Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú EL6631±¶¸£PROFINET¶Ë×ÓÄ£¿é
²úÆ·Ãû³Æ£º EL6631±¶¸£PROFINET¶Ë×ÓÄ£¿é
ÐÍ ºÅ£º EL6631
PROFINET IO controller/device terminal EL6631
Status LEDs
X1
X2
Top view
EL6631 | PROFINET IO controller/device terminal
The EL6631 PROFINET IO controller (master) terminal supports the complete real-time function (RT) as well as extensive diagnostic possibilities. All services in accordance with Conformance Class B are supported. Up to 15 PROFINET IO devices can be projected on the EL6631.
The EL6631-0010 PROFINET IO device (slave) terminal enables simple exchange of data between EtherCAT and PROFINET IO. It is a device in the EtherCAT strand, which can consist of up to 65,535 devices. The EL6631-0010 has a 3-port switch. Two ports are fed to the outside on RJ 45 sockets. This allows the I/O stations to be structured as a line topology, as a result of which the wiring is simplified. The maximum distance between two devices is 100 m.
Protocols such as LLDP or SNMP can be used for network diagnosis.
Technical data EL6631 EL6631-0010
Technology PROFINET IO
Number of ports/channels 2
Ethernet interface 100BASE-TX Ethernet with 2 x RJ 45
Fieldbus PROFINET IO controller PROFINET IO device
Cable length up to 100 m twisted pair
Hardware diagnosis status LEDs
Power supply via the E-bus
Electrical isolation 500 V (E-bus/Ethernet)
Protocol RT
Configuration via EtherCAT master
Current consumption E-bus typ. 400 mA
Special features LLDP, SNMP,
Conformance Class B,
max. 15 RT devices,
min. 1 ms RT cycle
Weight approx. 75 g
Operating/storage temperature 0…+55 °C/-25…+85 °C
Relative humidity 95 %, no condensation
Vibration/shock resistance conforms to EN 60068-2-6/EN 60068-2-27
EMC immunity/emission conforms to EN 61000-6-2/EN 61000-6-4
Protect. class/installation pos. IP 20/see documentation
Approvals CE, UL, Ex
¹«Ë¾Ãû³Æ£º ÏÃÃÅÔ¶Åô×Ô¶¯»¯É豸ÓÐÏÞ¹«Ë¾
µç »°£º 0592 5523720 / ¹ù¸£ÁÖ
ÊÖ»ú£º 15750709560
µØ Ö·£º ÏÃÃźþÀïÇøÏúÌ·369ºÅ
ÓÊ ±à£º 361000
Ö÷ Ò³£º http://
  • KL9010ÏÖ»õ
  • KL8001ÏÖ»õ
  • BK3120ÏÖ»õ
  • BK2000 ×ÜÏßñîºÏÆ÷
  • EL6751ÏÖ»õ
  • EL2008ÏÖ»õ
  • EL2004ÏÖ»õ
  • KL9100ÏÖ»õ
  • BK3150ñîºÏÆ÷ÏÖ»õ
  • ek1100±¶¸£
