C41水冷式谐振电容器
型号 规格 额定电压价格(元) 尺寸(mm)
C41 0.68uF/300KVar 700Vrms 400 80*80*36.5
价格仅供参考,以报价单为准。
主要应用/Application
广泛应用于大功率的高频谐振设备中
Widely used in high power high frequency resonant device
产品特点/Characteristics
电介质:聚丙烯薄膜
结构:铝箔、金属化膜内串结构
封装:铜板
高电压、高频率、高dv/dt特性
能承受大电流,散热性能好
Dielectric:Polypropylene film
Structure: aluminum foil, metal film inner series structure
Package: Copper
High voltage, high frequency, high dv/dt characteristics
Can bear high current, good heat radiation performance
技术性能/Specifications
引用标准/Reference standards GB/T 17702 IEC 61071 GB/T 12747
工作温度范围/Operating temperature range -40℃~85℃
容量范围/Capacitance 0.24μF~1.2μF
容量偏差/Tolerance ±5% ±10%
极间耐电压/Test voltage between terminals 5.0Ur10s 25℃±5℃
极壳耐电压/Test voltage between terminals
and case
6000Vac或9000Vdc 50Hz 60s,25℃±5℃
损耗角正切/Dissipation factor tgδ≤5×10-4 at 25℃±5℃,1kHz
绝缘电阻/Insulation resistance R≥200000MΩ,at 500Vdc,25℃±5℃,60s
预期寿命/Life expectancy 200000h at Ur and 70℃,30000h at Urms
此产品关键字:高频谐振电容、谐振电路电容的功能、谐振电容的影响
华裕电容-高品质金属化薄膜电容专业制造商
