、变频器、电镀电源、逆变焊机、逆变电源以及感应加热设备、大型开关电源等其他电力电子设备作滤波用或贮能焊机中作贮能电容用。
Widely used in UPS,inverter electroplating power,welding
machine,inversion power and also induction heating machine,
big switch power supply for filter and energy storage for welding machine。
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:金属化膜干式结构
封装:铝壳或不锈钢外壳,阻燃(UL94V-0级)环氧封装
引出:铜螺栓或铜螺母引出
高纹波电流,高峰值电流
Dielectric:Polypropylene film
Construction:Extended metalized film ,dry connection
Package: Aluminum or stainless steel casing,
Flame retardant epoxy encapsulation (UL94V-0)
Derivative: copper bolts or nuts of copper extraction
High ripple current, high peak current
技术性能/Specifications
引用标准/Reference standards
GB/T 17702 IEC 61071
工作温度范围/Operating temperature range
-40℃~85℃
容量范围/Capacitance
125μF~20000μF
额定电压/Rated Voltage
800Vdc~15kVdc
容量偏差/Tolerance
±5% ±10%
极间耐电压/Test voltage between terminals
(1.35~1.5)Ur 60s 25℃±5℃
损耗角正切/Dissipation factor
tgδ≤20×10-4 at 25℃±5℃,100Hz
绝缘电阻/Insulation resistance
C×R≥5000s,at 100Vdc,25℃±5℃,60s
耐电流冲击能力/Withstand strike current ability
dv/dt>10v/μs
杂散电感/Stray inductance
≤120nH
有效电流/Effective current
(80~500)A
此产品关键字:直流滤波电容、直流支撑电容、柔性直流系统电容器
华裕电容-高品质金属化薄膜电容专业制造商
