日本神视MS-GXL8-4光幕传感器
A: 透过型 FT-FM10L FT-SFM2L FT-BB FT-NBB FT-FM2 FT-FM2S FT-T80 FT-SFM2 FT-N8 FT-NFM2 FT-NFM2S FT-NFM2S4 FT-SNFM2 FT-R80 FT-V10 FT-SFM2SV2 FT-V22 FT-V41 FT-WA30 FT-WA8 FT-WZ8H FT-WZ8E FT-WZ8 FT-WKV8 FT-WS8L FT-W8 FT-WS3 FT-WS8 FT-W4 FT-WS4 FT-WV42 FT-Z8H FT-Z8E FT-Z8 FT-P80 FT-P60 FT-P40 FT-P2 FT-PS1 FT-A30 FT-A8(5M长) FT-AFM2 FT-AFM2E FT-K8 FT-KV1 FT-E12 FT-E22 FT-P81X FT-H35-M2 FT-H35-M2S6 FT-H20W-M1 FT-H20W-M2 FT-H20-M1 FT-H1-FM2 FT-Z802Y FT-L8Y FT-V8Y FT-6V FT-60V
B:反射型 FD-B8 FD-5 FD-FM2 FD-FM2S FD-FM2S4 FD-T80 FD-T40 FD-S80 FD-N8 FD-N4 FD-NFM2 FD-NFM2S FD-SNFM2 FD-R80 FD-SFM2SV2 FD-V41 FD-WKZ1 FD-W8 FD-W44 FD-WT8 FD-WS8 FD-WT4 FD-WG4 FD-WSG4 FD-WL41 FD-WL42 FD-WV42 FD-P80 FD-P60 FD-P50 FD-P40 FD-P2 FD-A15 FD-AFM2 FD-AFM2E FG-G4 FD-G6 FD-EG1 FD-EG2 FD-EG3 FD-E12 FD-E22 FD-EN500S1 FD-ENM1S1 FD-L43 FD-L44 FD-L44S FD-L46 FD-L41 FD-L42 FD-L4 FD-F8Y FD-F41 FD-F91 FD-F4 FD-F9 FD-P81X FD-G6X FD-H35-M2 FD-H35-M2S6 FD-H20-M1 FD-H35-20S FD-H20-21 FD-H30-L32 FD-H18-L31 FD-H13-FM2 FD-6V
日本神视光纤放大器: FX-301 FX-301B FX-301G FX-301H FX-301P FX-301BP FX-301GP FX-301HP FX-311 FX-311B FX-311G FX-311P FX-311BP FX-311GP FX-11A FX-101 FX-102 FX2-A3R FX3-A3R FX4-A3R
日本神视光电传感器: CX-411 CX-411-P CX-412 CX-412-P CX-421 CX-421-P CX-422 CX-422-P CX-423 CX-423-P CX-424 CX-424-P CX-441 CX-411-P CX-442 CX-442-P CX-481 CX-481-P CX-482 CX-482-P CX-491 CX-491-P CX-493 CX-493-P
EX-11A EX-11B EX-11EA EX-11EB EX-13A EX-13B EX-13EA EX-13EB EX-19A EX-19B EX-14A EX-14B EX-14B-PN EX-15 EX-15E EX-17 EX-17E EX-21A EX-21B EX-23 EX-22A EX-22B EX-23A EX-23B EX-24A EX-24B EX-26A EX-26B EX-28A EX-28B EX-29A EX-29B EX-29-PN EX-31A EX-31A-PN EX-31B EX-31B-PN EX-32A EX-32A-PN EX-32B EX-32B-PN EX-42 EX-44 EX-43 EX-43T EQ-34 EQ-34-PN EQ-34W
CY-21(-PN) C-27(-PN) CY-29(-PN) CY-22(-PN) CY-11A CY-11B CY-17A CY-17B CY-19A CY-19B CY-12A CY-12B
PM-K24/PM-L24/PM-F24/PM-R24/PM-U24/PM-K44/PM-T44/PM-L44PM-Y44/PM-F44/PM-R44 PM-K54/ PM-T54/PM-L54/PM-Y54/PM-F54/PM-R54
PM2-LH10 PM2-LH10B PM2-LF10 PM2-LF10B PM2-LL10 PM2-LL10B PM2-LH10-C1 PM2-LH10B-C1 PM2-LF10-C1 PM2-LF10B-C1 PM2-LL10-C1 PM2-LL10B-C1
NX5-M10RA NX5-M10RB NX5-M30A NX5-M30B NX5-PRVM5A NX5-PRVM5B NX5-RM7A NX5-RM7B NX5-D700A NX5-D700B VF-M10 VF-M10T VF-RM5 VF-RM5T VF-PRM3 VF-D500 VF-D500T VF-D1000 VF-D1000T
日本神视激光传感器: LS-H91 LS-H21 LS-H22 LS-401 LS-401P LS-401-C2 LS-401P-C2 LX-101
日本神视接近传感器: GL-8F GL-8FI GL-8FB GL-8FIB GL-8H GL-8HI GL-8HB GL-8HIB GL-8FU GL-8FUI GL-8FUB GL-8FUIB GL-8HU GL-8HUI GL-8HUB GL-8HUIB GL-N12F GL-N12FB GL-N12FI GL-N12FIB GL-N12H GL-N12HB GL-N12HI GL-N12HIB GL-N12HIB-PN GL-18H GL-18HI GL-18HB GL-18HL GL-18HLI GL-18HLB GX-5SU GX-5SUB GX-8MU GX-8MUB GX-12MU GX-12MUB GX-18MU GX-18MUB GX-30MU GX-30MUB GX-8MLU GX-8MLUB GX-12MLU GX-12MLUB GX-18MLU GX-18MLUB GX-30MLU GX-30MLUB GH-2S GH-3S GH-5S GH-8S GH-F8S GA-14 GA-15
日本神视压力传感器: DP-101 DP-101A DP-101-M DP-102 DP-102A DP2-20 DP2-80 DP2-60 DP2-21 DP2-41 DP2-61 DP2-22 DP2-42 DP2-62 DP3-20 DP3-80 DP3-21 DP3-41 DP3-22 DP3-42
日本神视区域光幕 NA2-N8 NA2-12 NA2-16 NA2-20 NA2-24 NA2-28 NA2-28-PN NA1-PK5 NA1-PK5-PN NA1-5 NA1-5-PN NA1-11 NA1-11-PN
日本松下Panasonic系列产品
AZD系列
1、 全系列产品取得EN60947标准认证
2、 易于维修,油封隔离及耐冲击之安全行程开关
3、 采用高硬度耐冲击之复合材料为主体构造
4、 接点溶解异常时,强制开离机构可使接点即刻开离(EN强制开离认定以→表示)
5、 可适用多种导线管规格(PG7-PG13.5)
6、 取得IEC947-5-1,VDE、FI之工业电气安全规格认证
7、 适用工作温度范围广(-20℃至+60℃).防护等级为IP65
8,机械寿命为1000万次以上,电气寿命为50万次以上
产品介绍 控制输出:6A 250V AC 6A 380V AC 5A 24V DC 寿命(最小工作次数): 机械:10的7次方 电动:2×10的5次方 工作强度(最大): 【推压塞柱型】 (链接杆型) 6.37N{650gf} 4.90N{500gf} 端子:螺钉端子(导管连接器:PF:1/2,PG:13.5型) 导线:橡胶绝缘软线 安装齿距: 21(×47)mm (适用的螺钉) (M4螺钉) 适用标准:UL/CSA
具体产品类型: 1.主要产品 激 励 器 零 件 编 号 滚轴杆 AZD1000 AZD1050 推压塞杆 AZD1001 AZD1051 滚轴塞杆 AZD1002 AZD1052 滚轴臂 AZD1004 AZD1054 可调式滚轴臂 AZD1008 / AZD1058 备注: 导管尺寸类型:PF型(PF1/2),PG型(PG13.5) 2.方块 产品名称 零件编号 滚轴杆 AZD1800 激励器类型 滚轴臂 AZD1804 可调滚轴臂 AZD1808
前部方块 AZD1820
用于塞杆型 PF型 AZD1001 主方块 PG型 AZD1051 用于臂型 PF型 AZD1104 PG型 AZD1154 3.导管连接器 产品名称 零件编号 备注:导管连接器用来接电缆内 PF型导管连接器 AZD1830 置橡胶密封内径(9mm和11mm)
AZ系列
ML 微型限位开关小巧型横式限位开关。
特性
1. 长寿命
采用高效率线圈弹簧开关装置,机械寿命为1000万次以上。
2. 高机械强度、小巧、轻便
附件间距为25.4mm与Z基准模型微型开关相同。外罩盖使用良好的机械特性的强塑胶,用 M4螺钉固定。
3. 对大超程有很大的缓冲、减震作用
4. 开关自身有防尘和耐油性结构
开关本体使用被压缩的橡胶圈和薄膜进行密封,环氧树脂密封端类型产品的端子部分为完全密闭式结 构。
典型应用
用于食品加工、自动装、机床、传送机、处理机的顺序控制。当安装空间有限制并要求防护等级时可理想用于轻工业机械。
产品类型 1. 标准类型 激励器类型 零件编号 短推压塞柱 AZ7100 长推压塞柱 AZ7110 链接杆 AZ7120 滚轴杆 AZ7121 单向滚轴杆 AZ7124 链接短杆 AZ7140 短滚轴杆 AZ7141 单向短滚轴杆 AZ7144 面板安装推压塞柱 AZ7310 面板安装滚轴塞柱 AZ7311 面板安装滚轴塞柱 AZ7312 可伸缩杆 AZ7166
主营:日本山武azbil,日本基恩士keyence,日本神视松下Panasonic,日本竹中TAKEX,日本欧姆龙OMRON
日本奥普士OPTEX,日本北阳HOKUYO,日本东邦T0HO,日本富士FUJI,日本三洋SANYO,
美国霍尼韦尔honeywell,美国邦纳Banner,台湾阳明fotek,台湾茂仁MOUJEN,台湾瑞科RIKO,
台湾天得tend,台湾开放KFPS,台湾士研ANV,安良,KGN光纤,德国施克SICK,巴鲁夫BALLUFF
法国施耐德Schneider,瑞士佳乐,科瑞CONTRINEX,韩国奥托尼克斯AUTONICS, BKC温控器,安全光幕,热电偶
深圳市创丰仪器仪表有限公司
深圳市宝安九区澎柏白金酒店大厦1001-1002室(即宝安汽车站正对面, 都之都大酒店,宝安广场旁边)
电话:0755-29796001,29120433,29120422
传真:0755-29796002
手机:13530544593,13143436561
企业QQ:800022795 网站www.Lansea.net
